Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Ice is forming on my "not working" ice maker drawer
Ice is collecting around the ice maker drawer causing a little difficulty opening the freezer door. I have a side by side refrigerator freezer. What could be the problem.
  • 27 Answers
Check that the water isn't over filling the ice mould or that water isn't escapeing down the back of the draw due to an allignment issue with the filler tube. worst case could possibly be a cracked ice mould.
Posted on Jun 28, 2009
There is water freezing under the bottom mount drawer. The ice is so thick that water is leaking out the front onto the floor. There is no information in the manual about troubleshooting this problem
Try to have it fixed under warranty.
If that does not work, here is what is usually wrong.
(I maintain a dozen of these and see this all too often.)
One day, the freezer drawer might have been left open, even for a short time.
I mean, not closed tight.
This causes warm air to enter the freezer, and then ice forms where the warm air met the cold air.
The ice forms in and around the gasket, which then keeps the door from closing tightly, which then causes more ice to form, etc.
After a good defrosting , and cleaning, (especially the gasket), see if a fresh start has fixed this.
If it happens again, you might need a new drawer gasket.
God bless your efforts.
Feb 27, 2018 | Televison & Video
Sub Zero 700 TC with two freezer drawers on bottom. Ice sheet is forming on the bottom below the drawers and causing the drawer to stick. I have defrosted the freezer with a hair dryer and thought this...
How are the ice cubes? Are they normal size or hollow? I was wondering if some of the water was not making it into the ice maker and causing this issue. Is there any frosting issue not mentioned? Any water droplets on or around the back wall of the unit (inside)? I am a service tech certified and would like to know more about this issue. Have you cleared the drain completely, meaning after you de-iced unit, did you use water to verify the drain was cleared?
I you like to know more, so I can direct you in solving this issue.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 22, 2013 | Sub-Zero 700TC Bottom Freezer Refrigerator
Ice is forming under the freezer drawer what causes this
Clean your coils. Then defrost ice build up with a hair dryer. Good luck!
Apr 12, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
My Whirpool Bottom Freezer Refrigerator keeps collecting ice at the bottom of the freezer and eventually, every couple of weeks, leaks onto the floor. It does have an ice maker which is not hooked up. We...
The defrosting heating element may have burnt out. Also if the gasket around the door/drawer isn't sealing correctly moisture from the air leaking in could be condensing inside and then freezing causing the build up.
Please rate my response.
Jan 14, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
Aug 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
MODEL # 59673504203 DRAWER IS ALWAYS FREEZING EVERYTHING IN IT. NOW NO ICE IS BEING PRODUCED
I had the same problem. I pulled the drawer all the way out. In the back is a vent flap. Ice had formed on it keeping it open. I chipped off the ice so the flap can move. This stopped the freezing veggies.
My ice maker stopped working. It was suggested I change the water filter as it may be clogged preventing water moving to the ice maker. As I am getting a new refrigerator I all not be buying a new filter.
This message is little late for the original poster but may help someone else.
Aug 04, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Ice is forming around the ice maker where the ice dispenses through the opening in the door. I have taken out the ice drawer and washed it so that there is no more ice. I have also eliminated the ice...
Check and make sure that the flap that lets the ice out is shutting properly. When warm air enters the freezer door, it condensates then water freezes forming your ice. If this is your problem, they make a kit that replaces it. Good luck...
Nov 17, 2009 | Refrigerators
Why is water forming under the veggie drawers
One of two things caused this problem, either the drain in the freezer is clogged and spilling over to the air duct and through to the refrigerator, down the back wall and then puddling up under the drawers or the Styrofoam between the freezer and refrigerator is saturated with water. If you remove the inner back wall of the freezer and there is ice built up, defrost it with hot water and a turkey baster, push some heavy weed trimmer line down the drain tube and they should clear the clog. If there is no ice build up, then you probably have the latter of the two problems, the only solution is to empty the unit, turn it off, and let it dry out for a few days with the doors opened. If the problem continues, then there is a significant breakdown of the Styrofoam between the two cavities and there isn't a solution, it is time to purchase a new unit.
Jun 16, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
127 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
