Question about Leapster Learning System
How do you get Leapster 2 to work step by step after callibrating?>
Gt 5230 touchscreen not working
go to settings phone setting and touch callibration every month we will do callibration ur touch will work perfactly
Oct 23, 2011 | Nokia 5230 Cell Phone
How do you calibrate the leapster learning game system?
  • Follow these steps to calibrate your Leapster Learning Game system -
  1. Remove any game and turn the Leapster off.
  2. Turn the unit on.
  3. When the sign in screen appears immediately press and hold down "home"(house), "hint"(question mark), and "B" buttons together for 4 seconds.
  4. Now you will see a few options.
  5. Press the "A" button for the touch calibration option.
  6. Now just touch the stylus on the cross-hairs and it will be calibrated.
  7. Now you want to restart the unit.
  8. Redo the steps if this should not work the first time.
Regards, Tony
May 19, 2011 | Toys
The pen has stopped working when touching the screen
If your Leapster 2 will turn on, but the touch screen is not responding to the stylus, try re-calibrating the stylus with the screen using the steps below: 1. Turn your Leapster 2 off, and remove the game cartridge.
2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
4. The screen should be displaying the calibration screen. You can release the 'hint' button now.
5. Press the 'A' button on the right to enter the calibration screen.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.
8. Your stylus and touch screen should now be working, enabling you to sign in as usual.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Leapster 2 Handheld Game
How do you turn it on.
HI, try these steps...
  • 1
  • Change the batteries. Sometimes this seems like a simple and obvious step, but is often overlooked. The Leapster console runs off of four AA batteries.
  • 2
    Hold the power button on the Leapster console. If you still do not see a display on the screen with a fresh set of batteries, then you got one of the bad consoles. This was a bad batch of consoles that were sent out by Leapster.
  • 3
    Contact Leapster customer support. They should be able to replace your Leapster learning system free of charge. With all of your information ready, it should be quick and easy to get a replacement console.
  • Feb 20, 2011 | Leapster 2
    We have a Leapster 2 which the screen no longer registers when touched by the pen. Can this be fixed or replaced? i bought it only 2 months ago hope you can help Emma
    I posted a solution to this problem a couple months ago. We have the Cars edition of the Leapster2. I'm guessing it was the same problem that we were having. When the pen touched the screen there was no response and the unit had barely been used. Try this!! I found it on www.ehow.com.
    Callibration
  • If you touch your stylus pen to the screen of your Leapster2 and it does not respond, your unit needs to be calibrated. To do this, make sure no game cartridge is in the unit. Turn the unit on while you are holding down the "Hint" or "?" button. Keep holding the button down until the Leapster2 menu appears. You will need to turn off the unit and repeat these steps if you do not see the menu. When the menu comes onto the screen, press the "A" button and use the stylus pen to touch each of the crosshairs as they appear. When you are done, your unit should be properly calibrated.
    Read more: Best Way - Leapster 2 Troubleshooting ' eHow.com http://www.ehow.com/way_5868621_leapster-troubleshooting.html#ixzz0wVJdZzs5
  • Feb 02, 2011 | Leapster Learning System
    Leapster 2 screen not working
    Hi
    This is a common problem for Leapster. The company has a repair program. Charges depend on warranty.
    May 11, 2010 | Leapster Learning System
    Sound is cracking
    If you cannot return it at the store, then call up Leapster and you can send it to them and they'll send you a new or refurbished one. I was told this a few years ago anyway. I reached someone out of the US. It wasn't easy communicating with the gal, so I was leary on following their steps, but with a name like Leapster, they do back their products.
    May 30, 2009 | LeapFrog Leapster 2 Learning System
    Leapster 2 broken screen
    We had a similar problem leapster turned on but would not let us chose a name for sign in. We held down the ? button when switching on then wen tthrough the stylus calibration and re-bootted. All started working again. Hope this helps
    Jan 10, 2009 | LeapFrog Leapster Electronic Book:...
    Leapster with broken pen
    My daughter did the same thing to the tip of her Leapster 2 stylus. I called Leap Frog at 1-800-701-5327 and was able to order a replacement stylus directly from them on credit card for $5.00 shipped.
    I also took her old stylus and sanded the broken tip down with 100 grit and then 220 grit sandpaper to get rid of the sharp, cracked point and it works just fine. I figure I'll keep the sanded one as a spare in case she does something silly with it again.
    Jul 27, 2008 | LeapFrog Leapster Electronic Book:...
    Leapster LMAX touch screen calibration not working on center dot.. games not being able to read
    I just bought the "new" leapster 2 and it loads but it doesn't do anything when touching the screen with the pen.... It asked me to choose my coutry which i did .. took 10 mins then it picked the wrong country.. now i am stuck at putting in my son's name.. again won't do anything..
    Jun 07, 2008 | Video Game Consoles & Games
    Leapster Learning System Logo
    53 people viewed this question
    Top Leapster Toys Experts
    James Hensley
    James Hensley
    Dennis Crouse
    JessicaChane2345
    Are you a Leapster Toy Expert? Answer questions, earn points and help others
