Computer restart my computer restarts after every 15 to 20 minutes. how can i fix this?
  • 258 Answers
Try running your antivirus complete system scan, make sure you have updated your antivirus within the program your using by selecting update
Posted on Jun 28, 2009
At idle 2005 4 litre mustang shows 50 psi at 75 degrees, when at normal temp pressure drops to 15,20 at idle. At 2,000 rpm shows 40 psi. This sounds low to me, is this normal?
That sounds normal. There would be specifications for it that you should check, but that sounds pretty normal. The specs probably show a pressure for idle at normal operating temperature, and another figure at a specified engine rpm. Or it may just have one spec at a certain rpm.
Dec 28, 2016 | 2005 Ford Mustang
Interior lights stay on wile i'm driving my 2005 lincoln navigator
Only one bad door switch should do that
The 20 min time out is the GEM or Body Module,
which is normal only because you have a bad switch,
otherwise it goes to sleep when either front door opens
Put radio on & open a door,the radio should go off
& kill the time delay if no issues exist
Feb 05, 2013 | 2005 Lincoln Navigator Luxury
My computer keeps restarting itself everytime i play games? How can i fix this?
It seems your power supply can't supply your computer power as needed so you need to replace your power supply. Use 500 watts pure power supply to avoid this problem.
Jun 23, 2017 | ASUS Essentio Computers & Internet
I get a message, "Frequency out of range. Nothibng else. The menue and other buttons don't do anything. Nothing else shows. I swapped out the monitor and the new one works.
This problem arise when your computer AGP driver not adjust monitor frequency.you fix it restart your computer and run safe mode settings resolution area(must be choice less area)or select 1024X768 pixel monitor frequency 60Hz press apply set OK.restart your computer.Run again normal mode.May be fix your problem.
Dec 27, 2009 | Princeton Digital VL1916 19" LCD Monitor
WHEN I PLAY DEVIL MAY CRY 4 MY PC RESTARTS
not sure but think your computer runs out of virtiual memory causing it to restert.
what graphics card are you using because it sounds like that you need a new one..
Dec 24, 2009 | Capcom Devil May Cry 4
CD Player not workinig
Try using a cd player cleaner disk, then remove the radio fuse in the fuse block wait about five minutes then re-install. This is done to restart the radio. If that don't work disconnect the negative from the battery, wait five minutes then reattach, this will restart the cd player for sure. This will also restart the car computer just so you are aware.
May 12, 2009 | Car Audio & Video
Flickers and crackling
This problem could be caused by bad capacitors or cold solder joints in the power supply circuits. The unit needs to be taken to a service center for testing and servicing. Hope this helps.
Apr 14, 2009 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
Alun Cox
David Payne
David Payne
