Question about Norelco Advantage 6705 X Electric Shaver
Norelco Shaver Won't Turn Off
This one was new, out of the box. It worked for two days and then wouldn't shut off after using. I took it apart. I pushed on the switch directly and it still wouldn't turn off. You can't pull the batteries without cutting something. It's a piece of Junk.
SOURCE: How to replace battery pack for a Norelco 6885xl electric shaver
The battery pack is soldered to the shaver's circuit board. Yes, it's a poor design in building something that people can't readily service unless they have a soldering gun, ******, and wick, plus patience. However, there are plenty complaints online already, and my shaver won't get fixed by b-tching some more.
There are 2 choices for replacement:
1. Bring or mail it to a service center to have the batteries replaced. The fee usually runs $29.99-$39.99, which includes the battery, parts, labor, lubrating your motor, cleaning the interior, cleaning/stripping the cutters, heads, and trimmer, plus return shipping.
2. To save yourself $26-33 bucks, make sure you know how to solder and have the equipment described above. you can find single NiCad AA with solder tab for $3ea or a pair for about $7.95+. Table the batteries together, solder a single tab across +/- on one side, and solder the others onto their respective tabs in your shaver.
For me, I'd love nothing than to hobby around and do it myself, but with 3 kids, a full-time, job, Wii, and other hobbies, it's easiest to just send it out... some services will guarantee to have it done within 2 days of receipt. You'll just have a lil beard to test it out when you get it back. :-)
Posted on Oct 16, 2008
  • 91 Answers
SOURCE: replacing batteries in a 6705x norelco shaver
To open up your shaver, remove the lotion cover and remove all 5 screws with a small flat head screwdriver. They have a star head, but also a flat notch. Since they shaver is water tight, the first time you open it up it will be difficult, but if you pry off with your screwdriver it should pop off.
Towards the head of the shaver the batteries are soldered to the circuit board. Pull the tail end of the batteries out of the plastic holder and cut them at the top end as close to the batteries as you can, or CAREFULLY bend it back and forth to snap the metal. Dispose of the batteries responsibly as you would any batteries.
Hope it helps you.
Posted on Jan 07, 2009
SOURCE: Norelco shaver service centre in India
i am based at hyderabad india and wish to get my norelco shavers modelno4852XL and 7864 repaired is there any sevice centre in hyderabad andhrapradesh india
please email me on krvr0506@aol.in
Posted on Apr 18, 2009
  • 3 Answers
SOURCE: Replacing Heads for 8140XL Norelco shaver
Same thing happened to my father's shaver. After working on it for about 30 mins, this is how I fixed it. You need to start with the top silver piece/cover. Turn it over so you see inside of it. Drop the 3 screens into the holes upside down (so they face out). You need to rotate the screens until they sit as low as possible. Now drop in the 3 blades, again sharp side down. There should be a triangular piece with 3 circles attached to it. One side is gray, and the other side has a black triangular piece. If you look closely each leg of the black piece has a tiny picture of a lock and an arrow. Rotate the black piece in the opposite direction of the arrow. Place the gray side down lining it up with the three blades. Now rotate the black piece, it will lock into position, and hold the blades in place! Finally, the silver head has a little hinge on one side. This hinge is flexiable. Bend it to a 90 degree angle, and slip it into the notch on the top part of the main body of the shaver. Close the head part, in my father's shaver I had to press a lever in the front to snap it into place.
Hope this helps!
Posted on May 13, 2009
brector3
  • 1625 Answers
SOURCE: Replace battery
It is a #8 torx screwdriver. if needed, you can purchase one from shaveroutlet.com. See link below
http://shaveroutlet.com/screwdriver-access-tool-for-norelco-shavers-and-some-braun-p-262.html
Posted on Mar 01, 2010
Diagram for norelco 3605x Took apart to replace battery and red plastic item fell out and I do not know where it goes Help please.
The red piece is the voltage switch. It allows you to use your shaver to be used with 120V or 220V by moving it into the corresponding position.
This piece fits in at the bottom of the shaver with the notch showing out of the tiny 'window' at the bottom. The metal prongs will situated so that they make contact with the circuit board.
ShaverOutlet com The Ultimate Shaver Source
Mar 19, 2016 | Norelco Health & Beauty
Norelco 8140xl new blades doesnt shave
Did you use part HQ9 for your replacements? Norelco makes many different replacement heads and only one type is correct. The correct type for model 8140XL can be found at shaveroutlet.com below
http://shaveroutlet.com/norelco-philips-hq9-replacement-heads-p-252.html
Feb 02, 2014 | Norelco 8140XL Electric Shaver
My batteries were holding a diminished charge, but i usually used razor with a cord, usually left plugged in. green charging light was always on. one day i unplugged cord for a day or two. when i plugged...
It is advised that you change the batteries when you realize that they are no longer charging properly. Most likely, only the batteries need to be changed but it is possible that you have caused further damage due to leaving it plugged in continuously and the batteries may hae become corroded or leaked.
If you decide to attempt to change the batteries, you will fin the correct type at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
You will find helpful videos on the item page to assist you in installation
Sep 24, 2011 | Norelco ReflexPlus 6863 XL Electric Shaver
Norelco 4805 xl razor won't turn on when plugged in nor will the battery charge. i would think it was the battery but it does't want to turn on when plugged in either. is the motor shot? thanks
When the battery goes completely bad, the shaver will not work even from the cord.
You will need to open the shaver and make sure that the batteries have not corroded badly and damaged the inside of the shaver.
You will find the correct replacement battery offered at shaveroutlet.com. See link below
You will also find a video tutorial on this page to halp show you how to open the shaver. See link below for another video with additional installation tips
http://www.shaveroutlet.com/shaver_battery_replacement
Jun 10, 2011 | Norelco Micro Action Shaver 4805XL...
I have a Norelco 4845 XL rechargeable razor that has not been used for about 8-10years. I took it apart and the batteries seem to be coroded around the terminals. What can I use to clean the terminals...
It would not be a good idea to try to use the shaver with those batteries...even if you cleaned them. If you intend to use the shaver, you should replace the batteries. You will find correct batteries at shaversource.com
http://shaversource.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Scroll down the page for tutorial videos on replacing the batteries
May 31, 2011 | Norelco Micro 4845 XL
I am looking for a repair manual for a Norelco Reflex Plus 6853 XL shaver. I took it apart to clean the motor as it was sticking and I want to make sure that I get everything back in its proper place....
Philips cliams that the Norelco shavers shouldn't be opened. If you have any problem with your shaver you should visit your nearest Norelco service center. You can contact Philips support to get details for your nearest service center.
FYI, I've provided a link to download the manual for 6853XL . Hope this helps.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jan 19, 2011 | Norelco ReflexPlus 6853 XL Electric Shaver
I have a Philips Norelco 7310XL razor and I have a problem. I recently moved, and in the process, something happened, and my razor isn't working. When I turn the razor on, the blades turn slightly and then...
It sounds like maybe one of the blades is damaged and it is jamming the whole thing. Try taking apart the head assembly and then insert each head one by one turning the shaver on in between each one. This should identify if one is damaged and causing the problem
If you require new heads, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Sep 18, 2010 | Philips Norelco 7310XL Electric Shaver
After soldering new batteries my shaver´s on-off switch won´t wor
it sounds like you may have some sloppy solder which is causing a continuous connection here there shouldnt be
Dec 24, 2009 | Norelco Rechargeable Cordless Men's Razor...
Norelco Advantage 6705 X Electric Shaver Logo
864 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
