Question about Toshiba 53H71 53 in. Rear Projection Television
Toshiba back projetion TV convergence problem
The TV operates normally and then suddenly the convergence will jump way out of position. Switching the TV off and on again only clears the problem if switched off for a long period. The problem was happening on a monthly basis but is now daily.
    Scholar:
  • 30 Answers
You probably have a convergence IC going bad. This is a very common problem. They run hot and wear out over time.
Posted on Mar 02, 2010
My Toshiba TV was on like normal, then suddenly the green color seperated from the red and blue.. On the bottom left corner you can see the green is 4 inches up while the others stay at the bottom. So if...
Ur tv have a problems known as a convergence pictures problems,it is dead.Ur tv have any colors lines like R,B,G mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than ur tv have a dead convergence board to causes the tv to have all of these pictures problems.The tv convergence board must have be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 20, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Projetion tv showing double picture
you eed replace the convergence kit, (2) stk-392-560 ,and the picofuse 5 amp in your pwr.s.
Jan 14, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence issue-60 inch RCA projetion TV
it is under set up options in the menu
Oct 16, 2009 | Televison & Video
Service Manual for a Toshiba 57H82
i hook up the cable for cable tv to my tv but it only works in the pip and when i try to change it to the full screen all i get is snow .and it wont show the picture at all untuill i change it back to the pip
Jul 10, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba TN55X Convergence problem.
You brought up an issue that we hadn't considered. Shortly after hooking up our TV to the receiver with a composite video, our convergence which wacko. My hubby replaced the 2 ICs, but now our power button just flashes red, with no picture. Not sure if new ICs are faulty or if it's another issue. He will replace old ICs to see if problem still exists with turning on the tube. And he'll try disconnecting the video signal to see if problem exists.
Ouch.. may have to consider another tv thanks to new technology ??????
Good luck solving your problem.
Jul 06, 2008 | Toshiba TN55X81 55" Rear Projection...
Toshiba 61H70 Weird Convergence Issue?
They may have gotten some cheap convergence ICs, thats a real possibility. I would recommend switching the two origional STK392-110 with some STK392-150 they will run alot cooler and last alot longer. Just use a good coating of heat sink compound on the back of the ICs. I will post a link where you can get top quality Convergence ICs and they provide free instalation instructions with pictures so you can do the job yourself in under an hour and save quite a bit of money. Heres the link.
http://servicemanuals.vstore.ca/
May 22, 2008 | Toshiba 61H70 61" Rear Projection...
I Have a Hitachi Ultravision projetion TV Ned help to fix it.
This sounds like the solder joints on one of the convergence output IC's have cracked loose or the IC itself is defective and quitting when it warms up. The IC needs to be either resoldered or replaced.
May 15, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Nov 30, 2006 | Hitachi 50UX57B 50" Rear Projection...
Toshiba 53H71 53 in. Rear Projection Television Logo
89 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
