Question about Coleman Heating & Cooling
When we turn on the central air there is a strong burning smell...like burnt toast but way stronger. IS it safe to remian in the house?
  • 614 Answers
Is your central air furnace or electric heat. Electric furnace sometimes have electric strip sequencer stick in the closed positions leaving on one strip of the electric heat. Get a service tech as soon as possible to check this out. Any smells from a central unit need to be teken care of promptly. TURN OFF unit you have it checked for your safety. Rus
Posted on Jun 28, 2009
Changed heating element. Clothes are now smoking if I stop the dryer in mid cycle. Burnt smell still pretty strong
Clean the entire lint parts even the hose in the back and male sure the hose isn't open side Dow under house. Air isn't escaping had same problem. Turns out the house was straight down n the dirt under the house
Feb 14, 2013 | Dryers
Smell gas when I turn on the heat
Contact your emergency gas people ,you have a serious problem and if left can kill,seek professional assistance now.
Jan 20, 2018 | 2004 Chevrolet Impala
Strong burning smell coming from vents and from inside rheem electric central heat. Smells like rubber burning.
You must have to open it, try to clean it..and check for some eletric cables with short circuit or bad cables burning and overheating...check the motor fan and if it has a bad AC capacitor
check the photo, and you will have an idea.v4ndre_0.jpg Good luck!
Dec 06, 2010 | Heating & Cooling
At higher speeds, when I push on the accelerator to accelerate the car will not increase in speed yet the rpm's while rev very high. Today it happened when I was climbing a hill and I noticed a very...
if you have a manual transmission , its likely the clutch
is toasted , if automatic , smell and look at the color
of the fluid , burnt smell , dirty red?
Likely a clutch band/s , burned up.
Aug 28, 2010 | 2000 Saturn SL
The unit works as of right now...but there is a smell of something burning
Quite often, if you smell like a plastic burning smell, one of the capacitors is faulty, and should be checked immediately. Quite often the compressor start capacitor, will get hot and start to melt. Have it checked by qualified technician or electrician, as they are dangerous and can give a fatal shock if not experienced with handling them, even when power is shut off. $20-$30 part, and 1/2hr. labor should take care of it. The cover on roof unit, has to be removed to access the capacitors, so watch for bees, wasps, when you do so. Make sure power is off at breaker panel.
Aug 01, 2010 | Coleman Heating & Cooling
Brunt smell and sweating
Seems like your blower motor is burning up. Its the motor that blows cool air across the refrigeration coil. If it is a whole house ac unit, probably your main blower motor for the furnace. If you are getting sweat, that means the compressor is compressing the refrigerant, and you should not smell anything from the outdoor unit, only from the furnace. Hope this helps.
Jun 04, 2009 | Goodman CKL24AR24 Air Conditioner
Bad chemical smell coming from the new Kenmore toaster.
I would say return the toaster. No telling what kind of fumes would get into your toast -- toasted bread is like charcoal -- it'll absorb a lot of stuff.
I agree with the China/USA sentiment.
Apr 21, 2009 | Kitchen Appliances - Others
Burt Toast Smell while running heater
This is caused by in most cases dry tree leaf getting particles into the heating duct through the air intake at the base of the windshield, this material contacts the red hot blower motor speed control resistor and burns, and yes it smells like burnt toast, in order to clean this stuff out u need to remove the blower motor, the material will be in the duct near it. I have seen this cause a fire, so get it checked and cleaned ASAP.
Dec 04, 2008 | 2000 Mercury Sable
Heating & Cooling Logo
371 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
