Question about Ruud UBHC Air Conditioner
Buzzing noise fan is on
Buzzing noise..... every 30 seconds fan is on
    Novelist:
  • 166 Answers
Your fan may have become loose and is in need of tightening. See this handy diagnostic article on this subject:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Making_Rattling_Sound.htm
Call an A/C technician if all else fails. As a recall, you can get up to four free estimates from local techs in your area according to a text-link towards the middle of the article lined above.
Posted on Jun 28, 2009
Fan heater blower on dimplex cadogan CGN 20 not working properly0 optimyst electric stove
Take it out and see if the fan wil turn by hand. It may have somethng obstructing it. The clicking is the motor overload. It wil burn out if it continues to keep clicking.
www.dimplex.co.uk/assets/.../Cadogan_Stove_Instructions_Issue_2.pdf
Jun 29, 2014 | Heating & Cooling
I hear a higher pitched solenoid buzzing for about 10 seconds every 30 minutes or so. It is a new sound and it seems to be coming from the lower right side of the fridge but I don't notice any...
is your ice maker hooked up?if no water is going to the ice maker and the arm is down it will buzz.also check the fans one in the freezer and one in the rear for the compressor and condenser,maybe a piece of paper is hitting the fan blade when the fan starts or it could be vibration in the frame,ytou can remove the bottom kickplate and you say every half hour or so it makes the sound and listen to see if you can pinpoint the noise,when you open the freezer door the evap fan will run,you can check that fan motor like that.you have to do a little detective work to find the noise but if the ice maker isn't hooked up to the water source and the arm is down it will buzz.good luck.
Jun 06, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
Buzzing noise
Put off it's power supply then switch it on after somtimes
May 12, 2010 | Kenmore 76579 Bottom Freezer French Door...
1998 Lexus gs300 at idle Very loud buzzing type noise from engine
check brake fluid level.
master cylinder might be of interest, but i would check the fluid level first
Apr 08, 2010 | 1998 Lexus Gs 300
There is a buzzing noise coming from the air con unit
if everything is running may just be contactor,if compressor is running not fan turn it off call service tech out(Fan motor bad)if fan is running but no compressor turn it off call service
Jan 06, 2010 | Mitsubishi Heating & Cooling
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Repetitive Buzz
Need to check the cooling fan.
-- open the back cover & unplugg two of cooling fan socket(black & red wires or yellow & red wires)
If the noise still remaining, need to exchange the color wheel.
Jan 29, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Carrier 58GS150-CB ignites but fan will not blow (Loud Buzzing)
The loud buzzing soud i found to be the fan blower motor. I removed the fan bracket assembly and sprayed a little WD-40 on the set screws and protruding shaft so that sqirrel cages could be removed. (Also marked position of set screws on shaft) once squirrel cages were removed I removed 4 motor mounting bolts. Cleaned sqirrel cages and housings with industrial strenghth rim cleaner to remove solid dirt and will replace motor and capacitor.
BTW thanks for nothing
Nov 22, 2008 | Goodman GMS90703BXA Heater
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Ruud UBHC Air Conditioner Logo
336 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
