No crank? Do you have access to jumper cables? Try connecting your car to another car with a fully charged battery. Look up proper procedure with google. If it starts, try charging the battery. Let us know what happens.
Are you sure the battery is correctly charged? Most USB connectors on most PC's don't deliver enough power to charge the battery. Try to charge the battery with the power cord till the green LED is on. If you'r sure the battery is fully charged and the same happens again, remove the battery for a small time and put it in again.
A charging battery's light is red. If it turns green then it means it is fully charged. Since you had stored your battery for a while, try to charge it by using a battery charger to kickstart it. It should work. Whatever transpires let me know. thanks and rate this answer.
check out if the battery is fully charged.and even if the battery is very old it does not get charged completely so replace the battery and checkout it should work.
