Question about D-Link AirPlus G DNS-G120 (DHDNSG120) Wireless Adapter
Checking the IP Address of my D-link Wireless Route
My router was working fine but, when trying to get a Berklin Wireless Range Extender to work with my network I changed something???? and now cannot log into my D-Link. How can I check for the IP address of the wireless router so I can check I am using the right IP address?
  • 208 Answers
Re: Checking the IP Address of my D-link Wireless Route
Plug it in hardwired then check the ip of the pc. the default gateway is the router.
start run cmd type ipconfig /all
if u hold reset button on back for 20 seconds it should reset defaults.
Posted on Nov 07, 2007
0 characters
3 Points
Comcast changed my wireless password and now my netgear extender doe not work
You will need to reconfigure your extender, check the manual or online at the link bellow.
Since your extender is not working your range is diminished.
WiFi Range Extenders
Oct 18, 2015 | NetGear Universal WiFi Range Extender...
I cannot connect my hg532 wifi range extender to my Echolife wn3000rp router
The HG532 is a broadband router, not wireless range extender.
So it will not connect up with another router.
You need to buy a range extender.
Apr 05, 2014 | NetGear Network & Wireless Adapters
Cannot connect NetGear WN3000RP with wireless
If you use a Netgear router to broadcast a WI-FI (Wireless Fidelity) signal in your home, you can easily double the range of your network by connecting a second router to one of the LAN (Local Access Network) ports located on the back of the Netgear router. You can use a Linksys, Belkin, D-Link or even a second Netgear router to extend the range. Any router that allows you to access the router settings to turn off the router's DHCP server is usable as a range extender.
Complete a master reset on the router you want to use as an extender. Typically, routers have a reset hole located on the back or side of the router. Push a metal push pin into the hole until the lights on the router flash. Often the settings on routers have been manipulated to enhance a network connection. Resetting the router ensures you can access all of the settings and not encounter any issues when making the connection. Plug an Ethernet cable into one of the router's LAN ports located on the back of the router. Plug the other end of the Ethernet cable into the Ethernet port located Enter the router's IP address into an Internet browser Web address field. If you do not know the default IP address, reference for a list of router IP addresses. Enter the default username and password for your router. If you do not know the default login information, reference Router for the default login information for your router brand. Access the DHCP server settings. Usually, this is located in the "Basic Setup" section of the router settings page. Turn off the DHCP server and then select "Update Settings." The location of the DHCP server can be located on a different page if the router is an uncommon brand. Access the "Wireless Setup" page and change the SSID to match the network name you use for your Netgear router. Select "Update Settings" to save the network name. This allows computers to move from the Netgear router to the router used as a range extender without requiring a second wireless profile being set up on the computer. The SSID could be located on a different page if the router is an uncommon brand. Access the "Wireless Security" page and update the router's password to match the password used on the Netgear router. If you do not secure your network, skip this step. The wireless password could be located on a different page if the router is an uncommon brand. Remove the Ethernet cable from the router and the computer. Plug one end of the cable into the WAN (Wide Area Network) port located on the back of the router you want to use as a range extender. Plug the other end of the cable into one of the LAN ports located on the back of the Netgear router. Hope this helps
Dec 05, 2012 | NetGear Universal WiFi Range Extender...
How to setup up for repeater mode
This particular Hawking device must be configured after it is connected to your LAN and powered up.
Before you can do this, you will need the software from Hawking. If your devices Serial Number begins with HEMCHWREN1 use the link below"
If you have a Revision 1 device with a Serial Number begins with HEMCREN1R1 use this link:
Once you have the software, here are the steps you need to follow:
  1. Connect the A/C power adapter to an
    electrical source, and then connect it to the
    'Power' socket of the Range Extender.
  2. Connect your Range Extender to a LAN
    port on the Router or AP that you would
    like to extend (repeat) the range on.
  3. Connect your PC to any of the LAN ports
    located on the back of your router/AP.
  4. Now run the appropriate program you obtained from the instructions in the beginning of the answer.
When the auto-load page appears, click the Setup Wizard option on the right and follow the Setup directions.
Scan for your Range Extender by clicking the 'Search' button. Once found, click the device to highlight it and click 'Next".
Choose a name for your Range Extender. You will use this name to identify and connect to your extended network. Optionally, you may change your login username and password. Click 'Next'.
At this point, the Setup Wizard should automatically obtain a new IP address for your Range Extender from the Router. Please wait for this IP to generate into the IP address field. Note the new IP address and click 'Next' to continue.
In the Search box, find the Wireless Network that you would like to extend. This Range Extender works best with other wireless-N networks, but also supports wireless-B and G networks as well. Select your preferred network and then click 'Next'.
For Security Settings, you must make sure that the Range Extender's security settings are identical to that of the Router/AP that is having the signal extended. If you do not know these settings please contact your network administrator.
At this point the Setup Summary displays all configured settings of the Range Extender. If the information displayed corresponds to your desired networks settings, you can go ahead and click 'SET' to apply the settings. The HWREN1 will automatically reboot. Please be patient.
More information can be obtained on the hawking site:
Sep 24, 2011 | Hawking Hawkin HiGain HWREN1 Wireless300N...
DHP-306AV and the DHP-W306AV To extend the range of signal, for the above 2 items I bought: 1. is DHP-306AV to be plugged on the wall electrical socket and connected to the router (in this case my study...
This can occur when the wireless adapter in the computer has trouble connecting to the wireless router. It may not get an IP address from the router or the wireless adapter encryption setting didn't get an the encryption authentication from the router.
In this case right click on the wireless adapter on the Task bar and click Repair. This will make the router re-issue an IP address and authenticate the adapter's encryption setting.
Feb 20, 2011 | D-Link DHP-W306AV PowerLine AV Wireless N...
When my wireless network is unsecured I can connect fine and browse the internet fine, but the moment I try to set up security I get a "limited or no connectivity" message from my wireless network. What's...
You must ensure that you have enabled the router as a DHCP server and the client PC network connection is set up to "obtain an IP address automatically". If the computer is not obtaining a valid IP address from the DHCP server (i.e. the router) you will get the limited or no connectivity error. You can easily check to see if you have a good IP address by opening a CMD prompt window and running ipconfig.exe. Generally, the WBR-1310 will have assigned an IP address like If you have an IP address like you router is not assigning your computer a valid IP address. Powering down the PC and/or the router will usually fix this, but not always. There are other, more compliated, steps that can resolve the problem if the above steps do not work.
Oct 10, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I purchased a wre54g range expander and have tried everything but it doesnt work
Who is the manufacturer of your wireless router?
check the IP address of your router.
connect the computer to the router and check the Ip address of the computer and the default gateway number. Default gateway is the IP address of your router. suppose the default gateway is then open the set up page of the router . check the wireless settings of the router SSID ,channel and the security settings. Do not change the settings on the router.
If you are using WPA2 security settings them that will network on the WRE54G.
Now your range expander and the router IP addresses should be in the same range. Suppose you router IP address is 192.168.x.y and the IP address of the WRE54G is by default
Now the x in the router IP address should be 1.
If it is, then connect the WRE to the router and open the set up page of WRE. change the wireless settigns on the WRE and power cycle the WRE and the router.
It should work
For more info about networking Click Here
Oct 06, 2009 | Linksys : WRE54G Wireless Range Extender...
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side:
DHCP on: range to .20
DNS Servers:,
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address:
Gateway address:
DNS Servers:,
Aug 03, 2009 | Network & Wireless Adapters
I can not remember the IP address for WGX102 Range Extender
run ipconfig/all on a PC connected to the router. The default gateway usually is the router's IP.
Jul 09, 2009 | NetGear WGXB102 Wireless Range Extender...
I need to boost the sending signal from my D-Link wireless router so my secondary computer can access the net - presently the router works for one extra computer but keeps losing the signal intermittently...
goto start - run - .cmd - enter..type`ll get ip address,subnet mask,default gateway.copy it.goto start- control panel - network connections now right click wireless network connection and click on properties and double click on internet protocol(TCP/IP) or if you are using vista goto network and sharing center - view status - properties - double click on IPv4.type in the IP address,subnet mask,default DNS server address type the default gateway in primary DNS and in secondary your connection won`t drop after this.
this will fix your problem...
Jun 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
D-Link AirPlus G DNS-G120 (DHDNSG120) Wireless Adapter Logo
558 people viewed this question
Top D-Link Network & Wireless Adapters Experts
Mike McWhinney
Cosma Papouis
Cosma Papouis
Are you a D-Link Network and Wireless Adapter Expert? Answer questions, earn points and help others
