Question about Sharp R-1480 Microwave Oven
Sharp R990C(s) Carousel Convection microwave cuts out on preheat at exactly 4:15 each time, regardless of temp set, or temp inside. It can be over 100 degrees inside according to my digital thermomenter, yet asking it to preheat to 40 degrees, it just times out and the motor and heat stops at 4:15 on my stopwatch. Conv and Cook light up on display, interior light, motor, fan, turntable all working, microwave working fine. It obviously can't measure the internal temp, perhaps it's just timing out? Got me beat!
  • 2 more comments
  • Greg Roles
    Greg Roles Jul 01, 2009
    Thanks for the response. No error codes at all, the display continutes to show preheat as per normal, except the oven has obviously turned off, light off, fan off, stopped rotating. "cook" also disappears. You have to press stop to clear the display. Happens if you preheat, or convection cook, or combo, hits 4:15 and it's over. Memory is clear. Everthing is working as it should otherwise. There is a click noise as it turns off at 4:15, like a relay. It has me beat!
  • Greg Roles
    Link goes nowhere, and I'm lost as to the breaker thing, do you mean the mains power? It's not tripping the mains at all, this is purely within the unit.
  • Greg Roles
    Guys, I'm in Australia, it's degrees celcius, that's about 90F i think : ) I only use the lowest setting as an example. I can have the oven way hotter,if I measure the inside with my digital thermometer, and it says over 100, then preheat it at 40 or even 70 degrees, it just churns away for the 4:15. Seems it can't register the temp inside.
    I found a solution on here to do with the dampner assembly, got all excited and checked this out. I found the dampner door, cam, switch etc, but at 4:15 it just turns off, dampner door stays shut. I can make the door open by pressing the switch, or by pressing stop on the control panel now stopped oven, and the cam rotates, pressing the switch, opening the dampner door.
    Dampner is out....
  • Greg Roles
    Good to have some idea of what to talk to the local techs about, thanks!
  • 10,515 Answers
As we are not there we can only make intelligent guess.I have seen this issue with most of the ovens.To be really honest, i have not got a same solution for every customer.
I can highlight the main reasons :-
1. In most cases, this is a problem with the inverter or a bad magnetron.If this being the case, you need to call sharp. This is tech's work. No way you could do it yourself. Sorry to be precise, but that's the solution.
2. Few people have find an issue with Microswitch. Either they are bad or not engaging properly.
The first REASON i mentioned is the most common and 90% people have the same problem.
Hope i helped you.
DO RATE THE SOLUTION.
Thanks for using "Fixya".
Posted on Jul 01, 2009
  • 66 Answers
You might not be able to preheat it to such a low temperature??? its an oven. its not even 40 degrees in your house? 40 degrees is cold. its an oven.
    Sergeant:
  • 326 Answers
  • SABARI ANAND
    SABARI ANAND Jul 01, 2009
    Go to your breaker box and reset the switch for the microwave.. that will fix it
  • 3,230 Answers
First of all i have a question -- Is there any error code on the display board?
It seems like you need to change the Display board, this is a chip base board backside to the oven display.
Thanks
Model R1800 Sharp Microwave Looking for Sharp Carousel Convection Oven Control Panel Model R-1800
What are your sympotms? I repair those boards.
Feel free to contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 22, 2016 | Sharp Microwave Ovens
User manual for 1200 w carousel ser# 57088
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Nov 15, 2015 | Sharp Microwave Ovens
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
Oct 19, 2017 | Sharp R-1874 Convection/Microwave Oven
I have a R-9H83 Sharp Carousel II Microwave Convection Oven that I have had for years and now when I use the convection to bake, it only will stay on for a few minutes and then just shut down. Any...
If you use a sensor function, the sensor may be obstructed, please clean the sides and top of your microwave with a dishcloth, warm water, and soap to dislodge any rough or stained spots.
If setting a timer, when setting to bake please pay close attention to the unit of measure so that you set it right, minutes vs. hours as you may leave the oven to do its business and return without noticing it did exactly what you told it to do but you had thought you entered a longer time.
Nov 21, 2013 | Sharp Microwave Ovens
How do i operate the convection part of model 863-5973-50 jcpenney microwave
Press convection button, then press button with temp you want, then press start to preheat. Once preheated, either press cancel once, to allow time to be input, or engage door button, an press Time and enter your cooking time. Then press start again
Nov 18, 2012 | Microwave Ovens
I need instructions on how to use Sharp Convection microwave Grill 2?
Best way short of Sharp is Google the model number of the unit with "manual" to try to locate free one online.
Nov 04, 2012 | Sharp R-930AK Convection/Microwave Oven
Show hight voltage shema capacitor sharp 1850 sharp carousel
Not sure exactly what you're asking but the service manual for the R-1850 is available online here and you can order part here or here.
Jan 22, 2011 | Sharp R-1850A Convection/Microwave Oven
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
Sharp R-1480 Microwave Oven Logo
258 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
