Question about Quantaray 100-300mm F4.5-6.7 Zoom Lens for Canon AF
Hello, I get an "err01" or "err99" when using my 24-105 canon L lens on 20D body. Repair center in Belgium said it would cost 599 euro for repair... Can you help me? Thanks Roelof
  • 2 more comments
  • roelof_breug Jun 28, 2009
    Contacts have been cleaned already as advised on internet fora, no result.
  • roelof_breug Jul 09, 2009
    Well, they charge me 599 euro's (abt 800 usd) in Belgium fo this...
    The 24-105 l canon lens costs about 1025 euro ( about 1300 usd) in Belgium...
    Or maybe I can service it in the States? Any idea what that would cost?
    Brigadier General:
  • 3,614 Answers
Well it seems that it was a mechanical problem on the unit. doing it yourself and try to fix it, may not solve the issue. it is better to send it out for repair cause of the sensitive part that may damage if you will service it.
Posted on Jun 28, 2009
    Brigadier General:
  • 8,619 Answers
Hi
You need to clean the contacts with a dry cloth an alcohol swap etc. of the lens and body. Also try to do firmware update.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jun 28, 2009
    If the contacts have already been cleaned then you need to do a firmware update. If that does not work then I would suggest you to buy a new one.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Jul 09, 2009
    Hi!
    The price of the lens is approximately $200. Please contact the Canon People based in Belgium on the following link to get a new one instead of getting it repaired---
    Quantaray 100-300mm F4.5-6.7 zoom lens
    Please do accept this solution and revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Yes you are absolutely right. I have inadvertently quoted the rates of Quantaray 70-300mm that too not in Belgium. However, I suggest you that it will be better buy a new one instead of getting it repaired.
    Thanks
    Rylee 70-300mm that too not in Belgium. However, I suggest you that it will be better buy a new one instead of getting it repaired.
    Thanks
    Rylee
Canon 20D. Says "Err
Error 99 is a result of an electronic communication problem normally between the lens and the camera body.
Use a red pencil eraser to "polish" the contacts even if they look clean do it again.
Take care to keep dirt out of the camera and lens bodies.
Another thing is often times the camera firmware needs to be updated to move on from this.
Another thing is the CF cards? The 20D was in an era where pretty well the larges CF card was a 2gig,I use several 1gig however if you have updated your cards to say an 8gig the firmware just can't handle the card.
Okay moving on clean the lens and body, update firmware, make sure the CF card isn't beyond the camera capabilities and last if all that stuff didn't work the it's possible the actual sensor is really dirty and needs cleaning.
The worst case scenario is that the shutter has failed. The Canon 20D is only good for 60,000 actuation's.
Hope this give you a few options
Apr 29, 2011 | Canon EOS-20D Body only Digital Camera
Err 99
Hello hemantp. This error code in this model indicates that the lens electrical contacts are dirty or slightly oxidized. To clean them you will need a common pencil with a clean eraser on the end and a lens cloth.
Detach the lens from the camera and hold it so that the lens' gold contacts are pointing down. Lightly "erase" their exposed surfaces and then clean them with the lens cloth to remove any debris.
Do the same with the gold contacts inside the camera body. Although this is a wee bit more challenging, you can do it by holding the camera so that the lens opening points down. That way no debris will fall inside as you clean. Joe
Nov 16, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 on EOS Canon 450D
This is what the people at the canon tech support say to do for error 99
read this!! :)
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked
hope this works for you!!!! have a nice day!! :) :)
Dec 04, 2009 | Canon EOS 450D Digital Camera
I have the same problem with err99
The lens contacts are oxidized or dirty. The contacts are used to communicate from the camera micorpocessor to the lens, etc.
Turn OFF camera.
Remove the lens
Using a pencil eraser, clean each contact on each lens and the camera body, taking care not to allow debris enter the camera.
Wipe contacts witha a soft cloth after "erasing".
This is an old trick from computer add-on cards.
See this discussion about the err99 error:
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
hope this works!
Sep 23, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon 20d - lens stuck / jammed
HI BRIAN ,,I AM SAGHA CAMERA REPAIRER,I THINK UR PROBLEM OCCURS DUE TO JAMMING OF PLASTIC MOUNT ON THE METAL BODY OF 20D.TRY THIS
1} LUBRICATE THE JUNCTION WHERE LENS GET ATTACHED TO THE BODY WITH KEROSENE THEN TRY TO RELEASE THE LENS.REMOVE THE BATTERY FROM CAMERA ,TRY AND HEAT UP THE JUNCTION WITH HAIR DRYER A LITTLEBIT THEN TRY TO RELEASE THE LENS.
2}IF THIS THING ALSO DOESN'T WORK THEN YOU HAVE TO SACRIFICE THE LENS PLASTIC MOUNT PUT SOME SHARP KNIFE LIKE OBJECT IN THE JUNCTION OF LENS & CAMERA & THEN PUSH IT UPWARDS WHICH WILL BREAK ONE OF THE PLASTIC LENS MOUNT COLLOR AND LENS WILL COME OUT WITHOUT DAMAGING YOUR CAMERA .LATER YOU CAN GET REPLACED THE LENS MOUNT FROM SERVICE PERSON. BUT NOW ATLEAST YOU CAN USE CAMERA WITH OTHER LENSES.
Sep 29, 2008 | Canon EOS-20D Digital Camera
CF error
My canon xti had the same reading cf card error 99.
Since my camera is out of warranty. I had to find a way to fix it. After reading all possible solutions in this site, I looked at the pins (that used to connect to the CF card) and found out that one pin in the middle bent. That caused the problem. I used the tiny screw driver to bend that pin back to the original position. Inserted the card back and it worked. I felt so happy!!!! (Please make sure to have the battery removed while fixing...to be saved.)
Dec 28, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Canon 20d error 99
does the camera work OK with other lens? If yes then Lens is the patient - only 4 moths old -send it back
Sep 12, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Err 99
This probably isn't it, but just to be sure... Make sure you have the latest firmware loaded. I was getting constant Err99's with my 10D and a new Lexar 40x card until I loaded the latest firmware, even though the firmware notes mentioned nothing about addressing CF card issues. Now everything is fine.
Sep 14, 2005 | Canon EOS-20D Digital Camera with 17-85mm...
Quantaray 100-300mm F4.5-6.7 Zoom Lens for Canon AF Logo
136 people viewed this question
Top Quantaray Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
teddyboy
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
