Question about Nokia 3110 Cellular Phone
Restarting problem... my mobile get switched off.only till nokia logo is coming.eventhough i had not inserted my memory card...can u plz give me the solution.my mobile model is nokia 3110c
HI, ONCE I ALSO HAD THIS SAME PROBLEM ,NOW MY MOBILE WORKING WELL .
I THINK YOUR MOBILE SOFTWARE VERSION IS OLD ONE SO THAT TYPE SV HAVING SAME PROBLEM,SO BETTER THING YOU MUST REFLASH YOUR SV.NOWADAYS IS 7.00 SOME THING NEW VERSION USING.THIS IS THE FINAL SOLUTION .OTHERWISE CANT .BECAUSE I USED ALL THE WAYS FIRST FORMAT MEMORY CARD,AND RESTORE FACTORY SETTINGS,BUT NOT USEFULL.
TRY IT .
Posted on Aug 03, 2009
Plz tell me how to solve my problem memorycard insert the mobile but show not insert memory card .. handset set is n72
Switch of your mobile then insert the memory card and also check to insert memory card rightly.
Good Luck!
Mar 14, 2011 | Nokia N72 Cellular Phone
My memory card getting automatically removed from the phone giving error msg. uasafe to remove memory card withou selecting "remove mem. card" first......... autometically
hmm...reset ur mobile (w/o mmc) and after that..switch off fone,insert memory card and start.. <even i had same prob but now solved >
Jun 15, 2010 | Nokia N73 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
Phone restart automatically
enge cp poh pde khit anung unit
Apr 18, 2009 | Nokia 3110 Cellular Phone
Lock the MMC
You have to format MMC in Nokia Communicator Mobile.That mobile formats Memory card eventhough it has Pwd.
Feb 17, 2009 | Nokia 3110 Cellular Phone
Nokia E90 forgotten lock code
Option No. 1 is
*#7370# is the code to reset everything, including contacts, sms, emails, all application, everything. But you need the 5 digit security code to do this.
Option No. 2
Since you have forgot the lock code, you can try this thing. Using PC Suit, take backup of your phone contents, then update the phone software.
Option No. 3
Unlock Security Code using Memory Card
Steps to unlock ur sec code.
1. Off Ur mobile.
2. remove battry
3. remove memory card
4. On ur computer and plug in ur memory card.
5. insert ur memory card.
6. unzip the attachment file and place it to ur memory card
e:\system\recog
7. now insert ur memory card into ur mobile and switch on the fone.
8. now if it ask for code type 12345 and ur mobile unlocks.
9. Every times u restart ur mobile it will unlock ur mobiles security code.
Dec 15, 2008 | Nokia N70 Cellular Phone
NOKIA 3110C DOES'NT WORK WITH MEMORY CARD
Dear sir,
I have Nokia 3110c mobile.When i was insert memory card(micro sd 1gp),it was continuously restarting.So please give some solution.
Jul 16, 2008 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
116 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
