Question about HP Computers & Internet
Keys do not input correctly - 2 round the wrong
I have an HP keyboard with Arabic characters (which I don't use). The '' and @ keys do what the other one is supposed to do. How do I get them to do their own thing?
  • 38 Answers
Change the langauge layout of the mouse from control pannel > Keyboard.... if required reinstall or update the driver for the keyboard
Posted on Aug 03, 2009
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    My asus sonicmaster laptop keys p 0 and / type the wrong characters. This can be corrected by holding down the fn key. This does not happen with the touchscreen keypad.
    If you go to Control Panel and check under Clock , Language and Region, then check under "Change keyboard or other input methods" and make sure it's set to you correct geographical region
    Oct 18, 2014 | Computers & Internet
    How can I type Japanese o keybord?
    Hai ! This is possible : )
    Type in Chinese, Japanese, and other character-based languages
    To type text on your computer in character-based languages, such as Chinese and Japanese, follow these steps:
    [Source: http://windows.microsoft.com/en-us/windows-vista/Type-in-Chinese-Japanese-and-other-character-based-languages]
    1. Add the language as an input language. If you want to use an input method editor (IME), make sure you select it when you add the input language. For more information, see Add an input language.
      You can edit documents in multiple languages by changing the language (the input language) in which you type. Input languages are included with Windows, but you need to add them to your list of languages before you can use them.
      1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
      2. Click the Keyboards and Languages tab, and then click Change keyboards.
      3. Under Installed services, click Add.
      4. Double-click the language you want to add, double-click the text services you want to add, select the text services options you want to add, and then click OK.
    1. Change your input language to the language you installed. For more information, see Change your input language.
    The input language is a setting in Windows that controls the language you use to type information on your computer. Before you can change an input language, you need to add that language to Windows. For more information, see Add an input language.
    To change the input language
    Click the Input language button on the Language bar, and then click the input language you want to use.
    93d5c617-b1ec-4138-a1ff-973e71de80fe.pngLanguage bar gl_ico.png Note
    If you don't see the Language bar, right-click the taskbar, point to Toolbars, and then click Language bar.
    1. Change your keyboard layout to the desired layout. For more information, see Change your keyboard layout.
    You can customize your keyboard for a specific language or format by changing the keyboard layout. The layout controls which characters appear on the screen when you press the keys on your keyboard. Some input languages have several keyboard layouts; others have only one. For example, you can change your keyboard layout from the English QWERTY format to the English Dvorak format. After you change the layout, the characters on your screen might not correspond to the characters on your keyboard keys.
    Before you can change the keyboard layout, you must add the input language and keyboard layout that you want to use to Windows. For more information, see Add an input language.
    Hide all expcol_imgs.png To change the keyboard layout
    1. On the Language bar, click the Input language button, and then select an input language.
    2. Click the Keyboard layout button, and then select a keyboard layout.
    gl_ico.png Note
    expcol_imgs.png To change the keyboard layout on the Welcome screen
    On the Welcome screen, click the Keyboard layout button 0c181420-8a93-48b6-82b1-b2dc25fc01b5.png, and then select a keyboard layout.
    TIP:
    After you are done you can switch between Japanese and English very easily by manually pressing the on screen buttons or using keyboard commands like SHIFT+ALT to switch between Japanese (???) and the Alphabet.
    May 04, 2011 | Compaq Keyboard
    Dear expert pos machine(ibm SureOne100 Type :
    looks like its running on IBM PC DOS. code page 708 - arabic. https://msdn.microsoft.com/en-us/library/cc195061.aspx however if you are using windows, then you may need an arabic windows, just adding an arabic languge file wont help. IBM PC Dos doesnt have an arabic option. you can download the ibm surepos 100 4613 technical reference manual which is what i did for you. but it no help in that arabic is not an option. research using arabic with DOS. because your keyboard is basically a PC one working in DOS.
    Oct 03, 2017 | IBM SureMark Printer TF6 Thermal Label
    Problem with keyboard setting: quotation marks don't show when I press the key, only after I press a second key. Also sometimes not then -- eg single quote followed by c gives me c-cedilla! How to change?...
    This "input-method" is a feature that is used in some non-English languages, to easily generate characters like 'C-cedilla'.
    Click Start
    Click Control Panel
    Click Regional Settings
    Set your Input Language to "English-US", to make the keyboard work "one-graphic-for-one-key-press".
    Jul 22, 2010 | HP USB Wireless Keyboard/Optical Mouse...
    My toshiba laptop is typing wrong characters but my wireless tevion keyboard is o k. Is there a solution to this ?
    Sounds like the laptop keyboard went bad and thats why its typing wrong characters. Best way to verify this is to use a USB keyboard on the laptop, if the USB keyboard is typing the correct keys then you know the laptop keyboard is bad. If the USB keyboard is typing the wrong keys as well then you know its a setting in windows that is causing the keys to type wrong characters.
    Apr 28, 2010 | Toshiba Satellite P105-S9312 Notebook
    My keyboard will not delete the character after the cursor location with the insert key???
    You are correct. It deletes the character the cursor is on. Unclick insert and use the delete key to delete characters after the cursor.
    Jul 11, 2009 | HP D8597A Keyboard
    Keys on keyboard typing wrong characters
    Instructions for Windows Vista
    1. Click Start and then Control Panel
    2. In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner)
    3. Open Clock, Language, and Region
    4. Click on Regional and Language Options.
    5. Click the Keyboards and Languages tab and then click Change keyboards.
    6. Under Installed services, click Add.
    7. In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK.
    8. The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes
    9. You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
    Instructions for Windows XP
    2. In Control Panel, if you are in Category View, click on Switch to Classic View (top left corner)
    3. Open Regional and Language Options.
    4. Click on the Languages tab.
    5. Under Text services and input languages, click on the Details button.
    7. In the Add Input Language dialog box, choose the input language and keyboard layout or Input Method Editor (IME) you want to add.
    8. Click OK twice. You should now see a language indicator in the System Tray (located at bottom right hand corner of the desktop by default). You can switch between different input languages (= keyboard languages) by pressing the Alt + Shift keys
    Apr 10, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
    The keyboard characters does not correspond to what appears on sc
    Does it type " by any chance when you press the @ key? if so this is usually because keyboard input is set to the wrong language in the regional & language settings are wrong in the control panel. try pressing the left alt key & shift at same time first this is a quick key to change between input languages.
    Feb 27, 2009 | Dell Inspiron 500m Notebook
    Computers & Internet Logo
    292 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
