Question about Mitsubishi VS-50607 50" Rear Projection Television
Dark at start up, lines on top
AT start up, the picture is dark and takes a few minutes to lighten up. Also thers lines on top that take about 20 minutes to go away.
  • adobestores Dec 17, 2007
    black line across top and bottom about three quarters inch thick, how do I adjust vertical on this set?
  • Anonymous Dec 27, 2007
    where are the c2p04 c2p05 located do you have a picture
  • 3 Answers
Replace Capacitors in the 9V regulator circuit..100uf 16V & 47uf 50V..May be listed as C2P04 & C2P05
Posted on Nov 24, 2007
I have a magnavox 55 inch screen model nu is 6p5440w102. Picture is dark tried to lighten but wont brighten up anymore.
This is an older set------with back off you will see 3 large black cylinders with lens---these are the red, green and blue picture tubes.
Clean the lens with a lens cloth or paper towel with glass cleaner sprayed on the towel.
Annual cleaning of them is suggested as dust or dirty lens will cut down the brightness---this happens gradually over time and will make the picture darker and somewhat dull looking.
I do it with set on but you should UNPLUG SET and just look to see if dust on lens.
Simple and takes only a few minutes.
Let me know what happens.
Steve
Mar 01, 2012 | Philips Televison & Video
I have a toshiba dlp, replaced the ballast and the lamp. Now the problem is when i put the tv on it takes a while before i get a picture, It starts off very dark then will lighten up gradually. What can be...
It is normal for your TV to take a few moments to reach a brightness level that you can enjoy. A typical Mercury vapor lamp will take amout 2 minutes before it reaches it's optimal brightness. It will continue to increase slightly about 10 minutes longer, but you will not see those subtle changes. So, your TV is functioning as it should, just enjoy the show. If you want to learn a little more about the Mercury Vapor lamp it your TV, please check out my Tips & Tricks. I hope this was of some assistance.
Mar 27, 2010 | Toshiba 52HM95 52" HDTV Projection...
Picture left of center bad on start up
Sounds like a bad display panel to me. Have you tried it with component input, or hdmi??
Aug 26, 2009 | Sony BRAVIA KDL-46W3000 Television
Colors trail behind motion in picture...color too dark
replace T-con board ( top centre of lcd panel ) lvds cable plugs into this
Jun 06, 2009 | Sony BRAVIA KDL52XBR2 Television
Scans slides too dark.
maybe the slides are too dark, in other words, the pictures you took didn't have enough exposure therefore you it shows up dark.. You could always use photoshop or someother photo manipulation software to lighten the scan, same thing happens with my hp scanner with slide adapter, if it slides just show up dark, lightening it with software will help, unless it is unsaturated/shadows too dark, etc..
Hope this helps.
Nov 11, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Sony tv KP-57XBR10W
Correct ! One set is for RGB focus and the other set is for
RGB screen voltage............................T.
Oct 05, 2007 | Sony KP-57HW40 57" Rear Projection...
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Toshiba 42wh36p problem
you tv problem intermittent the problem is in the color circuit, vertical circuit.have a tech check your tv for repairs.good luck.
May 18, 2007 | Toshiba 42H83 42" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
