Question about Amana ARGS7650 Electric Kitchen Range
Amana range will heatup then turn it's self off
Range is about 4 yrs old, came with house. oven will heat up then turn itself off displaying I'm assuming a fault code F3. It won't do it all the time. Have any suggestions?
  • manningoven Dec 16, 2007
    Same problem. Our oven is about 8 years old, came with the house.
    Sometimes when we bake the oven turns itself off and gives various messages. Mostly F2.
    A year or so ago a repairman replaced the electronic oven control. It cost lots of money ant it didn't help much.
    After calling the company, Amana suggested we unplug the oven to reset it. This is hard to do, as the plug is in the back of a built in oven. Must remove the drawer, lay on the floor, etc. Baking is very difficult since have to "babysit" the oven to make sure it doesn't turn off.
    Do you think we need a new temperature sensor and can we install it ourselves? Amana ARGS7650 Model
  • Anonymous May 10, 2009
    my oven is heating up and its giving me a very hard time to use my oven,its a headache.the panel gets realy hot to handale.HELP PLEASE
  • 473 Answers
F3 F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Oven temp. sensor needs to be replaced. You should be able to look at diagrams with the model # for part location @ or The sensor looks like a rod about 4-6 inches long and mounted to the back wall inside the oven. Some can be pulled out from insided the oven by taking out the two screws. If no screws then you will have to pull the oven out and remove from the back.
Posted on Nov 07, 2007
What dose F3 code mean
Amana Appliance Fault Codes - PartSelect
Fault codes for Amana ovens, range, stoves including dual convection wall overs and 'big ovens'. ... F3-1 - Oven Temperature Sensor/Circuit Failure - Check wire connections and ... what does it mean when the oven turns off and f3 shows ... My Amanaagds902ww gas range flashes "Door" when attempting to light the oven.
Amana Gas oven Fault Code F3 - Appliance Repair Forum
Nov 17, 2010 - 2 posts - ‎1 author
Have a Fault Code F3 display on oven when trying to set oven ON. Researched ... Yes, your F3 code would indicate a sensor circuit problem, Jenn-Air Electric Range Code F3
Mar 15, 2011
Range keeps giving error codes E0/F3 and E4/F3 and the ...
Nov 22, 2010
Replaced Sensor Still Getting F3 Error
Sep 20, 2008
F3 Error code on whirlpool Range
Sep 10, 2007
More results from
Amana Fault Codes - Appliance Help O
Dec 25, 2015 | Amana Kitchen Ranges
Replaced oven light and now oven won't work
Does the light work? Will it heat if you remove the light?
Nov 24, 2012 | Amana ACS7270AS Electric Kitchen Range
Electric oven and stovetop do not work, clock and oven light do.
Sounds like you are only getting 120 volts instead of 240 volts. Either a house electical problem or wiring in range. First go to your breaker and turn it off and on three times and give it a little extra push each time you flip it. ( You can actually flip a breaker off and on without resetting a blown breaker if you doni't push it all the way off and all the way on. If the breaker throws itself off do not reset it. You have an elecrical short in your house or range. If resetting the breaker does not work then you need to test for 240 volts coming into the range. We don't recommend you do any electical testing unless you know what you are doing with electicity. If you have 240 volts going to the range then unplug your range and remove the backing panel off the back of the range. Look for burned wiring or terminal blocks. If there is nothing obvious then you need to know how to read a wiring schematic and use a electical tester to go any farther. Let me know if this helps. Good Luck, Appliance Specialists
Dec 15, 2009 | Amana AER5715QAS Electric Kitchen Range
Amana range -the oven does not work, but rest of stove is working.
If the oven isn't working it is either the oven thermostat or the element. If the light and fan comes on to show it's heating but no heat appears, check the fan oven element on the back wall behind the panel. Usually 4 screws.
Dec 11, 2009 | Amana AER5725QA Electric Kitchen Range
I have a GE self-cleaning radiant range about 13 years old. The self-cleaning feature doesn't work anymore. The latch doorlight, even though set correctly to the right,keeps flashing on and off and the...
It could be a micro switch in the latch mechanism not communicating properly with the display circuit board, or it could be the circuit board itself. The switch might cost 20 or 30 dollars, but the board could be hundreds. Kinda costly if you ask me...
Mar 13, 2009 | GE Kitchen Ranges
Tappan gas range TGF364 not heating properly
try changing oven senso located in the oven cavity (upper right or left). its approximately 4-6" long and has a plug-in on the back of the oven
Mar 11, 2009 | Tappan TGF364AS Gas Kitchen Range
No burner/oven heating after house power outage.
try reseting the clock as lots of ovens will not work untill clock is set
Jan 19, 2009 | Amana AER5515QA Electric Kitchen Range
Amana ARGS7650 Electric Kitchen Range Logo
303 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
