Question about Canon Office Equipment & Supplies
How to clear the error e000002-0000 - Canon Office Equipment & Supplies
  • 10,515 Answers
I am happpy to have helped you before. My concern is that this error code (E002) is also a fuser error code. The E003 you had experienced before Had to do with an error concerning monitoring the temperature of the fusing section. The "fuser " is a high voltage, high temperature and high pressure area that is responsible for taking the toner (which consists of carbon black, polymers(plastic) and other crud that apparently the EPA and OSHA do do not require absolute specifics on and through heat and pressure bonds this powder of "stuff "to the paper. Because the the heat in this area approaches the temperature of combustion it is monitored in many ways. If the temp does not reach the proper degree in a fixed amount of time......error code. If the temperature swings high or low, whether under operation or not....error code. And we are talking milliseconds of differential. It is because of the danger to property (and more like lawsuits) that every little aspect of the fuser is failsafed. And the monitoring of the fuser is so precise that even a fluctuation in line voltage,( which is used to calculate an algorithm) can cause an error. In fact , fluctuations in the line voltage is a primary cause for fuser errors. I can help you reset this code as well. But the fuser for your machine is basically good for @ 150K. It also has limited serviceability It can be seviced but I strongly suggest that the entire unit be replace if it is close to 150 k. Now, lets try to reset your code and then you can make the call depending on what options you have. But please remember that if you are in an area that the line power you have is suspect...... then you neen to write this sequence down just in case that its just power fluctuations.Ok , here we go. Press "additional functions"......then press the numbers 2and 8 at the same time, then press additional functions again. This will put you into service mode......typically used by only trained field engineers. The new menu you see will look wierd as it will be blue and have several "boxes" on the menu with "COPIER" at the top of the list.Touch copier and it will highlight, then press "ok" at the lower right corner. This will summon a new menu which will have several tabs at the top. Of those tabs prees "function". Now there will be many items listed in the main field of the screen. One of the items will be "CLEAR". Press it, it will hihglight. One of the options will be "ERR". Press it, it will highlight. Press "ok" located at the lower right corner. The copier will not acknowedge that you have done so so dont expect whistles and bells. :-) Now, press reset until you get back to the main(I'm pissed off screen) which wll again display the error code. Now reach around the right side at the back, slightly below the halfway point and you will see/ feel the rocker switch that is truly the main power and shut it off. Wait 5 secs, and power it back up. The copier will attempt to reset itself and probably will. If it does then cool. Please remember, poor power can cause this problem, and if the meter count is close to, or exceeds 150,000 copies just buy (request) a fuser.
Thanks.
Posted on Jun 28, 2009
How to clear e000067 for canon irc2880i copier
Are you looking for Canon printer support number to sort out issue related with your printing machine? We also provide the Canon Printer customer Support, Canon Pixma Support Number, software installation, software upgrade, cartridge jam, paper jam issues and much more. Canon Pixma Printer Support
Jan 18, 2016 | Canon Office Equipment & Supplies
Ricoh error sc541
Fuser Error. Check fuser thermistor. reset fuser error. go to service mode press clear modes, 1, 0, 7, hold clear/stop. once in service mode turn off main power switch on the left side. turn back on.
Aug 05, 2014 | Ricoh Aficio Mp161 Copier Photocopier Copy...
Clear error on office depot calculator ks-1000
Usually, you press the AC (All Clear) button to clear an error.
Jul 31, 2012 | Office Depot KS-1000 Calculator
Error E00062-0003 and error E602-0008
fail of hardisk.
you must change it with the same model of copier.
but sometimes of my experience. I clear error than I clear file in mailbox.
do you know how to clear error ?
and I m sure you can clear file in mailbox.
Jul 19, 2012 | Office Equipment & Supplies
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
Have an Error 51 on Brother MFC-210C all in one printer?
I can help you with your Brother MFC-210C error 51 problem.
Error 51 refers to a paper jam error.
Clear the paper jam to clear the error code.
If the error code will not clear after clearing the jam, resetting and powering off, the printer may require service.
I hope that helps.
Aug 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
System error E000 how do I fix it. I tried what it said in the instructions to turn it off for a while then turn it back on that didn't help. Canon NP6025 copy machine.
To delay the 3 second shut down and enable the technician to access service mode; open the front door and pull out the transport unit. Do not actuate front door microswitch. Press the service mode button, enter " * 4 * ", scroll to error clear and clear error code. Machine will automatically turn off power after clear. Power up machine and test.
If the power shuts down after error code has been cleared, the cause of the error has not been corrected. Correct cause of error code and clear error in service mode.
May 07, 2009 | Canon Office Equipment & Supplies
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Canon Image runner photocopier
It is very easy... What code is it? It may not be resetable with out replacing a part... Need more info...
Jul 07, 2008 | Canon imageRUNNER 210S Copier
357 people viewed this question
old marine
old marine
