Question about Toshiba Office Equipment & Supplies
TOSHIBA e-STUDIO450 STATUS
I have a TOSHIBA e-STUDIO450. Some times Printer status is Opening. that time the print and preview screen is not showing(it will take more than 5 mints to open). how can i fix it.? pls help me..
Babumon
Koyilandi
  • ribu_rajan Jun 29, 2009
    Yes, am Using SMB to the printer. my n/wing is Ok, becos i can ping to the Printer and also some times i can print. after some time(like idel ) it showing the status OPENING.
    How can i instal the driver insted of SMB? I dont have the Driver. Is it available in TOSHIBAs Site..?
  • Toshiba Master
  • 653 Answers
Opening means connection to printer is lost, thus u cant print...
Are u running networking with smb to the printer?
If yes, do check your networking and if can, try to install driver instead of using smb.
Posted on Jun 28, 2009
  • didi2005 Jun 29, 2009
    U can download the driver under below websites.
    http://www.copiers.toshiba.com/support/s...
Printer hangs
check touch screen job status. this particular user might not have the setting configured properly on his pc and affected all job queue due to paper size not avail in any drawer or bypass paper needed.
to release the rest of the job queue, just delete the job pn the touch screen. u can see the delete button on the touch screen when u press job status
Mar 20, 2014 | Toshiba e-studio 455 Copier
Offline change
Just go to Devices and Printers from Control Panel, Right click on your Printer and click on See Whats Printing or Print Status, Once you click on it the Printer Spool Window would appear there click on File and make sure use Printer Off line is not checked. If its not checked and you have the same issue its an issue with the driver the Printer has to be reinstalled.
May 14, 2013 | Toshiba E-Studio 3040c Color Copier
My HP Photosmart C6280 asks me to replace the light blue ink cartridge and says it is unable to print until we replace the ink cartridge. We have replaced it three times and the same message appears. The...
Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons.
Display should say "Enter Special Key Combo"
B. - Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
(try both and see which one will get you to system config menu )
display says "enter special key combo"
1. Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
2. Press and release the right arrow button until the display says "System Configuration
Menu".
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to
5. Press and release the "OK" button
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared.
Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the
"Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears.
PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the
printer and wall outlet.
it is now powered down and unplugged.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the
wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer
will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do
not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
Aug 31, 2011 | HP Photosmart C6280 Printer
Hello i have a problem errore in printer hp 8253 errore 0xc18a0206 plase help me tanks
A. - Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say "Enter Special Key Combo"
1. Press and release the right arrow button until the display says "System Configuration Menu". (on C8100 use Touch Screen)
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Oct 31, 2010 | HP - HP Photosmart 8250 printer
HOW DO YOU RESET THE ERROR MESSAGE 0xc18a0207 on an HP 6100 series all in one ?
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
1. Press and release the “OK” button.
2. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
3. Press and release the “OK” button.
4. Display should say “Hardware failure status: Clear. Press OK to clear”.
5. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
6. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
7. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
8. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
9. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
10. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
11. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
If the error is still there, or reoccurs replace the unit
Jul 26, 2010 | HP Photosmart C6180 All-In-One InkJet...
0xc18a0101
A. - Press and Hold the “Print Photos” & “Red Eye Removal” buttons. Release both buttons. Display should say “Enter Special Key Combo”
B. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
Display says "enter special key combo"
Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal” .
If "support COxxFN0723BR" appears with "uiaux" message, perform the below steps:
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status.
5. Press and release the “OK” button
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Apr 21, 2010 | Office Equipment & Supplies
Receive message Printer status is not available at this time when trying to print
Getting "printer status is not available at this time" when trying to print
Apr 09, 2010 | Xerox Phaser 8560MFP Laser Printer
Status bar appears but page turner is missing.
With a multi-page project open on the program workspace, click File in the menu bar and choose Print Preview.
In the Print Preview window that appears, click the Zoom In button and click Close to return to the project. The Page Turner button will now display.
Aug 28, 2009 | Broderbund The Print Shop 22 Deluxe Full...
Error
pleas install status monitor, that will tell you whats wrong.
May 29, 2008 | Konica Minolta magicolor 2400 Laser...
133 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
