Question about Acer Aspire One Netbook 8.9" Notebook
I have exactly the same problem as robert keene
When i power up the fan starts but nothing else happens i have checked the power supply and battery all seems ok i'm not to sure how to go about checking other components like the cpu and ram any help with this would be great
    Scholar:
  • 40 Answers
This is most likely an issue the the mainboard.
The mainboard and ram are not considered user replaceable parts on this model, however if the unit is less than a year old then you can contact Acer support for repair.
Acer's number is 800-816-2237.
This process usually takes 10 business days and as of the last time I checked they do not cover shipping to the repair center.
This is annoying, but is the best option.
Posted on Jun 29, 2009
Acer AM1100-E1304a do not start.
Try removing the battery. It may be the battery is eating all the power that the supply can produce, leaving nothing to run the computer. That could happen with a shorted cell or a completely dead battery. IF the power supply you are using is the correct one for your laptop.
Oct 27, 2014 | Computers & Internet
Intel D946GZIS machine will not start after being reassembled. The green light on the Motherboard is on but after hitting the power button nothing happens
It is more than likely the power supply that is faulty. Newer PSU's have a 5volt supply missing, this means that some older boards will not run with the new PSU's. Try and find an exact match for your older supply but with a better power rating, if that is what is required.
Jun 24, 2012 | Intel D946GZIS Motherboard
I have an Acer 6920 and just yesterday I went to go turn it on with the power supply plugged in and connected to the outlet and the light near the power button flashed orange and my laptop wont turn on....
Sounds like a malfunction in your power supply. I would suggest contacting Acer support and informing yourself about the warranty on your device.
Don't forget to rate this comment - give me thumbs up if you liked this advice!
Mar 13, 2011 | Computers & Internet
When you press power button, computer does not boot up. only orange light blinking on and off.
Possible bad power supply. Unplug and let sit for 2 minutes. If you push the button again, and nothing happens; then replace the power supply.
Jan 06, 2011 | Dell OptiPlex GX620 PC Desktop
I have a T3626 emachine that I replaced the drive.
check all your ground screws on the motherboard. If that doesn't work try booting it up with out the hard drive. if that doesn't work, pop out the BIOS battery and unplug your computer, let it sit for about a min. and put the battery back in and restart.
Sep 18, 2009 | E-Machines Emachine T5026 power supply **...
My computer won't start.
check if the hard drive led is on so its the vid card if not its your motherboard because the fans are still running and its mean that the cpu is working but no activity
Jul 05, 2009 | Computers & Internet
ACER 3100 does not boot
have u tried booting the computer with just the power supply hooked up and your battery out? iv'e had the same exact lab top and the battery went bad and the computer wouldnt do anything at all like your talking about. Even if i had the power supply hooked up and the battery. Remove the battery, and try booting it up.
May 23, 2009 | Acer Aspire 5100 Notebook
Aopen barebone XC Cube does not start
Due to the fact that the clock is working on the front panel I would say you at least have some power
1. If your power supply has 110/220 selection on the back make sure that is set to the appropriate
setting.
2. Check to make sure the power is attached to the board right due to you changing the power supply
make sure that the if the board requires the additional 4 pin and or any others from the power supply
that they also are plugged into the mother board!
3. Check to make sure your switches from the power switch/ reset switch / hd lite / etc are all
properly in the right spot and in the right direction observing positive and negative orientation.
If all these are done and still nothing happens and the fan on the power supply is working you still can due further testing on the power supply using a multimeter and checking that the connectors to the board are functioning properly, if they are and you have done all the above things two possibilities remain, one your processor is installed wrong or not working or as you thought, your board could be malfunctioning..
I forgot to mention that you also have to make sure that the fan's are also plugged into the board properly (cpu fan, case fan, etc) this can also disable your computer from starting!
Note: I am going by the information above, if your computer made a sound or anything else please let me know!
Hope this helps
Dec 08, 2008 | Computers & Internet
Power not on
  • First if you have move the computer recently, check that nothing has moved inside box and unplug cards if any including memery and replace again.
  • Check switch if working, does it turn on if you hold button? If so New switch required.
  • Most common problem: Power supply might be blown, see if the fan is running in the back of box when you start-up. Otherwise you will need to check a few things before you replace with new one. Check that the CPU fan inside box is running. Check that there isn't dust build up on fan stopping from running. Might need replacing. Try also taking out battery and starting up computer. If all else fails you will need to replace power supply with a 500watt or more power supply. If you have another computer on hand, you could try the power supply from that system as look as it has same connectors and try and run with that. If works then you know what to do. If nothing, the motherboard might be gone, or cpu even. Try also taking memory out and replacing. see if runs.
  • Before you give up, unplug all cables to hard drive, cd roms and DVD-rom and try to turn on
Aug 03, 2008 | Acer Veriton 7600GT PC Desktop
No power up
Here was the fix for me. The machine refuses to boot if the video card is not functioning. It should have one long beep however to tell you that there is a video problem. Someone hooked up our speaker incorrectly though! So we got no beeps. Once the speaker was hooked up and the video card was replaced, all is well!
Oct 23, 2006 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Acer Aspire One Netbook 8.9" Notebook Logo
121 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
