Question about Mitsubishi WS-55807 TV
I am not getting any picture. i have sound but no picture. i opened the back and i see that all three lenses are glowing at the bottom of them please someone help
  • 69 Answers
Do you hear static elctricity ( Crackel Crackel)
sound when you turn it on /or off ?
means you have H.V. if not the tripler is out
or the primary Fly back is dead .
Posted on Jun 28, 2009
I have opened lens assemble for cleaning & now i have three image in three color (R,G,B). how i can calibrate lenses?? tanks
Take the unit to a factory authorized repair station. Once the lenses get out of collimation, you won't get them back on your own.
Oct 07, 2013 | Sanyo PLC-XP57L LCD Projector
Water accumulates and freezes on bottom of freezer.
Orange glow is defrost heater and that is normal. Crackling sound is heater heating up area around it, normal. Water and ice build up in the bottom is due to a clogged defrost drain.
Sep 01, 2012 | Refrigerators
Parents gave me their old Mitsubishi TS-5545 a few weeks ago. Pretty sure something shook loose on the move 'cause when I finally hooked it up and turned it on today the picture is hazy and and the...
You could Start with just Cleaning Mirror and top of All 3 Tube Lenses remove Back and try cleaning out All dust and Dirt with Thin Paint Brush then Remove Front Top and Bottom Panels and then you can Clean Mirror and Top Of All 3 Tube Lenses Then Put Back Together and see what Kind Of Picture you have then! Turn Color Off on Menu See if you Have a Black and White Picture?
Jan 16, 2010 | Televison & Video
I replaced lamp and picture shows well except at
Light from the lamp is getting itnto the top inside of the set Just changing the lamp should not cause this problem. I've seen this where someone has cahnged the light engine and did not reinstall the foam gasket aroun the lense . But any way look for an opening from the lamp area into the upper chamber where the mirror is.Light from the lamp should only go into the light engine and not into the upper chaber except through the projection lense.
Nov 27, 2009 | Toshiba 52HM95 52" HDTV Projection...
Screen blury,very pink,green edging on picture almost colorless!
This would be a convergence issue you can run the convergence setup that is in your user manual if that does not work you are going to need service.
thanks
Sep 17, 2009 | RCA HD52W56 52" Rear Projection HDTV
The screan is dark on the top and bottom and color is strong
This not the correct Model #, this model is a DLP set and does not have picture tubes and associated lenses. Did you remove the mirror? Does your set have a fold in back? I suspect the back is not fully out in the correct viewing position.
Dec 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sound but no picture!
I would double check the wire connections especially the bridged connectors that connect the A and D boards also see if the wire from the front panel PCB is actually hooked up. Often its easy to get a wire plug mixed up and plugged into the wrong socket or not seated properly.
Nov 30, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Screen went black, no picture
A clue to what is wrong is by looking from the back (taking the back off) and looking to see if the three picture tubes have any yellow glow at the bottom of them where the three identical boards are located on each tube.. If you have no glow there you possibly have a resistor R4703 open. It is a 3.3 ohm resistor and feeds the voltage to the filaments in each tube where the glow is suppose to be. If you do have the glow the problem could be much more complicated. Another to check is to see if the menu comes up on the screen. You could possibly be in the wrong input mode, Check your input mode with the input button on the remote The number R4703 is a location number to identify where the resistor is. This is all I can tell you that would not require much more complicated procedures requiring a tv repairman to look at it. If you have an ohm meter you can check R4703 but it must be checked out of circuit. (or at least one leg loose) Hope this helps
Jan 04, 2008 | RCA P52930BL 52" Rear Projection...
Phillips Magnavox 60 inch Projection Tv
I have a white glow around all the white letters and just all the white colors in general. What do I do ?
Sep 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi WS-55807 TV Logo
132 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
