Question about HP Serial adapter (17302A)
Monitor is a HP 1730, PE1237 Yesterday monitor ca me up ok, after appx. 20 min went to completely white screen. Checked voltages 3.3v, 5, and 12v - all ok! replugged plugs on pcb, still only white screen. Any suggestions?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 21 Answers
Check the monitor cable
Posted on Oct 07, 2012
5 Suggested Answers
Noggin
  • 944 Answers
SOURCE: HP 1730 Monitor
It depends on your graphics card driver. If you are using windows xp, go to "control panel", "Display", select the "settings" tab, and click "advanced". You should get a properties page, one of the tabs should be "Rotation" - change to what you want, then apply changes. If you are unsure why the screen changed in the first place, check on the "rotation" page for a description of the hotkeys - most likely there is a hotkey set to rotate your desktop which has been inadvertently pressed. If not windows XP, then the procedure is most likely similar. Hope this helps, please ask again if you need more info :)
Posted on Jul 20, 2007
noone
  • 105 Answers
SOURCE: hp 1730 monitor will not turn on
There are multiple circuits for this model. I suspect your model is PE1237. If so this model frequently has bad solder connections at the AC socket. Also capacitor 2119 or capacitors 2041 & 2031 can cause no power up. They normally are bulging if bad.
If your model is PE1238 (BenQ), you may see bulging capacitors in the power supply.(1000uf/25v)
Monitor Mike
Posted on May 09, 2009
thr_mouad
SOURCE: driver for hp 1730 flat screen monitor
mouad tahiri
Posted on Aug 25, 2009
technical114
  • 1851 Answers
SOURCE: monitor hp 1730 has no sound
Use a pair of headphones to check out that the computer's audio out is working properly. If it's OK, then connect the line output at the monitor's audio input and check the audio level at the monitor.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Apr 08, 2010
White screen after about 20 minutes of operation
key words above, (change(d) PC) did you mean you changed out the PC, and it fails, I will guess yes) as in past tense?
old old , 1710s, most are now dead, you know that right?
all have CCFL tubes in it.(problematic for sure)
and had a sleep mode inside, (problem 2) sure.
so with PC turned on, the push the menu key
and turn off the sleep timer, keep it off for ever.
it is not compatible with NEWER PCs at all.
the Monitor is bad,
if cable and pc are ok, the monitor is bad.
you proved that, if change = changed. above.
like this. (GO LED !) avoid all monitors older than year 2010 !
https://www.walmart.com/ip/Asus-LCD-VS197D-P-LED-Backlight-18-5inch-Wide-1336x768-50000000-1-5ms-VGA-Retail/20701019
Nov 06, 2017 | HP L1710 LCD Monitor
HP 1730 driver windows 7
what i know is that monitors don't need drivers. if your monitor is new then i believe it is already windows 7 ready.
what you need to do is check the VGA cable if it is damaged. try replacing a new one. Hope this helps.
Jun 21, 2012 | HP 1730 LCD Monitor
Please help me, i got a hp 1730 lcd monitor. the problem is that the screen is turned white and no image is present like there si not sinc on the screen the menu is lose only a shadow on the screen and...
How many months or years of your monitor that you are using? Do you check the outlet, cables? It's seems that your monitor has a problem because i read your observation that your monitor seems to be replace a new one. That's the monitor's problem.
Sep 16, 2011 | HP L1730 (Carbonite, Silver) 17" LCD...
I had a power failure in my area. When power was restored my pc booted up ok but the monitor screen only stays visible as it should for about 3 seconds, then it goes black screen. I have powered...
Close windows down. Wait 15 - 20 mins, then power monitor up but NOT windows. Screeen should say "NO SIGNAL in centre. If t does not, wait five mins If still no display shut down and wait another 5 mins. Then start monitor un ANDt windows.. All should be OK now, If not shut EVERYTHING down and disconnect from mains ovrernight. (PC riouter/modem,,,, EVERYTHING . 12 hours later, re-connetc in THIS order - 1.) MONITOR 2.) PC 3) ROUTER/MODEM Should be OK now.
Aug 17, 2011 | Acer X193W LCD Monitor
Starting the PC have got error on HP 1730 Monitor error message, OSD Lock out. Can you please tell me how to solve this issue?
How to Unlock an "OSD Lockout" Problem
smilie-tag.png monitor, osd lockout folder-category.pngPosted in Fixes ' Comments (32)
osdlockout.jpg This has most likely annoyed many of you at some point. You turn on your monitor one day and see a jeering message telling you something about an "OSD Lockout". It doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While I've only seen this error on HP monitors I know that others have encountered it on other brands as well. The fixes I provide should work on those monitors too. (Note: OSD stands for On Screen Display.)
Fix One: Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two: Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three: Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four: The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
If you know of any other fixes feel free to contact me. Good luck!
Having other problems with your computer? Simply scan your computer for free to identify problem areas.
Techbelkin please rate me
Nov 02, 2010 | HP 1730 LCD Monitor
Hp 1730 monitor went black
if after few seconds of display and then the while display turn black, this is the indication of failed capacitor on the LCD circuit board...
you will need to have some technical skill to replace the capacitor.
Jun 21, 2010 | HP 1730 LCD Monitor
HP vs17e My screen went black for a few moments and when it
Switch off and on your PC and hold down the F5 key and this should bring up your PC in Safe Mode. If this fails, then find a PC repair shop to replace the power supply.
Mar 22, 2009 | Computers & Internet
Hp 1730 monitor will not turn on. The power light on the front of the monitor blinks. Screen is black looks to be off. when i push the power button nothing happens.
Monitor Mike
Dec 09, 2008 | HP Serial adapter (17302A)
Compaq Monitor FS7600e - 17" monitoor
the -ve ground voltage decreased when u saw the screen goes white.if it flash too much then may be the front phosphorus coating burn due to excess whiteness suddenly. if that is ok then check the the G1 voltage , they are in excess, follow the track and replace the components after checking. also check the heater voltage and screen voltage (G2) ( do not touch the G2 voltage without insulation. they must be between 500-1000 volts. if they are disappears then check the EHT transformer. if the problem still prisist then inform me, i will guide u step by step.
Feb 08, 2008 | HP Compaq FS7600e CRT Monitor
HP Serial adapter (17302A) Logo
423 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
