Question about HP Pavilion dv1000 Notebook
HP DV 1000 Loose Hinges?
I'm looking for a way to tighten or if I have to replace the loose hinges on my DV 1000 myself. I can take the covers off to get to them myself and have all ready tightened the screws that they mount to the case and can find the part #'s myself needed if they have no adjustment and need to be replaced. I would like a better idea though if they can be adjusted or how to replace them if needed. If they can be adjusted/tightened it must be some trick way to do it since to me they look like they are not serviceable.
  • joefoefrombu Jun 28, 2009
    Thank you for the info and reply. That's what I thought. Now I hope some one has a good step by step like this website that has a video on how to open the top half of a DV 1000
    http://tinyurl.com/ldeyra
  • HP Master
  • 32,281 Answers
I have replaced hinges on HPs and other laptops. I have found laptop hinges have no adjustments and have to be replaced.
Posted on Jun 28, 2009
  • Chris Hingee
    Chris Hingee Jun 28, 2009
    The HP and Compaq laptops are relative easy to disassemble to get at the hinges.
    There are screws that fix the hinge on the back edge of the laptop and also sometimes under the plastic strip panel between the top of the keyboard and the bottom of the LCD screen. This strip panel is usually secured by screws on the bottom and possibly screws on the back edge of the laptop.
    This panel will also be held in place by plastic clips and require gentle levering up to remove the panel, the panel also covers the hinges. The LCD panel would need to be foldered/pushed back till it lays flat before you can remove this panel.
    Before you remove the last screws securing the LCD screen, there is a video connector and possibly a cable to the inverter, detach these before you remove the last screws holding the hinge to the bottom half of the laptop case.
    After you remove the LCD screen/lid, to get to the hinge in the lid, there are small plastic covers that hide the screws that secure the bezel to the lid. After the screws are removed the bezel will still secured in place with plastic clips and sometimes with double sided tape. You need to slip a thin blade between the bezel and the LCD screen and GENTLY lift it off the lid. Be careful not to scratch the LCD screen. I suggest you start at the bottom edge of the screen and gradually work your way around the other edges of the bezel.
    After the bezel is removed you can see the hinges and how it is attached to the LCD screen and lid. Be careful when you remove the hinges that you don't twist the LCD screen as it is fragile and when cracked it is destroyed.
    Good luch & have fun.
Loose hinges how do I tighten them
Watch the video it shows which screw hold the hinges to computer itself and to the screens back cover. HP DV7 LCD Screen Replacement
Mar 09, 2015 | HP Pavilion dv7-1130us laptop
How to tighten loose display hinges on toshiba pro a10
There ares no adjustments to tighten the hinges, they need to be replaced.
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site.
http://www.insidemylaptop.com/replace-br...
Jul 20, 2012 | Toshiba Satellite Computers & Internet
Loose display hinges
There is no adjustments to tighten the hinges, they need to be replaced.
Jul 20, 2012 | Toshiba Satellite Pro A10 Notebook
Loose hing on Gateway c140xl
Faulty hinges cannot be adjusted or tightened. If the the mounting screws are loose then these can be tightened.
These WEB site hace detailed instructions on replacing faulty hinges.
Hinges for Gateway laptops on the 'net,
http://www.laptoprepairco.com/Search/hinges/hinges.asp
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Feb 16, 2012 | Gateway Computers & Internet
Case loose round hinges
If the screws securing the hinges to the base of the laptop is loose then tighten these screws.
Hinges have no tightening adjustments and loose/faulty hinges need to be replaced.
These WEB sites can assist you to replace these hinges.
Feb 15, 2012 | Packard Bell Computers & Internet
Loose Screen on Dell Inspron 1525
If the hinges are loose, it is not possible to tighten them, the hinges need to be replaced.
For details on replacing hinges, please click on these WEB sites :-
and these WEB sites for parts :-
LAPTOP PARTS www.laptoprepairco.com/
www.laptopparts.com.au/
www.laptopking.com/
www.lappy.com.au/
www.excelcomputerinc.com/
www.laptoprepairparts.com/
www.lapzone.com/servlet/StoreFront
www.laptoppartsexpert.com/
www.sparepartswarehouse.com/
Sep 09, 2010 | Dell Inspiron 1525 Notebook
How do i tighten my screen on dv 1000 it is too loose with too much play
Hinges on laptops cannot be tighten, they need to be replaced.
For parts and details how to replace hinges please click on these WEB sites :-
Replacing Display hinges http://www.laptopparts101.com/display-screen-hinges/
Mar 11, 2010 | HP Pavilion dv1000 Notebook
Laptop hinges are loose
The hinges can be loose in two different areas, but the most popular is the hinge attachment point behind the screen bezel. Remove the rubber screw covers from the bezel, remove the screws, take your finger nailas and from the inside of the bezel pull gently to the outside to release the catches on the screen lid. Start on one side and work your way around the screen until the bezel pops loose. Look at the bottom of the screen and you will see the hinge attachment points. Tighten them up. If you have some locktite this would be a good time to apply it, remove the screws one at a time and replace. To replace the bezel, always start at the bottom and work your way up.
Jan 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
Screen falls back
Loose hinges or bad hinges. You can pop off the hinge cover (above the keyboard) and 'try' to tighten the hinges, but if that doesn't work, it's failing hinges and the only fix is to get them replaced mate.
Hope this hellps, be sure to rate!! :)
Jan 03, 2009 | Dell Latitude C610 Notebook
HP Pavilion dv1000 Notebook Logo
702 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
