after a hit of my camera 30d every thing is working perfect but thr light meter has the same problem , i will like to know were is exactly located the light sensor to beable to see if it is dislocated or loose, , any one knows were is located or what is the number of the part to locate it on the canon 30d diagram
When I try to view images on a tv the connection in the camera does not hold and the image does not...
(More)
When I try to view images on a tv the connection in the camera does not hold and the image does not stay. When I move the connection to a better connection and hold it the picture will stay if I put pressure on the the camera connection. Canon 30D
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly...
(More)
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly (running water no longer looks "frozen")...any ideas?
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or...
(More)
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or less) OK, so I figure the flash metering does not rely on the same mechanism. Anyone got a clue on how to get to the AE sensor? The location pepeik posted (thanks for that!) does not exactly suggest a way of getting there.
