Question about XFX NVIDIA GeForce 8600 Graphics Card
8600 gt graphic card not detecting
It was worked for one day and from second day it was not detecting.
I re-inserted it and I checked the BIOS settings, nothing is working, but my on-board VGA is working fine. Fan on the graphic card rotating, when I installing the Nvidia drivers it throws a error message says no such hardware detected.
Thanks in advace for quick resolution.
Youtube
Posted on Jul 10, 2009
My inno3d 8600gt is not being detected.
Try to disable onboard graphics card in bios. You should be able to install the 8600 card.
Jul 27, 2009 | Computers & Internet
Inno 3d Geforce 8600 gt not being detected [Imran]
As far as the detection of your card goes, you need to go to bios setup and check if your 'on board graphics' is enabled, it should be disabled. i can help further if you give your motherboard model number. the problem with the vertical lines may be that there is dust in your cards PCI socket on your motherboard or the pins on your card might have got damaged when you were cleaning them.
Jul 27, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Gt nvidia 512 ddr3 graphic card not detected by my mother bord
If I were you I'd try to insert another geaphics card in the mobo, if it does detect that one the graphics card is broken, if it doesn't try updating bios.
If that doesn't help either, the mobo has failed.
You can try to contact the manufacturer of the broken art, see if they have any tips, but I guess broken is broken.
Sorry,
Yannick.
Jul 13, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
GeForce 8600 GT 256MB DDR3 PCI Express Graphics Card doesn't work
contact the shop / place you purchased it from and they should be able to give you info of where to send it and what to do - they should have a section on there website where you can go through the return process and you will most likely need to get an RMA number to authorise the return / replacement.
Apr 11, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Nvidia Geforce 8600GT no signal
Go back into the BIOS and re-enable the on board video card.
Mar 24, 2009 | Evga e-GeForce 8600GT, GeForce 8600 GT,...
Screen not starting after installing graphics card
Hi rohit1987,
The XFX NVIDIA GeForce 8600 GT 256MB DDR3 PCI Express card uses two DVI ports on the back of the card. Display is most likely coming from the second port. Try moving your monitor cable to the next DVI port. You can do this while your system is running.
If you still do not receive display, post that here & we'll go over some other possibilities.
Good luck rohit1987!
Thank you for using fixya.
Mike
Jan 13, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Hello, Problem with 8600 GT egeforce graphics card
Sounds like the card is defective or your power supply is not hefty enough to drive the new card. Also check that the card is seated fully.
Lou
Aug 10, 2008 | Evga e-GeForce 8600GT, GeForce 8600 GT,...
Black screen no signal
replace the graphics card, ours was going black here and there the last few months then finally it didn't work at all, we just replaced it today and the new graphics card (ati) works fine.
Jun 07, 2008 | Evga e-GeForce 8600GT, GeForce 8600 GT,...
Geforce 8600 GT Broken down?!
Have you tried the non functioning video card in another computer?
Did it work?
If not, replace it.
If yes, have you tried taking the card out and reseating it? This will be done anyway if you try it out on another computer and then put it back into yours.
Is this card one of those that require a separate power feed to it? Is this connected? Does the lead join the harness up near the Power Supply or way down near the end of the harness? (this makes a difference to the amount of power available and can cause the video card to malfunction if the voltage is too low).
Sorry I don't have an immediate answer, there are too many variables.
Good luck.
May 08, 2008 | MSI nVidia GeForce 7600GS 256MB Dual DVI...
XFX NVIDIA GeForce 8600 Graphics Card Logo
666 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
