Question about Saeco Royal Exclusive 30153 Espresso Machine
I am getting an error message that says VENTILATE
I have a Saeco Royal Exclusive that is giving me a message VENTILATE when I looked this up in the manual under drainage it says that I should open the hot water valve and that will clear the line I do this and the water comes out hot but I still get the message. I am unable to do anything else on the machine. It has worked fine for 2000 coffees. I have done the regular descaling etc.what can I do? do I have to send it in? it seems as though the pump is working fine.
  • Anonymous Feb 11, 2008
    after descaling the machine the word ventilate is coming up......any suggestions?
    Michelle
  • Andres vanososte Apr 21, 2009
    I am getting tyhe same VNETILATE error message, , I did the dreinage on pag 37.. and de machine makes some noice, but no water comes from the dispenser tube, is the pump damaged?
Try draining the machine. Page 37 of the user manual, Drainage. Place cup under the steam/hot water tube, turn knob clockwise around to 9. If the pump is ok, it will start automatically and start filling the cup. Drain about 1/2 cup of hot water and return knob counterclockwise to start position. If the flow meter is not damaged, the Ventilate message should be gone.
Posted on Jul 26, 2008
    Sergeant:
  • Saeco Expert
  • 223 Answers
Have you seen any kind for leak prior to this ventilate message?
Sometimes if the boiler is leaking the flow meter gets damaged and causes a ventilate issue. Flow meter controls the amount of water that enters the machine. It is located directly below the boiler and gets water damage if the boiler leaks.
If you are getting a good water flow then theres a good chance that it is the flow meter.
Check out www.CeriniCoffee.com for more information and parts.
Posted on Nov 07, 2007
2 Suggested Answers
  • 1089 Answers
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Posted on Jun 14, 2010
Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
Aug 02, 2011 | Saeco Royal Professional Espresso Machine
The display on my Saeco Royal Exclusive says ventilate and the machine won't do anything, what do I do?
Hi
That means the pump needs to be primed by running water through the wand. Push the water button( the one with the drop or drops). You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed.
Aug 21, 2010 | Saeco Royal Professional Espresso Machine
How to ventilate a saeco cafe royalecoffee machine
Hi
There is a water button you need to push. It has a water drop on it. This will clear the ventilate message.
Jan 22, 2010 | Saeco Royal Professional Espresso Machine
New Royal espresso machine
Run hot water cycle to ventilate machine.
Mar 09, 2009 | Saeco Magic Comfort Plus Espresso Machine
Looking for user's manual for Saeco Stratos Expresso Machine
I have a user instructions to this machine.
I will try to upload it to Royal exclusive 3053 page.
/Mirran
Aug 12, 2008 | Saeco Royal Exclusive 30153 Espresso...
Ventilate!
Can you get water out of the machine by pushing the hot water button?
This is how you would remove the ventilate message in the first place, but if no water comes out then the machines electro-valve is not opening and you will not be able to remove the ventilate message. You will have to get the machine serviced.
I would also give descaling the machine a try before servicing the machine.
You can also find the user manual for the royal professional on our website: http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
We are a Authorized Saeco Service Center based out of New York.
For Saeco Parts and Cleaning supplies visit www.CeriniCoffee.com
May 29, 2008 | Saeco Royal Professional Espresso Machine
Saeco royal espresso machine
Ventilate just means that the system has senced a lack of water flow and shut down. Push the button to have water come out the wand and that should reprime the unit. If however no water comes out and the message stays on then you have another problem If water does come out but the message stays on then you have another problem. If in either of these cases you should google "saeco repair" and send it to an authorized saeco repair center to have it fixed.
Aug 26, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Exclusive 30153 Espresso Machine Logo
926 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
