Question about Cooktops
I ned to replace one of the heat control knobs on
I need to replace one of the heat control knobs on a free standing eletric fisher paykel stove.
    Novelist:
  • 222 Answers
U can find it only in the service center of the brand u have.
Posted on Jul 04, 2009
What is causing my Fisher and Paykel OR61 Duel element to on work high heat when turned on?
Likely a bad resistor Unit, I suggest replacement before it gets worst and possibley causes a fire.
May 27, 2014 | Fisher and Paykel CT560QX 23 in. Electric...
Fisher & Paykel Thyme main oven not working
You could try reseting the clock to the manual position.
If in Automatic the oven won't turn on until set time.
Mar 18, 2013 | GE JB870 30" Free-Standing Electric Double...
Middle section ticking sound with sparking as if trying to ignite even though knobs aa
see this steps and fix it. God bless yo
Relight an oven pilot:
  1. Turn all controls off, open the doors, and allow gas to dissipate.
  2. Hold a lighted match near the tip of the pilot on the burner assembly. If a burner does not light within two minutes, adjust the pilot, step 3.
  3. Turn the pilot adjustment screw (located near the pilot or the thermostat) in small increments and retest until the pilot has a blue flame.
  4. Check and replace an oven spark igniter:
  5. Turn all of the appliance controls off.
  6. Open the door and remove the oven bottom and the baffle (see above).
  7. Unscrew the igniter from its mounting bracket and inspect it for cracks or other defects. Replace it if it is damaged.
  8. To replace a faulty igniter, find the ignition control module, unscrew the cover, and disconnect the module. Install the replacement part and test.
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
Try using a pair of pliers and pushing down as you turn first counter clockwise as if you are turning the gas on then back clockwise till it won't turn anymore. If it's still trying to ignite see if its the oven or make sure that its the burner that's trying to ignite . I''m not a appliance person just a home maker so if it were me and none of those things work turn off the gas to the stove unplug the power to the stove and call the gas company or appliance center. One thing though some of those type of knobs are two parts like they have to be pressed down to turn on the gas. Or the have to be set in a certain position to engage the ignite switch. If you know a little about wiring look at the switch and check the wires. But make sure before you do anything that there is no gas on.!!!
I have a Fisher & Paykel CE901 36" electric
Sorry, I don't have a solution, but a similar problem. My CE901 is 6 years old. One of the regulators broke after one year. The repair (under warranty) caused an electric fire a couple of weeks later. After much complaining, I got a replacement cooktop from F&P. Now, 5 years later, one regulator stopped working, no longer turns on the element. (I guess that's better than no longer turning it off.) You are not alone. Seems like F&P is incapable of producing a simple regulator that works reliably.
Nov 28, 2010 | Fisher and Paykel 36 in. CE901 Electric...
How do I remove knobs for burners to clean them?
To remove the knobs from the cooktop you just pull them off. They are only presser fitted on a post.
Jul 30, 2010 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
How do I fix a bad igniter on my F&P GC912 cooktop?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 18, 2010 | Fisher and Paykel GC912 Iridium Stainless...
Gas cooktop igniting and lighting but when you stop the igniting the gas does not stay lit
It seems like one of your burners is clogged. You made need to use some oen cleaner and a small toothbrush to clean the burner. If the problem occurs with all the burners, then you have a blockage in the gas supply line. you willm have to take it apart at the stove and clear it out. Check the main gas connection and at the burner(s) to spot the debris clogging. Make sure to shut your gas valve off behind the stove. Good luck... hope this helps.
Feb 14, 2010 | Fisher and Paykel GC36 Gas Cooktop
Stove knobs...
if the model number used for this listing is accurate then you can find your knob here
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1173229&PPStack=1
Sep 28, 2008 | Maytag MEC5430BDS Electric Cooktop
No heat
You probably still have cartridge fuses in your fusebox. This sounds like only one blew. This will let the lights and other 110 volt things work just fine. If you have circuit breakers it probably needs to be replaced. There are no internal fuses that involve the whole stove.
Jun 09, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cooktops Logo
122 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
