Question about Refrigerators
The temp is dowwn to -6 will not go any lower the top pof the freezer doese not get cold so ice maker ect not working the fan at the top tries to work but just flicks backward and forwards so I replaced the fan but its doing the same thing we have only had it 2 years just out of 2 year warranty!! help please
  • 10,515 Answers
Check to see that the freezer fan is running.
If your fridge has dual controls, be sure the freezer control has not been turned up too far.
Check the freezer section for signs of frost on the walls, particularly on the rear and floor panels. Frost would indicate a defrost failure.
Check the condenser coils in back for dust & debris and see that fan is running there.
Be sure that food items do not block air intakes in freezer. A stuffed freezer can create airflow problems.
Update me once checked all the above mentioned elements.
Thanks for using 'Fixya'.
Posted on Jun 28, 2009
Ice maker not working at all top part of freezer and fridge not cold
HI JAMES.well i would try to get them both working properly first.again defrost for 24 to 48 hours first and try.u might get lucky.ALI
Jun 30, 2013 | Amana 22.6 cu. ft. Side-By-Side...
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
The freezer is working just fine but the refrigerator is not cold at all
CHECK THE FREEZER FAN MAKE SURE ITS RUNNING AND IF THE BACK WALL OF THE FREEZER IS FROSTED UP YOU HAVE A DEFROST PROBLEM. I ONCE FOUND SOMETHING FELL BEHIND THE BASKET SO THE DOOR DIDNT SHUT ALL THE WAY, CHECK THIS AS WELL
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
Freezer and ice maker quit working / The temp.display on the door is just flashing .
There may be a fan that moves cold air in the freezer and icemaker compartment(s).  If the fan freezes up the cold air will not circulate.  Since the fridge compartment is still cold it does not sound like a compressor problem.
Jun 02, 2009 | Refrigerators
KENMORE COLD SPOT REFRIGATOR/FREEZER,MODEL 106 52542101,WILL NOT EJECT ICE (SIDE BY SIDE)
hi thanks for the question if the ice cubes are formed in the tray nicely then you need a new ice maker if the whole ice tray is a smooth sheet of ice the freezer might not be cold enough empty out the ice manually ant try again &lower the freezer temp thanke the appliance doc
Sep 17, 2008 | Refrigerators
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker doesn't work
I have the same problem. I've had the freezer for 2 years & ice maker just stopped making ice this week. Freezer works O.K.
Jan 11, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
