Question about ASUS SK8N Motherboard
Setting up asus sk8n and cpu running but i have no video or cd the harddrive is running but cant fix
  • 2 more comments
  • john_henders Jun 28, 2009
    the motherboard is old but the other stuff is new i did what u said still dont work thanks but i still need help
    i did what u said but didnt work the motherboard is old but the other stuff is new what can i try now
    hdd on master and so is cd the video card is new but i tryed pci slot and the other video slot with new cards still no work
    hdd runs in other slot but no help the cd rom come a working cpu if there was no hdd sould i still see the bios on my sceen and thank u for your help
    Problem Solver:
  • 7 Answers
If motherboard is new, then the graphics could be faulty. Is the cd plugged into the same slot on the board as the Hard drive?
If so then the HDD needs to be set to master and the Cd needs to be set to slave. If they are on separate IDE slots then they both need to be on Master. Try putting them onto separate IDE slots and see if it works. Get a replacement Video card. They are cheap enough and make sure you check if your board is running AGP or PCI-Express cards.
Posted on Jun 28, 2009
  • sahmraw Jun 28, 2009
    I think your motherboard is faulty. Is it running the Athlon64 FX-51 chip or the Opteron?
    Your board takes an AGP graphics card up to 8x. If a new graphics card is not working either, I would say you are flogging a dead horse. Did this PC use to work or is it something you have bought for a project? Try swapping the HDD into the other IDE slot and see it if spins. Your cd player is new, you say, but have you tested it in another PC?
    I am just trying to rule out all possibilities before telling you to get another Mainboard.
Asus K53SD HARDDRIVE SLOW
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer atleast two hour a day.
Dec 01, 2013 | ASUS Computers & Internet
Asus sk8n motherboard. Trying to upgrade to 2 2gig cards. Crusial memory, they say will fit. Wont boot with the memory instaled. If I put them in both black or both blue slots freezes up. Cant get the biod...
The Kingston memory web site is an excellent source of memory spec information even if you don't buy their memory.
For the SK8N motherboard, they provide information on restrictions here: (click here)
Read the System Information tab to make sure that you're using the proper memory speed for the processor that you are using.
Apr 23, 2011 | ASUS SK8N Motherboard
Hello,i lost my sound few days ago and tried to install audio driver after installing them and restarting the computer ,a black screen was shown with message'error loading operating system'i don't know...
For that open cpu cabinet.then reconnect both connection to harddrive. Reattach RAM memory . then when you power up the computer press F1 or F2 or del or ALT+F2 then you can see bios setup make sure harddrive is recognized then save settings and exit. If your harddrive is recognize and still not able to load windows then you need reinstall windows with repair option with windows disk . Also try to run computer in safe mode for that when you power up the computer press F8 key 5 to 6 times then you can see safe mode and other menu then enter in safe mode then go to start menu->run type in run "chkdsk /r" without "" then press "y" then restart computer then it will fix and recovers errors on harddrive. Let me know if you need further assistance. Thanks for using FixYa.
Aug 04, 2010 | ASUS P4S8X-X Motherboard
Problem with ASUS P5GD1 mobo
Is the cpu fan working, remove all the memory,but one stick, then try each stick you have. Then, When you get your post, enter safe mode, this does not use full video, so if you can, and it works in safe mode, it is probably your video, if not it is either
your power supply or another piece of hardware.
Unless you installed something on windows just before this problem.
Post back if you need more help, any code errors would be great to post.
Feb 05, 2010 | Computers & Internet
While using my Media Center PC sometimes I get loud beeps from the MB. It seems to happen when a lot of memory is being accessed ( watching and recording a TV show at the same time ) or when the harddrive...
Your ASUS motherboard uses an Award Bios. Open the link provided;
http://www.bioscentral.com/beepcodes/awardbeep.htm
Check the beep codes listed.
Everything you mentioned can easily point to a possible overheating problem. Try cleaning your system fans. Everything electronic will attract dust and dirt which makes your parts run hotter.
If your PC is sitting on the floor the attraction is increased.
Use canned air if you do not have a air compressor. (Do not touch the fans blades while their turning during cleaning), they will break. Pull your system memory and than reseat it. If the loud beeps continue you might consider installing a bolder fan that pulls more cooler air into your case. If your CPU heatsink and fan assembly is clogged with dust you may consider replacing it. Your ASUS motherboard will shut its self down if your system gets too hot. Your ASUS MB also has a bios setting that allows you to check just what the tempture is. See page
4-36 section 4.5.4 in your manual. It wouldn't hurt to install, ASUS PC Probe II from your ASUS CD.
Happy holidays
Mike
Dec 11, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus sk8n mobo on board sound sound isn't working, have updated drivers...n00b here any help?
IF DRIVER IS INSTALLED
CORRECTLY THEN UNPLUG YOUR SOUND CARD AND REPLUG IT
WELL.
Oct 26, 2009 | ASUS SK8N Motherboard
I have a EMachine T6534 which won't start. I shut
I agree...sounds like a power supply problem. Typically a bad power supply will not damage the motherboard. It should still be functional.
Sep 02, 2009 | Computers & Internet
Hi all i have a asusp4p800 motherboard that was on and working till i shut it off to add more mem,and new video card,now when it boots up it wil stop at the asus bios screen unless i unplug the hard drive...
hallo friend
you should remove hdd ID cabals and after that hard disk jumper chak first jumper Hdd master and sacud jumper cd-rom jumper slave
so please chake hear
Aug 15, 2009 | ASUS Computers & Internet
Cpu frequency
1 gig is possible to run, but it is not possible to work your 3ghz cpu because p4s533mx can only accept almost 2.0ghz
Jan 13, 2009 | ASUS P4S533-MX Motherboard
Harddrive installation
In most pc's there will be 4 ide connections. Put 2 hardrives on one cable and add the other one to the cable with the cd drive.
Dec 22, 2007 | Computers & Internet
ASUS SK8N Motherboard Logo
77 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
