Question about Dell F3534 Touchpad
Dell Inspiron 600M Touchpad stopped working
My laptop went beserk suddenly. While IE was open, moving the touchpad seemed to result in other system processes turning on / off - for example, my wireless radio antenna was disabled, which luckily, I found out from the Help notes could be reenabled with Fn-F2. However, the next time my laptop went beserk, the wireless radio antenna quit working AND my touchpad quit working. I plugged in the USB mouse and THANK GOD that works! Not sure what the problem is. Laptop does overheat, so have it on frozen lasagna right now - with towel in between laptop and lasagna. It also didn't have updated AVG virus protection so am downloading that now too and will run in just a moment to make sure I don't have a virus.
Any other thoughts on how to restore the touchpad? Also, I'm using Firefox, not IE since each time computer went beserk while I had IE open.
  • 390 Answers
Hi
first things first, do take ur laptop off the towel (as this blocks air flow) and place it on a flat surface but slightly elevated to allow better air flow, a better alternative is a notebook cool pad.
now coming to the touchpad issue
download this utility from the support section of dells websight, it gives u loads of option for the touchpad and lets u turn
of the tapping to double click!!
tp2aa09i.exe
hope this helped
cheers
pls rate the solution
Posted on Jun 28, 2009
How to adjust touchpad sensitivity on dell inspiron 1525
Open Control Panel, Mouse, I don't know your OS?, OR, in the Tray Notification Area, open the Touchpad software Icon, maybe synaptics touchpad, settings, sensitivity Take a look at the Dell forum: http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=cmu&k=adjust+touchpad+sensitivity&rpp=12&p=1&rf=all&nk=f&ira=False&~srd=False&ipsys=False&advsrch=False
Feb 08, 2013 | Computers & Internet
Dell touch pad not working
The touchpad on a Dell laptop is usually located under the keyboard. Moving the finger on the pad moves the pointer on the screen. The buttons near the pad act as a right and left click. Windows includes a method to troubleshoot the touchpad. In addition, if the touchpad is still giving you issues, Dell recommends draining the "flea" power the standby power from the computer to restart it. Both methods are simple and only take a few minutes.
Open the control panel from the Start menu. Click on "Mouse." This will open a window with several tabs. On the first tab, click the touchpad to open a new window to change the settings for your touchpad. You can customize the settings to how you want your touchpad to work. If this does not solve your issue, proceed to the next step. Click the Hardware tab on the screen that pops up. Select the Dell Touchpad and click "Troubleshoot." A new window will open with the Windows Help and Support Center to bring you through methods for troubleshooting the touchpad. Follow the methods described until your touchpad is working properly. Drain flea power Shut down the laptop and disconnect all external devices, such as a thumb drive, headphones and the AC adapter power cable from the system. Take the battery out of the laptop. Hold down the power button for at least 5 seconds without releasing it. Return the battery back to the laptop. Power the system on. If your touchpad still is not working properly, call Dell for customer support.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=59EB83ED2E4B1243E040AE0AB7E1468E&doclang=en b> Dell Inspiron 1525 Touchpad That Is Not Working
Turn your Inspiron 1525 off and remove any power cables that are connected to the device. Close the computer, turn it over and slide the battery lock button down to release the rectangular battery from its compartment on the underside of the computer. Turn your laptop right-side up and open the computer so the monitor is facing you. Insert the tip of your flat-head screwdriver in the seam between the plastic keyboard guard and the side of the computer. The keyboard guard is located just above the keyboard. Pry up on the guard until it pops out of place. Be sure to do this gently, as you do not want to damage the guard. Remove the guard from the computer and set it aside. The two keyboard screws will now be visible underneath where the guard used to sit. Use your Phillips screwdriver to remove the two keyboard screws and use the tips of your fingers to lift the keyboard up from the top. Place the keyboard facedown over the touchpad and locate the thick connector ribbon that runs from the motherboard inside the computer to the back of the keyboard. Use your fingers to gently unplug the ribbon from the back of the keyboard and set it aside. Insert the tip of your screwdriver in the seam at the bottom of where the keyboard used to rest and gently pry it up. This will release the top plastic frame from the Inspiron, revealing all of the broken touchpad. Use your fingers to disconnect the thick ribbon from the side of the damaged touchpad and slide the touchpad out of the Inspiron. Slide the new Touchpad (available from your Dell retailer or online) in its place, fit the top frame in place and reassemble the computer in the reverse order you took it apart in.
http://www.insidemylaptop.com/replace-damaged-keyboard-dell-inspiron-1525-laptop/ Replace keyboard in dell inspiron
Feb 01, 2013 | Dell Inspiron 15 (N5050)
Dell Inspiron N5040 touchpad not working while charging
If battery works and ac adapter has problems that means electrolytic capacitors maybe dried up(not supplying the current needed to run the laptop) and has to be cured by using the laptop more often.
Apr 13, 2012 | Dell Inspiron Computers & Internet
Unlock the mouse in dell inspiron m5030
1) Examine your "Function"/"F" keys and look for a touchpad icon. If you find one, hold the "Fn" key and press the touchpad icon button to unlock the touchpad. Move on to Step 2 if your laptop doesn't support this feature.
  • 2) Plug a USB mouse into an open port on your laptop. Click the Windows "Start" button. Click "Control Panel" in Windows XP and double-click "Device Manager." Type "Device" in the search box in Vista and Windows 7 and click "Device Manager" from the results.
  • 3) Click "+" next to "Mice and other pointing devices." Right-click the touchpad and select "Enable." Your touchpad is now unlocked.
  • Feb 06, 2012 | Dell Inspiron M5030 Laptop
    My touchpad on my dell 1548 has stopped working
    It could be you may need to reinstall the driver for your touchpad or the touchpad itself is bad
    Nov 10, 2011 | Dell Inspiron 1545 15.6-Inch Laptop...
    Dell Inspiron 600m touchpad.
    Start by uninstalling the touchpad drivers, don't reinstall them as there is really no need for the drivers unless you want to use the scrolling features.
    Then I'd also check the hard drive for bad sectors, volume errors and fix them. This is because if the hard drive is holding data like video drivers, touchpad drivers or any other information on a part of the drive which has bad sectors then the operating will start to act up like freezing, taking a long time to boot up etc.
    If you don't find any errors on the drive then it is a possibility that the operating system itself has become degraded.
    All you have to do to fix the problem is start as if you was going to reinstall XP, but when you see the option to repair the operating system choose that (not the recovery console option), that way any data stored in My Documents folder will be left untouched.
    Good luck and please post back if you need anymore help or advice.
    Regards.
    Nov 24, 2009 | Dell F3534 Touchpad
    Have a Dell Latitude laptop and the touchpad just stopped working
    For some reason most latitudes have this problem, I don't know why but its some problem with both the software and hardware setup.
    Sep 27, 2009 | Dell F3534 Touchpad
    Stuck cursorDell Latitude D600 laptop.
    using touchpad or external mouse..I would check into updating the drivers for the mouse
    www.aa1consulting.com
    Jul 26, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
    Dell Inspiron 6400 PC Notebook-touchpad working erratically,help!
    i cant figure out how to turn on the croll for my inspiron 6400 touch pad
    Mar 05, 2009 | Dell Inspiron 6400 Notebook
    Dell Inspiron 600M Keyboard Replaced, now touchpad doesn't work
    need to pick up the keyboard and make sure the ribbon cable to the mother board is fully seated. if it is. then the touchpad need to come out and clean it very carefully. the sugar and any sticky substances need to be clean off the machine, around the touchpad.
    I hope the drink did not damage the touchpad.(it is heat senstive)
    if it still don'e work aft reinstalled it. you need to call dell to get a replacement.
    Nov 13, 2008 | Dell F3534 Touchpad
    Computers & Internet Logo
    831 people viewed this question
    Alun Cox
