Question about Gateway 450ROG Notebook
Dark screen when unit is turned on screen breifly flashes correctly, then goes black. resets didnt help. did not do hard reset. Hi, it wont come on need code.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Re: dark screen
I have a mx6024 that had the same problem. I took off the bezel from the LCD. Under that you'll see a metal frame that holds the Lcd in. Look down to the bottom left side and theres a wire from the power supply should be there. If the wire goes under the frame, lift the frame to slide the wire out.Use a little piece of electrical tape the keep the wire in place and put the unit back together.The frame was shorting out the monitor, I haven't had the issue again since.
Posted on May 18, 2008
Re: dark screen
Sound like you may need a new inverter for the laptop
Posted on Feb 25, 2008
  • 1,006 Answers
Re: dark screen
Hello there:
It seems like ur hdd is not working propertly
or Ram
or VGA check those 3 and if they are ok WRITE HERE back.OK?
Posted on Nov 07, 2007
0 characters
3 Points
I have a Toshiba C850 and when i switch on the laptop it flashes a black toshiba screen and then goes to a blue screen with yellow writing which says Enter Password. It gives three attempts ten shuts
this is either a bios or hard drive code needed for unit to proceed extremely hard to reset sue to the fact that the code is in a non volatile chip.
May 21, 2014 | Toshiba Satellite PC Laptops
Continue reboot loo
There are a lot of possible reasons for this.
1. Fan is bad.
2. Motherboard has gone bad.
Do you still see the Compaq logo when you turn it on?
Jun 10, 2013 | Compaq Presario 700 470024-192 Notebook
Hi when i turn on my laptop it powers up then screen goes black ,in the top left hand corner it says password there is a horiizontal little line flashing and it wont let me type in the password,please...
Sounds like the BIOS password has been set to prevent unauthorized usage. If you don't know the password, you can't use the computer and it can't be reset except by Toshiba.
May 17, 2010 | Toshiba Satellite Pro L300 Notebook
White screen with black vertical hypen lines???
Hi, you should get an update for your graphics driver and the Bios update. After the updates for the driver. Do a hard reset. To do a hard reset. We need to shutdown the notebook. Remove the battery. Remove the power cord. Press and hold the power button for 30 seconds. Do not expect the turn on. That would be weird. Actually we are trying to reset something internally. After this. Test if the issue goes away. Hope this helps!
Mar 04, 2010 | Compaq Presario M2000 Notebook
M-series gateway (m1629) press start button, nothing
Taken apart, looking for abnormal solder etc checked powers switches decided that this unit was acting like it may have shut down due to excessive heat issue. pulled battery on board, tested ok, re-installed everything and found that this unit now is active. Conclusion: I suspect the bios shut this unit down, hard reset correct this issue.
Aug 24, 2009 | Gateway PC Laptops
Acer reinstall issue
Run the same procedure again and choose factory settings. It wd do so , unless the recovery partition got corrupted.
Mar 17, 2009 | Acer Aspire 5100 Notebook
Very, very dark display screen (almost completely black)
What you are describing is the inverter in a the laptop display going bad. The only fix is to purchase the correct display inverter for that model and install it in your laptop display.
Nov 26, 2008 | Dell Inspiron 1501 Notebook
Dell wont come boot
sound like you have corrupted the operatint system u have to redo the hard drive reinstall windows this will help
Nov 15, 2007 | Dell Inspiron 1100 Notebook
Gateway 450ROG Notebook Logo
98 people viewed this question
Top Gateway PC Laptops Experts
Mark Taylor
Mark Taylor
Brian Sullivan
Brian Sullivan
Alex Krenvalk
Are you a Gateway PC Laptop Expert? Answer questions, earn points and help others
