Question about Power Acoustik PEQ-70 7-Band Car Equalizer
How to wire an eq to car stereo without an outboard amp?
Sony CDX-CA400 car cd player/receiver what wires go to what? I have power wire and ground and power antenna wire hooked up to receiver but there are four more wires labeled,(high input right - right +)high input left - left+.my ? is can I hook the eq to for speakers without having an outboard amp hooked up to the eq? out put from receiver to input of eq and then what do I do next? Thanks for any info in regards to this.
  • 578 Answers
No those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Posted on Jul 07, 2009
I am trying to remove the CDX-CA400 from a Ford f450 chassis--without success. I have used a screw driver in the slot on the left side but it doesn't dislodge. Advice?
You need a radio removal kit which has the two tools to press the buttons on each side which are in the tiny slots and will allow you to slide the radio out.
Aug 12, 2010 | Sony CDX-CA400 CD Player
After market stereo installation help
You'll an stereo install kit. I comes with the surround for the new stereo to fit into, and that will fit into the space for the stereo in the dash, this kit will also have a connector to wire the new stereo to, and plug into the stock stereo plugs.
Jan 03, 2010 | Sony CDX-CA400 CD Player
Find remote wire connection for sony cdx ca400
Should be a blue wire with a white stripe in the plug that goes into your unit if its missing take the harness to bestbuy or an audio shop and they can prolly stick a wire in the empty spot. hope this helps you.
Sep 16, 2009 | Sony CDX-CA400 CD Player
Is there a way to connect my IPod directly to my after-market Sony CDX-CA400? If so, what part do I need?
if there is no i pod input on the unit you need to buy a fm modulator to do it
Jul 01, 2009 | Sony CDX-CA400 CD Player
I need to hook up cd player
something i found today on google. hope it helps.
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
May 09, 2009 | Sony CDX-CA400 CD Player
CDX-RA700 will not get power from my Honda Civic
Automobiles use Direct Current "DC" and is very dependant on a good ground. The black wire from your stereo should be the ground and needs to be attached to the chassis "metal part of the car". You can use an ohm meter to check for grounds by placing one lead on your door hinge (unpainted) and the other to where you are connecting your ground from the stereo. Be sure that this wire does not have voltage on it with the key off, on acc, or in the on position or you could blow a fuse or damage your equipment. Besides that make sure that you have 12v constant to the (usually red wire) and switched (voltage only with the key on) to (usually the yellow wire). Hope that helps. It's mostly about the ground.
Mar 10, 2009 | Sony CDX-RA700 CD Player
Installing a CD player in '08 Aveo in plac eof stock AM/FM radio
You should check with Car Toys or Best Buy but you will probably need an adaptor and a wiring harness. If your doing it yourself your going to need to know how to get the stock radio out and the wiring diagram for the Aveo. Sometimes you can find the wiring diagram on Google by searching for it but usually finding diagrams for 2008 vehicles takes a year or two before it becomes available.
If your CD player has a tuner in it already you shouldn't need one. If it doesn't have one, that presents some other options.
Jun 22, 2008 | Sony CDX-CA400 CD Player
SONY EXCD-206 December 1996
I have the same radio, the radio's harrness has a red wire ignition 12 volt,yellow battery 12 volt, black ground, and a blue Iam not positive it can be the amp, or illumination.
Nov 18, 2007 | Sony CDX-CA400 CD Player
Power Acoustik PEQ-70 7-Band Car Equalizer Logo
1,075 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
