Question about Lenovo IdeaPad S10-1211U Netbook
Windows is not detecting usb mouse and mouse is not working
When i connect a mouse to a usb port windows does not detect it and says to replace the device...i have changed the mouse too but still the problem persists...
  • 94 Answers
Which OS you have..? xp/2000 , both OS not need USB driver but auto detecting.., i request you to try another usb socket.
Posted on Jun 28, 2009
    Sergeant:
  • 361 Answers
look on device manager , i think there is not instal usb pord drive , keep board cd and in stall usb port . then your computer dected usb device or mouse. xp should be detced usb port. keep mouse and restsrt once a time. it can take. thanks
Mouse not working
Mouse is a short life device. If your used it more then replace a new mouse. Because if your repair it cannot succeed. And cost a double charge .. So Purchase a new mouse..
May its cable cannot connected well to computer...
If You have usb mouse change the usb port and place on other usb port... If this not works remove mouse..
If you use ps2 mouse this type of mouse dont detect if your connect on pc on mode.. So restart your computer to find your mouse...
Hope this will help you...
Mar 08, 2013 | Computers & Internet
Gaming mouse cannot detect
try to plug into every usb slot... see if your mouse can still work or not... but i recommend you to bring that mouse and claim for it warranty....
ps; if you plug your mouse into the PS/2 port, u need to restart your pc. i hope this will help you.
Jun 13, 2012 | Computers & Internet
My laptop cannot detect the mouse. It states that there is an undetectable device. I have followed all directions and I still can't get the mouse to connect to my laptop
I think this will help.
A USB Connector has 4 terminals.The two terminals at the ends are to supply 5 Volts. The middle two are for data transfer.
If the terminals at the end are OK the device will get power (5V). Then the computer can detect something was attached. But if one of the middle terminals are damaged, your computer cannot recognize the device.
The problem might be with the USB port of the printer. Connect it to a different port. Does it (mouse) work on your desktop machine? Then the problem is not with the mouse.
If the mouse fails on all USB ports, the problem is with the mouse. Check the USB jack of the mouse. Sometimes the damage is visible. Or else one of the 4 wires of the mouse cable is disconnected (damaged) due to bending of the wire. In this case, buy a new mouse or replace the mouse cable.
Jul 22, 2011 | Office Equipment & Supplies
Computer not recognizing hard drive. Seems to be a problem with usb connection. Can I put the drive into another enclosure?
Definitely you can try with different enclosure, and it will work in any enclosure... But before buying a new enclosure it would be better if you try to connect the hard drive in a different computer to isolate where the issue is...
Jan 02, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
My V450 Nano Cordless Laser Mouse for Notebooks aint working the green light is on but it doesn't get recognize by may laptop
Q: Troubleshooting: Basic Mouse/Trackball Problems trnsp.gif This article covers some common reasons why a Logitech mouse may cease to function.
trnsp.gif This article applies to the following products:
All Logitech mice/trackballs
Cause:
There are a number of reasons why a mouse or trackball may suddenly stop working. These include the following:
  • defective hardware
  • system configuration changes
  • wireless detection issues
  • hardware connection failures
Solution:
It is possible that the mouse or trackball has failed. A failed unit can be described as a product that works for a period of time then suddenly stops working. Verify that you have not made any changes to the system that might coincide with the failure of the product. For example, if you moved the connection of the device to another port to add another device to the system or if you added new software or made other system changes. Also, verify the device has not become disconnected from the system by checking to see the device is correctly connected. Once you have verified the above potential causes for failure, proceed to the following steps.
1. Wireless Detection Issues
If you are using a wireless mouse or trackball, you should first check to see if you have a connection issue. Please see Knowledge Base article 970 for information on diagnosing and resolving detection issues.
2. Port Connection Issues
If you have concluded that the issue is not due to a detection issue and the pointing device has just stopped working, try the device in another port. If you were using it on the PS/2 port, try moving it to the USB port if you mouse supports it. If you have another USB port, try that other port. If you were connected through a hub, try connecting directly to the system ports to verify the hub has not failed.
3. If the device doesn't work on a second port, try it on a second system, if possible. If it fails on a second system, then the device probably is defective. You may also want to try a second mouse in the same port that the failed mouse was using.
4. If the second mouse does not function in the same port, verify the system port has not failed. Contact the system manufacture for more information on the status of the system port.
5. If either the mouse fails on a second system or the second mouse works in the same port, then you know the Logitech mouse is defective. If this is the case, please contact to inquire about a warranty replacement.
Answer ID 3997
Created 2006-06-13 01:54:48
Updated 2009-06-03 04:28:23
Jul 18, 2010 | Logitech V450 Nano Cordless Laser Mouse
Hi there, my computer cant detect my wireless mouse, even thou the curser is in the screen. but it can detect my keyboard. i did change battery, plug out the wireless antenna, keep pressing the connect...
to know if your windows keyboard and mouse controller is working try to use first a cabled keyboard and mouse, if you find it working try this steps.
first, try to remove the wireless usb device which your keyboard and mouse is connecting to, try to use another usb port from your computer.
second, your wireless device comes with a cd installer, try to reinstall the program of your wireless device
and then try again
Jan 05, 2010 | Computers & Internet
Hi, the CS62U is connected with an HP8750 (win2000) and a MSI WIND NETTOP 120 (win XP home). It works perfectly with the HP desktop but the mouse is not responding anymore.
Try this:
1. Disconnect your HP computer, so that only the MSI Wind is connected.
2. On the keyboard, hit [Numlock]+[-] then press [A] (this will auto-search for the computer that's connected, and connect both keyboard and mouse to that port).
Give XP a minute to detect new hardware. If XP does not detect the mouse, try plugging the mouse into a port directly on your netbook. If XP still does not detect the mouse, it's XP that's not detecting your mouse properly, not the kvm switch. :) If it does detect it, you should be able to then plug it back into your kvm switch and it should work at that point.
Note: if you get stuck with lights flashing on your keyboard, just hit [Esc] on the keyboard. That will reset the KVM switch.
Hope this helps!
Sep 24, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
MY PENDRIVE IS NOT GETTING DETECTED
hi im josh in cebu phils. friend if not detected the problem is you usb port or the flash disk. if you tried using your flash disk in other computer and you are sure that it is functional. then go to your usb port.check the connections.check also the confg.from the device manger if the printer port works. then dont forget that windows 98 and older versions of windows dnt automatcaly detect usb.good luck .
Feb 20, 2009 | Intel Motherboard
Onboard usb
VIA needs to stop making USB chipsets... lol... Are you sure you have USB legacy support enabled? Moreover, the default Windows XP drivers are not error free when used with a VIA Rev 5 USB Host Controller because it's actually a VIA Enhanced Host Controller. Every time I have USB problems with the VIA Enhanced Host Controller I go to there website, download the driver, and it usually fixes the problem.
USB 2.0 (VT6202, VT6212, VT6214/L)
Moreover, I have plugged in a Microsoft Wireless Optical Mouse and Windows XP could not detect it until I installed Microsoft Intellipoint; if you can believe that. Try also installing the mouse drivers as well...
Nov 27, 2008 | MSI 865GM3-LS (MS7043020) Motherboard
Targus wireless notebook mouse
See for Windows, the answer is yes. This is because when Windows detects that the mouse is not connected, it may freeze. Also may not boot up all the way from restart either. You can always get a multi port USB hub if you need more USB ports.
Nov 20, 2007 | Targus Wireless Optical Notebook Mouse...
Lenovo IdeaPad S10-1211U Netbook Logo
493 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
