Screen settings on computer monitor
I bought from PC World a display version of the Samsung computer monitor SM943NW which came out of the box and therefore without instructions or manual. In particular, I am unable to alter the settings as my mouse cannot operate within the display boxes of the menu. Please advise where I might download a manual, or else advise on the specific problem.
Henry Cohn
    Brigadier General:
  • 7,191 Answers
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 15, 2013 | Samsung N120-12GW Netbook
Samsung 6000/6500 internet browser
The 6500 and above has a web browser in the Smart Hub else:
Using Your TV as a Computer (PC) Display
Setting Up Your PC Software (Based on Windows XP)
Depending on the version of Windows and the video card, the actual screens on your
PC may differ in which case the same basic set-up information will almost always be
applied. (If not, contact your computer manufacturer or Samsung Dealer.)
1. Click on "Control Panel" on the Windows start menu.
2. Click on "Appearance and Themes" in the "Control Panel" window and a display
dialog-box will appear.
3. Click on "Display" and a display dialog box will appear.
4. Navigate to the "Settings" tab on the display dialog-box.
The correct size setting (resolution) [Optimum: 1920 X 1080 pixels]
If a vertical-frequency option exists on your display settings dialog box, the correct value is "60" or "60 Hz". Otherwise, just click "OK" and exit the dialog box.
Oct 10, 2012 | Sys Refurbished 6000/6500 (wsx6101oc12sfm)
Trying to connect dell desktop to my Samsung DLP HL-R5064W tv through vga cable to watch movies. Toggle source button on remote to pc, but receive an out of range message. please help
"Out of range" message indicates that the output from your computer to display it from your Samsung HLR5064W DLP TV is too large. You need to adjust the screen resolution settings for you TV. I have attached images of display settings dialog boxes from different versions of Windows.
You may open the display settings of your computer by clicking on START > CONTROL PANEL > DISPLAY. While your TV is connected, click on IDENTIFY button. You will notice that numbers 1 and 2 will appear briefly on your screens consecutively. As the dialog box shows 2 monitors with numbers 1 and 2, click on the monitor with "2" on it. Then, adjust resolution to 1280 x 720 as this is the highest resolution your TV can handle. You may adjust the TV (monitor #2) to be IDENTICAL or to EXTEND the display of your computer. You can also assign it as the main monitor but not recommended. Click OK then try to toggle your computer's display. You should be able to see a display from your TV this time.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 22, 2011 | Samsung HLR5064W DLP Projection TV
I just bought SamSung BX2331 monitor, I hook up the HDMI to computer and nonitor, and I plug in the power too. The whole thing was set up, but I do not see anything. When I turn on my computer's power...
The computer monitor is outdated, and does not have enough pixel quality to perform caparatively with high definitoin Quality. Also, the HDM1 computers are the best version capable, an outdate monitor would produce least qualify display images. Acquire a projector device to dsiplay high qaulity pictures from the HDM
Dec 21, 2010 | Computers & Internet
Display is fuzzy
Go into monitor controls on monitor and adjust as they come up. Unhook monitor, power up computer, cut off, plug in monitor power up computer, right click on screen, settings, adjust for screen size and additional monitor by clicking 2 and saying yes in box. Hope this helps.
Jul 05, 2009 | Samsung SyncMaster 175V 17" LCD Monitor
Whole display is of reddish colour -Samsung 945NX LCD
try to update the lastest version of your video card driver
May 12, 2009 | Samsung SyncMaster 152 B 15" LCD Monitor
Samsung 17" Flat Screen PC Monitor
Problem from motherboard side.
- No display from motherbaord circuit (Display IC)
- Try to figure out with PCI Display card or
- Try to connect different monitor or this monitor to different computer to cross check your dignosis
Jun 02, 2008 | Samsung Computers & Internet
Popup on monitor screen
first try unplug set from AC plug for about 10 seconds for full system reset.If not see if firmware (software) on set could be updated to newer version software...could be a software issue..
Nov 28, 2007 | Samsung 710N V2 17" LCD Monitor
940mw - Compatibility
First thing i would check is your settings. See if windows is reconizing two monitors. If not then you will need to tell it to find it. Hook up your second monitor goto add new hardware and see if windows finds it. If it doesnt find it then i would go to manufactures site for your laptop and see if there are advanced drivers for that particular model of monitor.Also I would look at the manufacures site for advanced settings or technical information. This should solve your problem.
Nov 14, 2006 | Samsung SyncMaster 940MW 19" LCD Monitor
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
