Question about Toshiba Satellite Pro 4600 Notebook
Toshiba Satellite Pro 4600 says "D drive is low on memory"
"My Computer" shows both a "C" and "D" drive. "C" drive is 15g's and I have formatted so it is basically empty. "D" drive is 4g's and shows all but full. I have tried deleting everything that the computer will let me to free up space but everytime you use the computer it loses memory. Is the only drive in the laptop located on the back cover and then partitioned for 2 drives labels? This is my first go around with working on a laptop but have worked on desktop units. Thought they would be similar but maybe not. Yes ... I have done a clean-up and a defrag although the computer tells me that there is not enough room to do a defrag because "D" is full. Is there a way to copy "D" to "C" and just run the operating from the "C" drive?
  • Toshiba Master
  • 32,281 Answers
The laptop contains only disk drive, no room for a 2nd drive. You have a 20Gb hard drive and it is partitioned as 2 drives.
You may be able to Ghost the D drive and put the disk image on the C drive, but it may work and boot up on the C drive..
Setting up a laptop is no different in setting up a desktop computer except a little bit more work is involved in installing the device drivers. The device drivers are specific for the version of Windows just like a desktop, but you need to download the drivers specific to your model laptop from the Toshiba WEB site
Normally you would install the Windows operating system on the C drive together with the programs etc. and the D drive to hold your data files.
If you have installed Windows operating system on the D drive and the laptop bootup OK and you don't want to reinstall Windows on the C drive, then I would put the Swap Page file on the C drive. This should free up enought diskspace on the D drive to do a Disk Cleanup and a Defrag. I would also move your data files from the D drive to the C drive to give you more space on the D drive.
If it was me, I would re-install Windows on the C drive, together with the drivers and programs etc.
Posted on Jun 28, 2009
Toshiba Satellite Pro 4600 laptop
Just put the Recovery Disk in the drive and the system should start booting from it. If not, pay close attention to the screen and when it shows you which key to hit to change the boot order or boot sequence hit it. Change the boot sequence to read from the CD drive. This is a temporary change on the boot sequence.
If you want to make a permanent change to the boot order or boot sequence you will need to hit the key that says enter Bios or System Setup and change it there.
Apr 25, 2012 | Toshiba Computers & Internet
Hello, is there any difference between various Toshiba Satellite Pro 4600 motherboards? Would it be hazardous to buy one of those old models to replace another (unfortunately dead) Mb? (got a PIII750...
They are the same.
The Toshiba Satellite Pro 4600 is a model series.
Hazardous? In what way? Solder joints containing lead?
I don't have an exact Service Manual to give to you. But if you look through these, you should be able to find enough information to disassemble your laptop.
1) http://www.irisvista.com/
2) http://www.irisvista.com/tech/
[I found this in a search just now. Wanted to see if it used a mobile Processor or Desktop Processor.
{Uses mobile}
http://www.pchub.com/uph/model/0--2424-1/Satellite-Pro-4600-parts.html
Page 3 shows the motherboard ]
Nov 24, 2010 | Toshiba Satellite Pro 4600 Notebook
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
Toshiba Satellite Pro 4600 Says D Drive is Out Of Memory
One can only venture a guess on this one: your hard drive is partitioned into C: and D:. Physically, there's only one drive, but it might have been split into 2 separate partitions. I'd go from there.
Jun 28, 2009 | Toshiba Satellite Pro 4600 Notebook
How do i format satellite pro 4600
Caution: formatting the will lead you to loose all the data on your computer.
To format the drive you need to boot from the cdrom/dvd drive
to boot from the cdrom/dvd drive you will need to chnage the boot sequence you will need to tap the F2 key at the toshiba logo and here you can change the boot sequence or try tapping the F12 key at the toshiba screen to enter one time boot menu here you can select the drive you want to boot from for one time only and to reinstall windows here is one helpfulll ink
http://www.windowsreinstall.com/
Further queries are welcome
Please do rate me if you find my solution helpfull
Mar 17, 2009 | Toshiba Satellite Pro 4600 Notebook
Password for windows 2000 on a toshiba satellite pro 4600
burn it to a disk put it in the disk drive turn off unit then fire it up and hold down the f10 button choose from cd and follow the instructions if you can not succeed then go to best buy spend 29.99 and have the geek squad reset it for you.
Jan 28, 2009 | Toshiba Satellite Pro 4600 Notebook
Lost installation cd
ask toshiba to send one for a nominal fee.
Nov 29, 2008 | Toshiba Satellite Pro 4600 Notebook
Please refer to THIS SITE for help with your issue.
Jun 10, 2008 | Toshiba Satellite Pro 4600 Notebook
Toshiba Satellite pro hl-dt-st dvdram gma-4082n
goto program defaults/media player/disc insertion= and choose the options you require. Or goto computer-cd/dvd drive and choose the program you wish to run the disc
Dec 10, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite Pro 4600 Notebook Logo
268 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
