Question about Acer Aspire 5315 Notebook
Sound problem on Acer Aspire 5315
I have a problem related to sound on Acer Aspire 5315. OS is Windows SP3. in Device Manager the problem appear at High Definition Audio Bus.
I tryed to install form Acer sitr the Audio driver but it doesn't work.
Can you help Me?
  • ciprian_rota Jun 28, 2009
    which one do you sugest?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 162 Answers
You want to download a new sound driver i think your sound driver is not working
Posted on Jun 28, 2009
I've had this problem before; it's the internal 56k modem. you must have uninstalled it. just find, download and reinstall the driver for it.
Posted on Jul 01, 2009
How do i find out what kind of sound card to get for an acer aspire notebook 5315 series. It was bought at a yard sale and has windows 7 on it. Everything works but the sound
Hi Bonnie,
You should check Windows 7 Control Panel's device manager. See if the sound is disabled or if it indicates that it "has a problem" Try to re-enable it - or failing that - uninstall the sound card and click the box that says "remove files". Reboot with an internet connection (wifi or wired). Let windows detect the "new" sound hardware. Check any hardware volume control and set to a mid - high level point. After Windows downloads and installs the driver - follow instructions - reboot if asked. Then test the sound. Check software volume controls in control panel and verify that the sound is enabled. Try using the headphone jack if internal speakers are not producing sound. Once sure that the sound card is loaded, enabled and volume is set to mid - high and neither the internal speakers or external headphone do NOT work, you can consider selecting a new sound source that can use a USB port or PCMCIA (PC Card Slot) depending on your needs and port / slot availability on the laptop. Links below for both styles. Good luck!
pcmcia sound card Google Search
USB sound card Google Search
Apr 09, 2015 | Acer Aspire 5315 Notebook
No sound on acer aspire 5611. I have downloaded all drivers, as well as Realtek HDAudio. Still nou sound! Please help?! Am running XP SP3. There is only one ? device, namely PCI Device PCI\VEN_8086&DEV...
Just for what it's worth, I use the site devid.info for drivers. It has a driver agent as well which will scan for drivers too if needed (it's the only driver "Scanner" that works that I've found). That said, I searched for that device and could not find it on that site.
This driver is on the Acer website for Windows XP. http://global-download.acer.com/GDFiles/Driver/Audio/Audio_RealTek_5.10.0.5273_XPx86.zip?acerid=633638101827496299&Step1=NOTEBOOK&Step2=ASPIRE&Step3=ASPIRE%205610&OS=X02&LC=en&BC=ACER&SC=PA_6
It should work, if not, send me an email to gensupportjsebean@jsebean.com and I'll try to get back to ya!
-Jonah
Oct 06, 2013 | Acer Aspire 5000 Notebook
Pleas .. problem sound cannot working in aspire m1641 os winxp sp3 . drivers cannot remove, Sources drivers cd acer , download link acers, stiil not work sound.. thanks
Try uninstalling the sound card driver, and let windows reboot. This should let windows re-installed the original driver that came with your acer.
Apr 27, 2011 | Computers & Internet
Acer aspire 5610Z mic problem
nope, PCI Flash memory doesn't have anything to do with your mic issue. This may just be a configuration issue. Go to control panel -- sounds and audio devices. Go to Voice Recording under Voice tab. It should not be grayed out. Click Test hardware and follow the instructions. This should help you resolve the problem. If all else fail, reinstall the audio driver.
Nov 08, 2009 | Acer Aspire 5315 Notebook
Sound driver is not installed from the site .either it is corrupt
http://www.laptops-drivers.com/acer-notebooks/acer-aspire-4315-download-driver-for-windows-xp.html
go here and scroll down until you see the realtek audio driver then download it. Then run the driver (install file) on your laptop and you should have your sound back.
I hope this helps
Jan 31, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315-2077
It may show up under USB devices, your audio is Realtek, check to see if it's showing up in device manger. Old trick is to remove the hardware by deleting it from device mgr, reboot and it should pick up the hardware and then install the software for it. The realtek is what I am describing, make sure you physically remove the magic jack before doing this.
Jan 29, 2009 | Acer Aspire 5315 Notebook
Sound problems
well, the driver is not installed properly.. you must install it first so that u can use your cam.. f installed already, check your connections and make sure your cam is detected by your computer
Nov 14, 2008 | Acer Aspire 5315 Notebook
No sound in aspire 5315
- I guess you downgraded your system to windows xp, If that the case you have to check if the system has an internal modem .If so, please download the driver for that PCI modem.
- I have already checked the modem that was already install on your system(V.92 56Kbps* data/fax modem,)
- You have to download the windows xp driver for this modem. or download chipset driver for windows xp
Oct 08, 2008 | Acer Aspire 5315 Notebook
Solving my Audio driver on Windows XP SP2 on Acer 5315-2153
Your system needs audio driver for the sound to work.
follow this link
http://www.acerpanam.com/synapse/forms/acerdrivers.cfm
and download drivers for your system (select your model 5315), make sure you choose the one that matches your OS, that is XP.
Jul 09, 2008 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5315 Notebook Logo
432 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
