Question about GE Zoneline AZ55H07D Air Conditioner
LG heater won't stop beeping
Since we cleaned the vents of our heater it will not stop beeping. any suggestions?
  • 146 Answers
Turn it off for few meaning turn off from the breaker or plug if has one no power! try that!!
Posted on Jun 28, 2009
LG fridge beeping. door is shut. cleaned top of fridge. Thermostat being very sporadic the digital readings are jumping around. water got into the electronics and shorted it out? Suggestions?
I would turn it of put a heater facing where the water got in it and let it dry for a couple of hours .
If you leave it on with water in the electronics you will cause damage to the computer.
If you get it dry this could save it.
Regards Craig
Feb 10, 2018 | LG Refrigerators
LG DLEX2801L Electric Dryer. Won' t stop tumling even when turned off. Only when the door is opened will it stop. The check filter is lit up but I clean it after every use and I have made sure there are...
The breaker won't reset? Or the dryer? If it.s the breaker, it is protecting you from a short circuit and a possible electric shock. Are you sure you want to try to fix this without a professional?
Feb 06, 2018 | LG DLE2514 Electric Dryer
LG Tromm Dryer Won't Stay On!
Your motor might be weakened. As when you start is back does it come on if it does then we are looking at venting issue.
Oct 06, 2017 | Dryers
Thermador CVS36R Cook'n'vent vent won't go down and fan stopped workin
You probably will find that the vent is clogged with grease. A switch device works with the vent so the fan operates only when the vent is open and does not operate when the vent is closed. Things should get back to normal after a thorough cleaning unless the fan is defective and won't operate at all.
Sep 03, 2012 | Thermador CVS236 36" Cook 'n' Vent System...
Dlg2522w gas dryer not heating, cleaned vent, reset, unplugged, still won't heat, motor replaced last year
I tired the reset on the over temp. Did not work. How do I check the igniter/ gas valve and thermostat?
Apr 26, 2012 | LG DLG5932W Gas Dryer
I have a model 640 Reliance water heater. SN # A07A150454 M,F, 01/30/2007. About 3 months ago the water started getting cooler, then won't start. I turn the control up, then it starts, but the...
I believe 640 is typical tank-type atmospheric-vented gas water heater.
Gas water heater problems can get complicated. New heater sells for $350 at local box store.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
If thermostat is not controlling temperature accurately, then (1) gas control needs replacement (2) water heater has sediment build-up (3) combustion and burner parts need cleaning. (4) All three things above, plus additional causes such as bad venting or not enough combustion air.
Usually recommended that plumber replace gas control valve thermostat:
See typical tank-type thermostats:
http://waterheatertimer.org/images/Typical-gas-valve-500.jpg
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Clean sediment out of tank:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Clean combustion chamber and burner parts and troublehoot venting and air supply:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Clean-burner-300.jpg
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
Aug 07, 2011 | Reliance Water Heaters
Dryer tries to start - then stops and beeps PLEASE HELP
Check the exhaust hose. If the dryer isn't venting properly it will either stop or the heater will turn off and the clothes will remain wet. If the hose is not clogged check the wall vent tube.
Apr 29, 2009 | Fisher and Paykel Dryers
Rinnai 557FTR Heater
The heater you have is not sold by RTA INTERNATIONAL. We are the distributor for GARDENSUN patio heaters. From what you say, I would think you have a pressure problem or a bad thermocouple. Check all your fittings by spraying them with soapy water. Be sure you turn on your gas to check.
Check the tip of your thermocouple. Be sure the tip is tapered and not burned through on the tip. If it is, you need a new thermocouple.
Jun 15, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
GE Zoneline AZ55H07D Air Conditioner Logo
188 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
