Eight wires thermostats - Heating & Cooling
  • mwilliamsy Jun 28, 2009
    i was told it was my thermostats but i do not knowe whitch one to buy becuase it haves eight wires and it heat/cooling with heat pump
    IT WAS TOLD TO ME THAT I NEED A NEW THERMOSTATS. BUT I SO NOT KNOWE WHITH ONE TO BUY I HAVE EIGHT WIERS THANKS MERRI
    President:
  • 1,197 Answers
First you must be commended to be asking the question BEFORE you go and buy the wrong thermostat, and then try to figure out how to wire the unit, all while not having heat. Look at all the previous posts here about needing help to connect a thermostat, and it is getting cold in the house, and you will see what I mean.
The following links are some general help regarding thermostats, the third as a sample of how complicated the wiring can be, esp. for heat pumps:
http://toad.net/~jsmeenen/tranewire.html
http://toad.net/~jsmeenen/wiring.html
http://www.columbustemp.com/pdf/prod..._datasheet.pdf
Sure sounds as if you have a heat pump, with two auxilary stages of heat, this being refered to as 'Multi-stage".
And as you already know, there are many thermostats to choose from. Now I am a proponent of hiring professionals to consult and do work that a homeowner is not able to do on his own. Should you decide to tackle this job yourself, there is some prep work you must do.
First, you really need to understand exactly what type of system you have, for several reasons. One is obvious, know how your system is working, what is working when. Once you know what and how your system works, then you will know when it is not working properly to be able to take advantage of it's proper operation for your comfort, and perhaps realize some energy savings, along with the proper maintenance of the system.
check out the below link for information on how to wire a 8 wire thermostat
http://www.exqheat.com/images/Instr.11-30-08.pdf
since ur looking for a 8 wire thermostat... i suggest u try Honeywell TA32H01....
check out the below link and enter ur zipcode for details on retail outlets at a place near u...
http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Where+to+Buy/RetailLocator.htm
if u felt i ve spent my time for u.... kindly rate my service...
good luck and have a nice day...
Posted on Jul 01, 2009
  • 3,230 Answers
Please explain your question in details.
thanks
Posted on Jun 28, 2009
Where is my thermostat located on my 97 oldsmobile ieghty eight
follow the upper radiator hose to the engine. It will be clamped to a housing on the drivers side front of the engine. The thermostat will be under that housing.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 28, 2011 | 1997 Oldsmobile Eighty Eight
Where is the temprature plug in on the motor?
I don't know if you have the six or the eight cylinder, but not really an issue. Look on top of the engine at the front and follow the top radiator hose to the engine. You will see the thermostat housing that the upper radiator hose connects. Right there close you will see a sensor that screws into the block or the thermostat housing. Should be just a single wire that slides onto the top of the sensor. Good luck.
Aug 27, 2011 | 1981 Ford F 100
I have replaced the thermostat and the heater does not get very warm how can i fix it
You need to know the size thermostat you put in the lower temp thermostat the warmer the engine gets sooner. You may need to replace the heater core.
Sep 17, 2010 | 1990 Oldsmobile Eighty Eight
Car over heats fans dont come on unless you turn on a/c or heater ? on my 94 oldsmobile eighty eight
Check for a bad thermostat ,and ,or low coolant level,and you may have to bleed the air out of the cooling system,and replace the coolant sensor.
Jul 10, 2010 | 1994 Oldsmobile Eighty Eight
COOLING PROBLEM
Thermostatic senor no good.
Cheers, Timo.
Apr 29, 2010 | 1994 Oldsmobile Eighty Eight
What are the numbers on a distributing cap
engines have a fireing order for each piston like 18436572 for an eight cylinder the distributer cap will have eight spark plug wire connections starting with number one connect plug wire to number one cylinder then moveing clockwise around the capconnect plug wire to the number eight cylinder untill all wires are connected in order to the right cylinder
Feb 16, 2010 | 1989 Saab 9000
Trying to install new programmable thermostat.
Standard hook up for Heat pump.
Red wire----------R
Green-------------G
Blue----------------C
Yellow-------------Y
Orange------------O
White--------------W1 with a jumper to E sometimes will also say Aux, varies with Manif. of T-stat.
Hope this helps you out.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Oct 20, 2009 | GE Zoneline AZ55H09D Air Conditioner
Where are the coolant sending units
ON THE LEFT CYLINDER HEAD BELOW THE THERMOSTAT HOUSING.IF YOU REPLACED THE COOLANT SENDING UNIT.STILL THE OVER HEAT LIGHT COMES ON YOU HAVE A SHORT IN GAUGE OR WIRE.
Sep 27, 2009 | 1995 Oldsmobile Ninety Eight
How To Replace My Thermostat...HELP!
Termostat is as follow. See clarification. R U changing the sensor?
Follow the top radiator hose over to the engine and where it connects to the thermostat housing. There should be two bolts holding the housing to the motor. Remove the housing and replace the thermostat and gasket. The larger side of the thermo goes in the engine.
May 05, 2009 | 1990 Oldsmobile Ninety Eight
Thermostats being replaced often
I have repaired A/C commercial and in dustrial for 40+ years. ( ot of ten times replacing one item as a t-stat 5 times pretty much proves it is not the thermostat. The VA rating on your transformer has to ne able to carry the total load of your circritry.
Yes, I have als seen cases wher a intermitent short occurs in the thermostat cable that has up to 6 different wires in it.
Also "Heat anticipators" in all t-stats (Unless they are automatically controlled) need to be set properly.
You need a AMP reading meter with a Volatage and Resdistence Meter.
I suggest calling a professional. ONE WHO IS LICENSED TO WORK ON THE MODEL OF AIR HANDLER AND CONDENSER YOU HAVE. THE T-STAT MUST BE WIRED CORRECTLY TO THAT SYSTEM. TRANE, CARRIER, RUUD, GOODMAN, ALL ARE DIFFERENT IN COLOR CODES FOR WIRING.
I had one job wher a painter had nailed through the t-stat wire inside the wall and caused a short between the Red (Hot wire) and the ground wire ( in this case it was the blue wire) Depending on the t-stat ... There ar up to eight terminals that need to be i9dentified and then properly wired.
Heat pumps use at least 5-6.
5 t-stats failing is gettin close to $500 of repairs if not more.
Feb 06, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
