Question about Samsung RB2155 Bottom Freezer Refrigerator
Samsung bottom freezer model rb195bsbb door doesn't stay shut
How do I find the part that helps keep the door shut I don't know what iit is called only what it looks like other fridge manufacturers call it a door cam kit but obviously that not what samsung calls it cause I can't find it listed that way on any samsung part website right now my freezer is held shut with duct tape PLEASE HELP. thanks in advance steph
catriver
  • 878 Answers
SOURCE: freezer stopped working
Solomonau, it's hard to tell without being there exactly what is going on. I do know however,that in April of 2005 Samsung came out with a bullitin regarding the cap tube. It states that it has been inserted into the dryer incorrectly and can cause no cool situations. This is part of the sealed system which should be covered for 5 years. What you are describing sounds like a partial restriction, which could be taking place in that dryer and cap tube. If you were to post your model number, I would be able to tell if yours was included in this bullitin. You can then contact Samsung and inquire about this service bullitin, Catriver..post back.
Posted on Sep 20, 2006
SOURCE: samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Posted on Feb 26, 2008
ngfam1
  • 639 Answers
SOURCE: Samsung frost free fridge freezer - RL39WBSW
Dear friend,
ngfam at you service! happy to assist!
Sounds like two separate problems!!!
Do not delay!
Call service before you have bigger problems and a bigger expense!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 28, 2008
ghappliances
  • 126 Answers
SOURCE: i need a replacement door
FIRSTLY WHY DO YOU NEED TO REPLACE THE DOOR OF THE APPLIANCE.
MOAHMED
Posted on Sep 19, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
Samsung RB195BSBB bottom freezer not cooling
If the ice buildup was by the pipe just going into the evaporator in the freezer compartment and the suction line going into the compressor is warm to the touch and not cold and/or sweating you are low on freon.
If the entire evaporator was buried in ice, the ice covering is also serving as an insulator and preventing internal temps from going down any further. There is a problem with the self defrosting mechanism which is designed to prevent the ice buildup. Could be either the defrost timer, defrost thermostat or the defrost heating element. Hope that it is just the heater element. If you have an electronic module for the rest you are in for unpleasant surprise to replace the unit. Proprietary parts mucho expensive plus labor.
Until you fix it, just let the unit manually defrost (U can use a hair dryer to speed it up) and turn it back on again. It will work fine till the ice builds back up. Keep opening and closing of freezer compartment to minimum to minimize moisture laden air that enters compartment.
Nov 24, 2013 | Refrigerators
I have a Sears Coldspot chest freezer Model #1869. The door doesn't seal properly and ice builds up within the door and the seal becomes even worse. The freezer itself works fine.
A precut seal will be expensive so please don't expect the price to be reasonable should you find one. Sears uses a longer number to list model numbers like 312.215478 as an example. Where can I find my model number? Let me know if you have questions, Thanks Sea Breeze
Nov 19, 2012 | Refrigerators
Samsung Refrigerator with bottom freezer model # RB195BSBB freezer will not hold temperature. There is a fan running a loud and constantly, and freezer will work it's way down to 8 degrees but will not get...
Check for ice build-up in and around the freezer fan where the blades are, if you can see ice in there (some times it may look like white foam but dont be fooled, it will be ice), the fan will be hitting it, defrost the freezer and check defrost element, (you will have to dismantle freezer section to get to it but reletively simple job) disconect from mains first. Good luck
Dec 18, 2010 | Samsung Freezers
My samsung frig suddenly started clicking (the bell that lets you know the frig door is opened.) checked to make sure all doors were closed but bell keeps ringing and now the temp. is rising inside. what's...
Can you pull the gasket back slightly (flat screwdriver or dull knife, don`t cut/rip the gasket) from the side of either fridge door and tell me if the cabinet light is on inside ? I need to know if the light is on without opening either door.
I`ll watch for your reply.
macmarkus :)
Feb 04, 2010 | Samsung RF265AA Bottom Freezer French Door...
Samsung refirgerator freezing food.
your damper door is freezing fully open between the freezer and refrige compartment defrost it,then adjust the cold control to make sure its controlling the door position,itsound as if your door seals may be letting in warm air that condenses and freezes on things check this too
Jan 16, 2010 | Refrigerators
My refrigerator door won't stay closed!
Don’t mess with this or you could invoke the manufactures warrantee. Contact Customer Services
http://www.samsung.com/uk/support/onlineservice/onlineService.do
Nov 07, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Kenmore - over under
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
Jul 08, 2008 | Kenmore 62832 / 62834 / 62839 Bottom...
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Samsung RB2155 Bottom Freezer Refrigerator Logo
200 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
