Question about Breville Kitchen Appliances - Others
I have several sandwich toasters but the Tefal coating keeps flaking off. I want the know where I can buy spray-on Tefal coating to re-cover the toasting surface?
    President:
  • 2,976 Answers
Don't use the spray on teflon. It will kill you. It is used as an industrial coating but it isn't food grade. You would be safer, using wheel bearing grease to cook your food. The problem with nonstick cookware is, once it starts to break down, there's nothing you can do except either replace the item or scour it off and use a cooking spray.
Posted on Jul 02, 2009
Tefal
It is cheaper to buy a new toaster.
Aug 19, 2014 | Kitchen Appliances - Others
Manual download
Here is the tefal home page for the classic 4 slice toaster. I believe it is the same taoster as you have described but let me kow if it isn't.
At the bottom of the page is a downloadable pdf manual for this toaster.
http://www.tefal.co.uk/Breakfast/Toasters/Tefal-Avanti-Classic-4-Slice/p/1500532718
Hope this helps
Jan 29, 2014 | Tefal 5332002 4Slice Toaster
The left side of my toaster dosn't work
It's probably one of two things:1) They pressure contacts that engage the electromagnet may have burnt carbon deposits similar to spark plugs. One needs to clean in between the contact (two on each side) while putting slight pressure as the contacts meet.2) The spring mechanism that engages these contacts has snapped at the securing point, thus not able to put enough pressure to engage these contacts that power the electromagnet.
For some reason it's always the left side.
If the toaster is more than 5 years old I would suggest buying a new on , even though these toasters are very reliable. As the crumbs that left inside are so powdery and coats every surface inside, as well.
May 22, 2011 | Tefal TT744115 4Slice Toaster
My tent has served me well but recently parts are starting to fall off. When I shake the outer cover dry there are lots of flakes that look like glue. 3 of the velcro attachments to the outer part of the...
Hi, the flakes you're referring to is the original weatherproofing that was applied by the manufacturer. This coating can be reapplied using a spray on product that is purchased at most camping outfitters. Before you spray, give the cover a gentle wash to clear any dirt and grime. Then using a mild abrasive pad, gently lift away the flaking weatherproofing. Spray the new coating as per product instructions.
Nov 17, 2010 | The North Face Tadpole 23 Tent
I need a raclette tray for 8.
I know the Swissmar Raclette Grills have a replaceable grill top, but I do not know if you can buy this item from Tefal. I would contact their Consumer Service number:
http://www.tefal.com/Consumer+service/Home+consumer+service.htm
Sep 13, 2010 | Tefal Raclette Buffet 7822700 Indoor Grill
Lever to lower toast has snapped off just inside the toaster casing. It is plastic and cannot be reattached
Hello Sue, I've attempted to locate replacement parts for for Tefal Avante toaster, but there doesn't appear to be a broad source for these, which troubles me as I've got the same toaster and use it everyday.
I did locate the Tefal customer support/service contact that should be able to provide you with either a local authorized service location or provide you with the replacement parts you need to get it working again.
You can call Tefal directly at 1--800-395-8325 from 8:00 AM to 5:00 PM Monday thru Friday, EST
Here's a link to the contact page, in case you prefer to send an email instead.
http://www.tefal.com/Consumer+service/Contact+Us/Contact+international/United+States.htm
With luck, Tefal will be able to assist you in getting your toaster working like new soon.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | Tefal Avante Deluxe 2 Slice Toaster
I have a tefal TT550015 toast 'n' Egg and have no instructions on how to use it. Please advise
To use the egg side only, fill the measuring cup with the correct amounts of water. (One side is for boiled eggs, one is for poached eggs.) Pour the water into the basin at the bottom. For boiled- Place 1-4 eggs in the tray with the four holes. Use the sharp thing at the bottom of the measuring cup to pierce the egg shell. Place the lid over top, and hit the 'egg' button. When the light on the button goes out, remove the lid. For poached, grease the pan. Spray/ butter, whatever. DO NOT rely on the non-stick. The thick black tray for boiling eggs goes on first. With the egg in the greased pan (scrambled or whole) place the pan into the unit. There are four plastic pieces in the boiling tray to show you where it goes, the handles aligned. The round tray, with the square holes in it, can be used to warm pre-cooked meat.This is optional, and that tray goes on top. Place the lid over the top, and press 'egg'.
WARNING: this cooks by steam, and any remainder can cause burns. Be careful when removing the lid. Same goes for the product. The boiled eggs should not be touched directly.
To make an egg sandwich, load the egg side and the bread/english muffin/bagel into the toaster. Press the 'egg/toast' button BEFORE starting the toaster. The toaster will start on a timer so that the egg and toast will be done at the same time. When the toast pops up, you are good to go.
Note: there should be no water afterwards, maybe a little oil if you cooked meat. Hard water residue is easily removed with vineger and a paper towel.
Dec 02, 2008 | Back to Basics TEM-500 Egg & Muffin...
I have a 4 slive tefal deluxe toaster which has stopped working
often is the switch as you press down its a steel wire like a pin that snaps i have repaired 2 same problem i soldered a fine steel wire on its easy part to replace but so far i cant buy a replacement switch
Sep 08, 2008 | Tefal Avante Deluxe 4 Slice Toaster
PEELING PAINT INSIDE MICROWAVE/TOASTER OVEN
I do have the same problem, but I know they make microwave paint if you can get it from an appliance store or you can order through the web - BUT 2 sites I just looked at said a gloss enamel paint, such as that used to paint "model" toys works just as well. In either case: Smooth the old stuff off, sand lightly (you want no metal dust left -or- damaging any coating on the metal) just sand enough to make sure there's no flakes & it's smooth, then use a gloss enamel paint rather it's approved for microwaves or the Testor's kind.
NEXT -Make sure you DRY with Hairdryer to set the paint, and keep the heat to med or low, don't bubble or scorch your work!) and do not use the microwave for 24 hours!! Leave the door open while drying for several days afterwards if you can. Any fume smells can be absorbed by using -used- coffee grounds and leaving overnight. Google groups was one source the other was a repair listing forum.
Aug 30, 2008 | Microwave Ovens
Kitchen Appliances - Others Logo
199 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
