Question about Intel Computers & Internet
No Audio In my xp pc Audio is not working, in sound and audio device properties it shows no audio device, no playback device, no recording device& no MIDI playback device. for Video no problems and in hardware tab Audio Codecs. Legacy audio drivers, Media control device, Legacy video capture devices and video codecs are showing "This device is working properly.'' message. my pc is windows XP SP-2, processor Intel(R) Core(TM)2 CPU 4400 @ 2.00GHz & mother boars intel DG965SS.
    Problem Solver:
  • 7 Answers
Here is the link to the page for the driver for your audio. once you install this you should be up and running again. Hope this helps!!
Posted on Jun 28, 2009
I can hear them but they can't hear me
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 28, 2011 | Audio Players & Recorders
Appears to be installed properly but doesn't record
When you first connect the turntable, Windows XP (and Mac OSX) will often select the "USB Audio Codec" as the audio input and output for your entire system. Since your turntable does not have speakers, audio will not be heard from your programs until you tell Windows not to use the turntable as an output device. Here's how to change these settings so that your internal sound card will always be used for playback whether or not your ION TTUSB is connected via USB:
    For Windows:
  1. On the bottom left of your screen, select the "Start" menu.
  2. Select "Settings" then "Control Panel".
  3. In the window that opens, select the "Sounds and Audio Devices" icon. (If you don't see a choice called "Sounds and Audio Devices," choose the "Switch to Classic View" option in the panel on the left of the window, and the "Sounds and Audio Devices" icon should become available in the list on the left.
  4. Select the "Audio" Tab at the top of the "Sounds and Audio Devices" control panel window.
  5. Under "Sound Playback," choose your internal sound card as the default device. This varies by computer but should not be set to "USB Audio Codec" or "Microsoft Sound Mapper".
  6. Under "Sound Recording," select "USB Audio Codec" for your default device.
  7. Check the box titled "Use only default devices".
  8. Click "Apply"...then "OK".
    For Mac:
  1. Open your Hard Disk.
  2. Open your "Applications" folder.
  3. In the "Applications" folder, open the "Utilities" folder.
  4. In the "Utilities" folder, open the "Audio MIDI Setup".
  5. In the "Audio MIDI Setup" under Audio Devices, set:
    • "Default Input" to "USB Audio Codec"
    • "Default Output" to "Built In Audio"
    • "System Output" to "Built in Audio"
Now, all programs, including Audacity, will only use your internal sound card for audio output.
Dec 26, 2007 | ION Audio iTTUSB Turntable
DOES NOT RECORD ANYTHING ON MY WINDOWS XP
Probably need to enable in control panel as per instructions below.
You may also need to check you have correct input device (wave) selected in your recording software
Click VOICE
That should be it.
Feb 24, 2011 | CAD Microphones GXL2200 Professional...
Hy, I have a problem with my mic that is all ready instaled in my laptop also with a camera. When I go to the Control panel to see what is the problem, everything there is ok, but I am not able to work...
There are two separate mic settings in control panel - record and playback. Have you enable record also? See below. Also in Skype-Tools-Options check you have got the right audio device selected (normally WAVE)
Click VOICE
That should be it.
Feb 22, 2011 | Toshiba (P000257700) Microphone
New microphone will not record...please advise.
There are two separate settings in control panel for record and playback - see below
Click VOICE
That should be it.
Feb 20, 2011 | Dynex Voice-Certified PC Desktop...
I cannot get my microphone to work
Click VOICE
That should be it.
Feb 19, 2011 | Toshiba (P000257700) Microphone
My microphone is built in to the computer but will not even show up in my recording devices. it used to work fine and now it doesnt say it even exists on the computer.
See last paragraph of instructions below re unlisted devices.
Click VOICE
That should be it.
Feb 19, 2011 | Compaq Audio Players & Recorders
My microphone on Presario F762NR stopped working i did troubleshooting and it did not find any problem! maybe it is turned off somewhere and i don't know where!
Click VOICE
That should be it.
Feb 18, 2011 | Compaq PC Microphone (Black or Beige)...
My computer will not see or hear sound from my microphone but i know it works
Click VOICE
That should be it.
Feb 17, 2011 | Labtec Verse-514 Consumer Microphone
Hi,I'm having a very big problem.In the Sound and Audio Device it is said that there's No audio Device !.Even though days before, i was having sound.In the Audio tab,in the MIDI music playback there's...
Ok, if you have the audio driver installer with you then it's fine, otherwise download it from your PC manufacturer's site for your model no. Run the installer, it will extract some files in C drive in a folder. now open device manager, right click on audio controller and select update option, then select install manually and "i will choose driver". In the next dialogue, click 'browse' and point it to the folder where driver has extracted files, inside the folder somewhere there will be a .inf file, select that and click OK.
If you are still having difficulty, then post here your model no., audio device etc. in detail, then i can guide you better.
Dec 10, 2010 | Microsoft Windows XP Professional
Computers & Internet Logo
368 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
