Question about Dell Computers & Internet
Page will not fill whole screen
I have two black bars at the sides of my computer screen and the picture is distorted.
  • jackielmo Jun 28, 2009
    Thanks, that did the trick!!
  • 390 Answers
Hi
you haven't mentioned much about ur monitor but generally adjusting the screen resolution to different setting should resolve the problem
while also there are screen setting buttons on the monitor to adjust the size of the screen and others
hope this helped
cheers
pls rate the solution
Posted on Jun 28, 2009
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
2 vertical bars on the right side of screen, thay are black, has picture and sound but no thing in the bars
That's because your aspect ratio is 4:3. To get the picture to fill the whole screen change the aspect ratio to 16:9. You can do this by pressing the aspect button on the remote (right above the channel + button) and changing it to different sizes such as cinema, panorama, and full. Try all the options and see which one like best.
May 26, 2011 | JVC PD-42V485 42 in. EDTV-Ready Plasma...
Can't get picture to fill the screen. Black bars
U have a CRT tube analoge standard tv,this feature will not work for a CRT analoge standard tv.Zoom in and out,picture sizes like 480,720 and 1080.The analoge tv can't get the tv signal ranges beyond 480i that why u have black sides bars picture,if u have a HD TV like a LCD tv or Plasma tv,than the Zooming in feature will works.
May 24, 2011 | Televison & Video
How to zoom in on info
When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
  1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
  2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
  3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
  4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
  5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
  6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
  7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
  8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
  9. Exit the menu when you are done and watch your programming normally.
Feb 04, 2011 | LG Televison & Video
Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
On some channels, the 16:9 channel fills the whole screen (which I want) on othrs, same resolution has grey bars on both sides!! Hate it.
Unfortunately, this has to do with the way each channel is broadcast. Some have gone to 16:9, but some have not (even those in HD--See ESPNHD for one example). Most TVs have a way to "strech" the picture somewhat so you can fill more of the screen, but of course then your image may be distorted. I agree that they grey bars are annoying; I wish they would go to a true black.
Sorry I couldn't be more encouraging. Enjoy your TV!
Sep 13, 2009 | LG 42LP1D 42 in. LCD HDTV
Why do we have black bars on top and bottom of screen
Originally when 16:9 TVs were produced movies were being shot in 16:9 so that you had a full screen. Now they are being shot in 14:9 as it gives you a more cinematic experience. This is due to the fact that colours look more vibrant when they are placed against a colourless/lightless surface (such as a black panel) as for the bars on the side of the screen LuciferStarr is correct; it depends on the format in which the video was originally produced. For example most older television shows are still shown in 4:3 but newer shows and movies are produced in the widescreen format.
Jun 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Just got digital hd
If you press the zoom- button on your remote it will give you options for the screen size. The "stretch" option might help.
Oct 17, 2007 | RCA L26W11 26 in. HD-Ready LCD Television
Computers & Internet Logo
196 people viewed this question
Alun Cox
