Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Both drawers have water in it the wont drain what can i do?
Mine flashes an f4 error and won't drain. One of the other posts tells you how to fix it. You have to clean the filter with a toothbrush.
Posted on Aug 12, 2009
  • rstarkey351 Jul 31, 2011
    yes this worked, thank you, my filter was full of broken glass, brocken crockery and food stuffs, even though we always rinse first. Fixed my F4 problem.
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Fisher paykel cross draining
As the drawers share a common outlet to the kitchen sink drain, it is the drain water from bottom drawer going to top drawer. Can happen if the drain hoses are not following the correct specifications for installation. An air gap kit is available to solve the problems.
Refer
http://www.genuineapplianceparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/?preadd=action&key=WT50
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
There is water left in the fisher paykel dishdrawer after cycle. it is a single drawer. it is not displaying an error. how do we get the water out?
I need to know which model you have, so I can walk you through this. Or close drawer, push start, the unit will drain first, when done draining, push stop or pause before filling starts, then power to shut down. This will get rid of the water only. I would check the drain hose and all drain sources for obstructions, this unit has a time drain and if obstructed, it will leave water in the unit. Is this a double drawer? Is the problem only seen in one drawer (lower), need model number to unit stand what problem you may have.
Good Luck
Aug 21, 2011 | Dishwashers
The fabric conditioner drawer stays full of water and wont drain. Ive cleaned it thoroughly?
There should be a drain tube, or something like that, inside the machine that goes to the drawer that may be clogged.
Please rate, and write testimonial if you feel the need to, if this was helpful.
Good Luck
cookieMonster
Oct 07, 2010 | Washing Machines
Have a rental property with F&P two draw dishwasher aprox five years old. Apparently bottom draw is holding water - what do you think?
Could be many reasons for the bottom drawer to hold water.
It could be leaky top drawer causing water to collect in the bottom drawer. Check if water collects when top drawer is running.
It could be blockage in the bottom drawer drainage which can be fixed by cleaning the filter plate and the drain sump. If the drain pump is not running during drain cycle then you will have to replace the drain pump motor.
Aug 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Lower drawer drains into upper drawer.
You are most likely correct,they tend to give out over time.
Aug 17, 2009 | Dishwashers
After 2 minutes top washer blinks. Water does not drain
When I opened the top drawer the water seems to be accumulating in the drawer and no water is draining. The drain tube appears normal and not kinked in any way.
Jan 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
One drawer drains into the other and vice versa
hope someone has a solution as we also have this problem...
May 25, 2008 | Dishwashers
Refrigerator - water liking under the meat drawer
defrost drain stopped up cleanout the drain from the freezer to the drain pan
May 07, 2008 | Jenn-Air JCD2295HES Side by Side...
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
636 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
