Question about Gaggia Syncrony Espresso Machine
Bits in my coffee
I've had my Gaggia Espresso machine since Christmas and up until recently it's been working with no problems. However, now when i make espressos i get bits floating in the crema that make it dark brown. It's almost as if the filter isn't working or the coffee is ground too fine but i use pre-ground coffee. Hope you can help. Thanks
  • 1,089 Answers
Hi
If you are using pre-ground and you have ground it for espresso, that too fine and that is why you are getting specks. It should be ground to the size of sugar granules.
Posted on Jun 28, 2009
Gaggia titanium coffee slow coming out of machine
Not sure it will work for you but Our Bunn has a flex wire to run thru the tube weekly , and if we do not clean that tube it might take 20 minutes to make a pot where when cleaned it does 12 cups in 3 minute
Nov 26, 2015 | Gaggia Titanium Espresso Machine
Gaggia Titanium: stuck on 'rinse'.
Try first unplugging power cable for five minutes, see if this reset machine.
Aug 20, 2008 | Gaggia Titanium Espresso Machine
Gaggia titanium
A nice coffee maker. So, please could you tell us what is your question?
Maybe some operating instruccions?
Check support library:
Or do you want to repair something?
Gaggia TITANIUM Espresso Machine Operating Instructions Manual
GAGGIA
Gaggia Titanium Super Automatic Espresso Machine
Cleaning Gaggia Titanium Espresso Machine Gaggia Titanium Steam Valve Replacement
Aug 03, 2015 | Gaggia Titanium Espresso Machine
Does the gaggia titanium have a grinder sensor? Can anybody tell me where it is? I have the "grinder blocked" message. I've cleaned the grinder, Shute and doser door, but I still have the...
Hi...Grinder blocked message is ..when you make coffee there is no current going into the grinder. In other words the grinder motor is blown(coil windings in the motor is blown). You have to replace the motor. The problem is common with Gaggia, Talea, Odea coffee machines. hope your machine is less than 2 years old to get fix under warranty.
Apr 10, 2012 | Gaggia Titanium Espresso Machine
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
My Gaggia Paros does not grind fine enough. Is there a way to improve the adjustment beyond the standard range?
I have mine on the finest grind. Then changed coffees until I found one that works. I use Indian Tiger Mountain. Works really well.
Feb 06, 2010 | Gaggia Paros Espresso Machine
Have a Gaggia Cyncrony Compact Coffe Machine that doesn't brew!
Has the machine been de-scaled recently? I would run a descaling solution through the machine first to eliminate that.
Jan 15, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Titanium only buttons that are working are the large coffee and the menu button?? Nothing else does anything....no hot water, no espresso therefore no up and down arrows for the menu button!!! I...
Had exact same problem (same two buttons worked). One of two button connection ribbons (wires) had disconnected inside the electronic box in machine. Simple was is to remove the top, open electronic box, reconnect grey ribbon (back left for me), and electronic tape onto connectors. Just did this, all worked for me.
Dec 08, 2009 | Gaggia Titanium Espresso Machine
Gaggia coffee
Do you prime the machine when you connect it to power?
Feb 01, 2008 | Gaggia Coffee In White, White MDF...
Gaggia Syncrony Espresso Machine Logo
81 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
