Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Bad color in photos-Starts out good then goes to very bad
Starts good then goes to bad. Aprox. 1/10 or less of the way across it starts to look faded. Green turns to a light shade of more blue. Face color turns a redish tint.Printer fairly new- New ink both cartridges We have always had problems with printer head either needing to be cleaned or realigned
  • 4 Answers
Have you attempted printing directly on the printer via. pictbridge orthe inbuild card reader? this does sound like a problem with the printhead, or connection to it... try taking the print head out andreplacing it, it would need to be re-calibrated again when you do this,but if there is a connection issue this would most likely solve it. its possible also that the feed through for one colour of ink isslightly clogged or not drawing ink correctly (sounds like yellow)-this would mean that its not able to restock its yellow pallet quicklyenough while printing. you could attempt to clean it out yourself, orif its under warranty, see if they will replace your print head for you
Posted on Jul 02, 2009
Does an old PHD cause faded colors?
the PHD transfers the image to the printed page and when it starts to go bad the images can become dull or faded and even blurry or totally missing. Id recommend the PHD be replaced and it should resolve your issues.
Feb 24, 2012 | Dell 2135cn All-In-One Laser Printer
The ABS break trouble light will come for aprox 8 starts then all will be fine for aprox 20 starts then repeat
Check for loose wires to the ABS module and have the module checked. This could be a bad Caliper but it sounds like it is the ABS module malfunctioning.
Oct 07, 2011 | 1998 Oldsmobile Aurora
On half the screen the colors are faded. when a video is watched on the faded half the colors are really bad
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 26, 2010 | ViewSonic VP230mb 23.1" LCD Monitor
Colors fading away. Replaced cartridges.
I contacted Konica M again. We ran some printing tests. It seems to be bad ink cartridges, in particular the Cyan.
Dec 21, 2009 | Konica Minolta magicolor 2480 MF...
The pilot goes on and stay on but heater doesn't the thermostat its ok
Take the two wires going to the thermostat and cross them. If the unit starts, you have a bad thermostat. If it doesn't, at the heater put a jump wire across the terminals where the thermostat wires are connected to. If the unit starts, one of the wires going to the thermostat are broke. If it still doesn't start you may have a bad transformer. Check for 24 volts AC across the two terminals on the gas valve. If yes, bad gas valve. If no, bad transformer.
Dec 16, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Replaced the alternator and voltage regulator, battery goes dead when lights are on at night. The fan belt is new and properly tightened. Any suggestions
Suggest that you recheck the connection on the voltage regulator!
Next, start the engine and place a good voltmeter across the battery terminals and read the voltage at idle with nothing on.
Next, turn on the headlights and read the voltage. If it drops more than 2 tenths of a volt (goes from 14.2 to less than 14 volts) the regulator is bad. If the voltage is always less than 13.5 with the engine running - chances are that you got a bad generator!!
Let us know!!
Oct 10, 2009 | 1966 Ford Mustang
Faded picture with horizontal lines
Bad CCD.
Video uses only less then 1 megapixel, that's why it's OK
Apr 05, 2009 | Canon Sure Shot Z155 Caption 35mm Point...
Monitor problem
This monitor is bad replacement is the only option as the CRT monitors are obselete you could get a good deal on one if you are not shopping for a flat panel!
Oct 24, 2007 | Samsung 793S 17" CRT Monitor
Sony Kp-51hw40
Sounds like a bad solder connection in the sweep power supply. Not a repair for the novice I'm afraid. If you get it fixed before the set goes out completely, it should not be that expensive of a repair. Good Luck
Jun 03, 2007 | Sony KP-51HW40 51" Rear Projection...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
174 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
