AL01 indicates activation of the anti flood device.
It sounds like water has leaked into the base of your machine. Pull
the appliance out, unplug it from the wall socket and tip it rearwards
about 45 degrees. Drain the water out and once empty the anti flood
should reset.
Try the machine again. If it faults during the test you may have a leak into the base.
Had same issue on FWD80, root cause seemed to be the lower spray unit had unscrewed from base over time and was sitting at an angle. After re-seating it correctly, the AL01 still showed so I did the "tilt 45 degrees backwards" thing. After mopping the floor ... the water leeks from the unit somewhere .... switched it back on, hit reset and it was fixed. Thanks for posting solution!
hotpoint dishwasher aquarius fdw60 starts ok then eco light and fast light flashes and it stops...
(More)
hotpoint dishwasher aquarius fdw60 starts ok then eco light and fast light flashes and it stops working. help
green lights prewash and drying constantly staying on and the machine wont do anything Hotpoint...
(More)
green lights prewash and drying constantly staying on and the machine wont do anything Hotpoint fdw60
