Question about Apple iPhone Smartphone
Cyncing some programs and it turned of and then on with logo only
I was cyncing some programs from icy in 3.0 and then it restarted and it don't want to respond and giving me the apple logo only and the computer and the itunes can't see it....
can you help me solving this problem...
  • 129 Answers
You'll need to restore your iPhone. While this may resolve your issue, you may lose data if you've not updated recently. 1. Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes.
2. Connect iPhone to your computer.
3. Select iPhone in the iTunes sidebar and click the Summary tab.
4. Click “Check for Update.” iTunes tells you if there’s a newer version of the iPhone software available.
5. Click Restore to restore. Follow the onscreen instructions to complete the restore process.
Posted on Jun 28, 2009
How do i do a factory reset on m752
To factory reset: 1. Turn off the tablet 2. Press and hold volume down and power simultaneouly. Hold it for 30 seconds until an Android logo will appear on screen then let go. 3. Scroll down by pressing Volume down and Volume up to select any from the selection. 4. Select Wipe Data/Reset and select wipe data again and wait till it`s done. 5. Go back to the menu and select reboot to restart the system. Once the tablet has been restarted it will all be back to default values.
Bets Wishes
check here:
http://office.manualsonline.com/support/other/tablet/where-is-the-reset-button-on-a-kocaso-m752-tablet-5408896#comments
- Don
Oct 31, 2014 | Kocaso M752 Black WiFi 7" Android Tablet...
Tip
How to make computer to fast or fast boot ?
Do the following to make your PC Fast
Do 1
1. Turn on your computer, and hold down delete.
2. In the BIOS window, look for the Boot Menu option.
3. Choose the QUICK BOOT to turn off memory test
.4. Make sure the hard drive comes first in the BOOT ORDER.
5. Turn off any logo displays.
6. Restart
Do 2
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility,click either BOOT tab.
5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Do 3
1. Click the Start button.
2. In the Start Search bar, type control userpasswords2
3. Load the User Accounts window
4. Uncheck User must enter user name passwords...
5. Click Apply
Do 4
1.Click Start button and load the Control Panel
2. Under the Control Panel menu, click Programs.
3. Under the Windows Defender heading choose View currently running programs
4. Choose Startup Programs from the Category option
5. Remove Programs that you feel unnecessary for startup
Do 5
How to disable this indexing service
1. Click on Start
2. Click Run
3. Type services.msc
4. Select Indexing Service and Double click on it.
Select Manual under Startup Type.
5. Click Stop
6. Click OK
on Jan 03, 2010 | Computers & Internet
Laptop samsung freeze at windows logo startup
Restart with safe mode. Start-Run-msconfig, than uncheck all loading startup programs. (one must be a killer) Restart and go.
Mar 19, 2014 | Computers & Internet
Hide ip easy wont uninstall
Go in to Local Disk, and find Hide ip easy folder (within program files or program file x86) once found the folder, enter the folder and delete the icon with the same logo as hide ip easy, once deleted, Uninstall the file via control panel good luck
Mar 13, 2013 | Easy-Hide-IP
Won't boot in safe mode
Starting an IBM Thinkpad T43 in safe mode allows you to troubleshoot technical issues that you otherwise couldn't. Often when a system has a virus or other type of malicious program, safe mode is the only way to locate and delete the problem. In safe mode, only the computer's essential programs are enabled, and only the files necessary to running the system are in use. Learn how to start an IBM Thinkpad T43 in safe mode using a few fairly easy steps.
1.Close all programs and restart the IBM Thinkpad T43.
2.Press "F8" repeatedly after the IBM logo appears, but before the operating system logo appears. If the "F8" key doesn't work, restart the computer and try pressing the "F11" key repeatedly.
3.Press the "down arrow" key to select "Safe Mode."
4.Press the "Enter" key. The computer will boot up in safe mode.
Sep 16, 2011 | IBM ThinkPad T43 Notebook
My lifebook isnt detecting anything i plug into the usb ports
To enter the BIOS Setup Utility do the following:
1. Turn on or restart your notebook.
2. Press the [F2] key once the Fujitsu logo appears
on the screen. This will open the main menu
of the BIOS Setup Utility with the current
settings displayed.
3. Press the [RIGHT ARROW] or [LEFT ARROW] key
to scroll through the other setup menus to review or
alter the current settings.
Go to USB Features and make sure that the USB Ports are Enabled.
Hope this Helps!
Don"t forget to rate;)
Gary
May 18, 2011 | Fujitsu LifeBook P2040 Notebook
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
Computer boot screen slow?
Do 1
6. Restart
Do 2
2. Click Run
Do 3
5. Click Apply
Do 4
Do 5
1. Click on Start
2. Click Run
5. Click Stop
6. Click OK
Jan 02, 2010 | EPoX EP-8KRA2+ Motherboard
My palm centro was hot cyncing intself
I just googled this issue b/c my daughter got a hold of my phone and somehow (as only an 8 month old can) hotsycned my phone. O
ut of total frustration at the thought of having to replace my phone, I took the battery out and left it on the counter for about a minute. It works fine now.
Aug 04, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
I have a TE-2000 with alogo how do I change it
Hi.
Try this:
Turn key to program.
3 SUBTOTAL
2122 SUBTOTAL
10000000 CASH
SUBTOTAL
That should turn off the bitmap logo. Now just program your own logo using character input.
Mark
Mar 08, 2009 | Casio Parts Cash Register PC Desktop
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
