SOURCE: 99 Dodge 1500 will not turn over
check the ground connection between the engine block and the battery
SOURCE: truck will not crank with starter
sometimes there is a dead spot on the starter's commutator where the brushes contact inside the starter or it is a bad solenoid
SOURCE: 2002 Dodge Intrepid accessory/starter relay problem?
Accessory position is turning key towards he driver. Ignition on is away 1 and start is away2.
SOURCE: I have a 1992 Dodge Ram Van 318 ci. It died while
I had an intermittent starting problem and then a no start situation in a 1991 with the same engine. Changed the pickup inside the distributor. Less than $30.00.
