Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
There is no Audio from my computer. In General Tab of Audio Codec Properties, a message is like this "No Audio Device Found". What is the solution?
  • 672 Answers
You may need to re-install your audio drivers. this link to intel will help with that. Manual and drivers are available here. http://www.intel.com/support/motherboards/desktop/chipline.htm
Posted on Jun 28, 2009
I have a xp3 they does not support a multimedia
Posted on Jun 29, 2009
Audio service
Go to the device manager of your computer. You can open the device manager in the following ways:
Start - Control Panel - System and Security - Device Manager
or
Start - Accessories - Command Prompt - devmgmt.msc
You will have the device manager in front of you, check for the sound or audio controller. Go for the sound or audio codec or device and right click for the properties and then click on the tab saying driver and check whether the same is disabled or enabled.
** You can also avail our technical support by visiting our website: http://www.vtechsquad.com.
May 01, 2013 | Computers & Internet
Audio device not installed
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Feb 03, 2013 | Microsoft Windows 7 Ultimate 32bit
Audio problem
Open device manager by right clicking on My Computer and check if the audio driver is working properly. Right click on audio driver - Properties - under general tab you will find a option " Device usage " - check whether it is " Use this device (enable) - selected. Go to Driver tab and click on update driver option. Check cables and speaker's connection. Open Control Panel - Sound and Audio Devices, here check for the options if they are muted.
If you still have the problem, then probably the audio port of the Motherboard is faulty, you may need to change it.
Jun 03, 2011 | Computers & Internet
Got message from driver "wrong platform"
This usually means that the driver you are loading is designed for a different windows version.
For example, perhaps you're running Windows 7, and the driver is made for Windows XP.
First determine for sure which windows you have, Right click on My Computer, choose Properties. Under the General tab it will tell you what what windows version you have.
Then visit http://sabrent.com/v2/drivers/ to find the correct driver for the version of windows you have and the model of device.
Jan 22, 2011 | Sabrent (SND-P8CH) Sound Card
Can't hear playback. Windows Vista - Playback device says usb Audio Codec
here is what ION is telling people (short version) this is for vista or win7
1. Visit www.ionaudio.com/ezvc to download the latest EZ Converter software.
2. install new software if needed,
3. connect ION Audio USB. make sure its ON (if it has a switch)
Setup Procedure
1. Start then Control Panel.
2. double-click Hardware and Sound.
3. double-click Sound.
4. At top select Playback tab. choose the audio output device.
Don’t chose “speakers-usb audio codec” (that’s your ION) don’t chose modem
5. click Set Default.
6. select Recording tab at top of Sound Control Panel. choose "Microphone – USB Audio Codec" as the default device. (that’s the ION)
7. Click Set Default.
8. click Properties. select Advanced tab
9. set the Default Format setting to 2-channel, 16 bit 44100 Hz (CD Quality).
10. Un-check the two boxes under Exclusive Mode. Click Apply
11. select Levels tab from the top of the Sound Control Panel.
12. Set the level slider to 4. Click Apply, click OK to close the window.
Have everything set up and running, if you have to call this number for help.
401-658-3743 ext. 1405
Jun 25, 2010 | ION Audio iTTUSB Turntable
IDT HD audio codec driver updated by windows updates. since this update i have no audio on my computer. It says device failed to start code 10 in control panel and the computer does not recognise any sound...
Go to the device manager and right click on the device and select properties. In the driver tab select rollback driver. This will install the previous version of the driver. Hope this solves your problem.
Cheers
Please rate!
Sep 28, 2009 | Computers & Internet
Mere pc mea se voice nahi aa rahi........na hi wo volume controler dikha raha hai desktop mea........
do one thing
open control panel then click on the sound speech and audio devices after that click on the adjust system volume a dialog box will appear infront of you then click on the hardware tab there is realtek(whatever your audio software's name) or audio codec click on them then click the properties tab and check whether the device is enabled or not......
Jul 04, 2009 | Computers & Internet
I'm able to hear audio but not the video of wmv files. I have Winamp, VLC player & WMplayer.
Removing the Default Codecs loadTOCNode(2, 'moreinformation'); To remove the default codecs, follow these steps:
  1. In Control Panel, double-click Add/Remove Programs.
  2. On the Windows Setup tab, click Multimedia, and then click Details.
  3. Click the Audio Compression and Video Compression check boxes to clear them, and then click OK.
  4. Click OK.
The default codecs, with the exception of the Microsoft PCM converter, are removed. You cannot remove the Microsoft PCM converter.
uparrow.gifBack to the top Removing a Specific Codec or MCI Device loadTOCNode(2, 'moreinformation'); To remove a specific codec or MCI device, follow these steps:
  1. In Control Panel, double-click Multimedia.
  2. Click the Advanced or the Devices tab.
  3. To remove an audio codec, double-click Audio Compression Codecs, double-click the codec you want to remove, and then click Remove.
  4. To remove a video codec, double-click Video Compression Codecs, double-click the codec you want to remove, and then click Remove.
  5. To remove an MCI device, double-click Media Control Devices, double- click the device you want to remove, and then click Remove.
then download a free codec pack such as k-lite
http://www.codecguide.com/download_kl.htm
and install
Mar 19, 2009 | HP Pavilion MX70 17" CRT Monitor
I need to active my sound card
if your using windows xp try this click start right click on my computer, click properties in there you should see the general tab showing you general details.
if you want more click hardware tab then click device manager now in here you should see everything. thank you and please send us your feed back regarding this problem thank you and fixya.
Dec 14, 2008 | Compaq Audio card Sound Card
I plugged in my speakers in the green hole and the pc dose not recognize it
A device driver is a computer program that enables devices to communicate with each other.
If your audio driver something in this form
Vinyl AC’97 Codec Combo Driver (WDM)is not enable or updated you might not be able to use your speaker.
Click start, click control panel, at the left side of the control panel window, click switch to classic view.
Right click System Icon, click open.
Choose "Hardware" tab and click the "Device Manager" button .
Please right-click mouse on "MultiMedia Audio Controller" and choose the "Properties" menu item to show the driver details.
· Click the "Driver" tab and then click the "Update Driver.." button for update.
· Please follow the instructions of the "Upgrade Device Driver Wizard".
· Choose "Search for a suitable driver for my device" and click the "Next" button.
· Click the "Next" button to install Audio Driver on "Driver Files Search Results".
· If the "Digital Signature Not Found" dialog is opened, click the "Yes" button to continue the Installation.
· After completing the above steps, the driver has been installed into the system.
Please click "Finish" button to complete the installation.
Jul 25, 2008 | Computers & Internet
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
91 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
