Question about Epson Stylus Pro 4000 InkJet Printer
Epson Pro 4000 not used for 3 months & nozzles are apparently plugged. Tried nozzle cleaning routine several times to no avail. I do not have a shiiping container to return the printer Epson for repair. Any ideas?
  • 413 Answers
More likely the ink cartridges have dried up.
Take them out and see if there is any ink in them...
Posted on Jun 28, 2009
Magenta won't print at all on test page. Tried normal cleaning cycle several times to no avail. Also tried "power purge" cleaning cycle twice also with no success. Help!
The magenta print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 20, 2013 | Brother MFC 6490CW InkJet Printer
Maintenance request error code 4000 for Epson stylist pro 4900
HI,
MAINTENANCE REQ - 4000 - It detects twice in a row that all the nozzles are clogging.
Check the video to know how to clean the nozzle to get ride of error 4000
How to clear nozzle clog on your Epson wide format printer from PRO...
www.electro-medical.blogspot.com
Mar 04, 2013 | Epson Office Equipment & Supplies
Black only text won't print
Mar 04, 2013 | Epson Stylus Pro 4000 InkJet Printer
Epson stylus pro 4000 i have a clogged nozzle cant move it other 7 are fine
Inkjet printers needto be used frequently to prevent ink drying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, thenprint head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jul 03, 2011 | Epson Stylus Pro 4000 InkJet Printer
How to remove and clean epson stylus pro 7000 printer head its cloged
Welcome to FixYa!
If you have not used your printer for a long time, the print head nozzles may be clogged. Perform a nozzle check and clean the print heads.
Use the Epson Printer Utilities to do a nozzle check and to clean the printer head.
Reference Manual of Epson Stylus Pro 7500 InkJet Printer:
http://files.support.epson.com/htmldocs/pro75_/pro75_u1/INDEX.HTM
Comments and rates are appreaciated.
Thanks for using FixYa.
Jas
Feb 23, 2011 | Epson Stylus Pro 7500 InkJet Printer
Cartridge problems Epson 4000
Where are you located? is it Humid? possibly the chips on the cartriges have something on them (corrosinon, oil from a finger touching the chip, etc) that is interferring with good contact with the wire "feelers" inside the machine. clean the chip with Qtip and alcohol, or fine fiberglasss bristle battery contaact cleaner (hard to find these days)
May 13, 2009 | Epson Stylus Pro 4000 InkJet Printer
Not printing magenta ink and tried cleaning heads already
Hi, one or two head cleans won't clear a clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning".
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Hope this helps.
Please take a moment to rate this solution, thanks.
Mar 28, 2009 | Epson Stylus CX6600 All-In-One InkJet...
I have an Epson 4000 which has a clogged nozzle
I have an Epson 4000 which I started using new in Sept 2004 and my magenta is clogged too. I've gone through 2 maintenance tanks trying to clear it, (and LOTS of ink), but the magenta is still blocked. I even tried this: http://www.youtube.com/watch?v=3NR8g4qUAJc trick but it didn't seem to work. I hope you have better luck.
Feb 23, 2009 | Epson Stylus Pro 4000-PS InkJet Printer
Epson 9600 suddendly stopped printing yellow
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
Oct 10, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 4000 InkJet Printer Logo
217 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
