SOURCE: how do i take off
Rand is working on this. A new version may be available soon that addresses this issue.
Thanks,
Mark
SOURCE: Droped my new rand mcnally gps and cracked the
You can replace a cracked GPS
screen, but you can't repair it. If your GPS is under warranty, you can
contact the manufacturer directly about sending the unit back to have
the screen replaced. If the device is not under warranty, you can still
contact the manufacturer about replacing the screen. The company will
charge a fee to replace your GPS screen if you don't have a warranty
that covers that type of repair. You can also replace the GPS screen
yourself, but be aware that replacing your GPS screen can void your
warranty.
Instructions
Things You'll Need
http://store.randmcnally.com/?SCCampaign=cjaff&gclid=CPe2iu2B36oCFVAaQgodIwM58g
HERE IS THE LINK BELOW TO COPY AND PASTE AND PUT IN YOUR BROWSER AND THIS IS YOUR OPTIONS, CAN CONTACT THEM AND SEND IT IN AND THEY CAN REPLACE IT FOR YOU, OR CONTACT THEM AND HAVE THEM SEND YOU OUT THE PART AND REPLACE YOURSELF, BASED ON INSTRUCTIONS I LISTED ABOVE.
MY ADVICE IS : Sense your unit is expensive and new, it is worth having them fix it or fix yourself. I hope hope this helped you, and on the good size you for sure have a good unit. Thanks Mike , your fixya Expert.
SOURCE: rand mcnally tnd 710 not turn on
If it is more than a few years old then the battery is a real possibility as the problem.
SOURCE: How to open Rand McNally gps?
Did you ever get your 710 open? I am on my second one, and the USB connector is starting to cause issues again. I think this is definately the achilles heel of this unit. I am considering adding a different power connector and changing the adapters so I don't have to use the USB port when it is in the truck.
