Printer Canon PIX
  • joop_v Jun 28, 2009
    Thank you, but all this I knew already. The fact is that indeed there is a false call for papar jam. There is a part that has to be replaced.
    The manual said that that one can pull the paper back from the input side. But aparently this may cause breakage of a part. Luckily the printer is still in the guarantee.
    By the way, you wrote about HP printer, but mine is a Canon.
  • joop_v Jul 06, 2009
    Thank you for your advice, but you did not tell me new. I felt hopeless because there was a message about paper jam, but there was no one little piece of paper in the printer.
    The solution: Because - according to the manual - I pulled the originally jammed paper backwards, a part of the machine broke. So I brought it to a repair shop and now it works again.
  • 13,433 Answers
    President:
  • 1,952 Answers
  • 3 more comments
  • mohammed marika thambi
    mohammed marika thambi Jun 28, 2009
    You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
    Also see this:
    Issue: Paper is jammed inside the printer
    Solution: Removing paper jams MP600
    Removing Obstructions or Jammed Paper
    If [Paper output slot - The paper is jammed. Clear the paper and press
    OK] appears on the LCD, follow this procedure to clear the paper jam
    Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
    Clearing paper jams inside the printer
    Clearing credit card-sized or 4" x 6" paper jammed inside the printer
    ASF / Paper Output Slot
    1. Turn off the printer.
    2. Remove paper from the ASF.
    3. Gently pull the jammed paper out.
      1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
      2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
        The above illustration shows a PIXMA MP500.
    4. If the paper tears and a piece of that remains inside
      the printer, open the scanning unit (printer cover) and remove the
      paper from inside the printer.
      Note:
      Be careful not to touch the components inside the printer.
    5. Turn on the printer and confirm that the Alarm light is off.
      (If the jammed paper remains in the printer, the paper may be automatically ejected.)
    6. Load paper back into the ASF.
    7. Press to clear the message and continue printing. If you are
      printing from an application software, follow the instructions
      displayed on your computer.
    Top
    Paper jams inside the printer
    1. Turn off the printer and disconnect the power cord and USB cable.
    2. Remove the jammed paper slowly using the following procedure.
      1. Open the rear cover to check if the paper is jammed.
      2. Pull out the cassette and check if the paper is jammed inside the cassette area.
      3. Stand the printer with the left side down, holding the document cover.
      4. Press the tabs together and pull the green cover toward you.
      5. Check if the paper is jammed.
        (If you were not doing Duplex printing, you do not have to follow this procedure.)
      6. Close the green cover and place the printer back to a normal position.
    3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
    4. Load paper back into the ASF or cassette.
    5. Press to clear the message and continue printing. If you are
    Top
    Clearing credit card-sized paper jammed inside the printer
    Credit card-sized and 4" x 6" sized paper must be loaded properly. If
    this media is not loaded properly, it will feed into the printer and
    will not exit. Credit card-sized paper should only be loaded in the ASF
    and in portrait orientation. 4" x 6" sized paper can be loaded in the
    ASF or cassette. But must be loaded portrait orientation.
    If credit card-sized paper was loaded in landscape orientation in
    the ASF and did not eject (exit), please follow this procedure.
    2. Load the same paper type that is jammed inside the printer in portrait orientation.
    3. Power on the printer.
      The paper stock in the ASF will automatically feed the jammed paper from the printer.
    4. To resume printing, load the paper in portrait orientation.
    If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
    2. Open the rear cover.
    3. Fold in four a piece of letter-sized plain paper.
    4. Push in the folded paper until it hits the jammed paper.
    5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
    6. If the jammed paper cannot be pulled out, push in the
      folder paper from the rear so the jammed paper is in between the feed
      rollers.
    7. Pull out the folded paper and close the rear cover.
    8. Power on the printer and confirm that the Alarm light is off.
      The jammed paper should automatically eject.
    9. To resume printing, load the paper in portrait orientation.
    I hope this information allows you to resolve this issue. If you
    need further assistance, please post back with a comment to this
    thread.
    If I've managed to answer your question or solve a problem,
    Paper jams can be real or false. The unit may report a paper jam when
    there is not any jammed paper, however, the solution to a real paper
    jam or a false paper jam is the same.
    WARNING:
    Jammed paper must be removed using the rear
    access door and the power cord must be disconnected or a carriage jam
    or mechanical damage may occur. Do not remove jammed paper from the front of the unit.
    1. Turn off the HP product and turn it so the back of the unit faces you.
    2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
    3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you.
      Figure 1: Removing the rear access door
    4. Inspect the pressure rollers on the rear access door and verify that
      they are clean and turn freely. Clean the rollers if needed with a soft
      towel lightly moistened with water. If the rollers do not turn freely,
      replace the rear access door.
    5. Inspect the pressure rollers on the rear access
      door and verify that they are clean and turn freely. Clean the rollers
      if needed with a soft towel lightly moistened with water. If the
      rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
    6. From the rear access door opening, remove the jammed paper.
    7. Remove the remaining paper from the paper supply tray. Discard any
      paper that is damaged or crumpled and then re-stack and reload the
      paper into the paper supply tray.
    8. Reinstall the rear access door.
    9. Reconnect the power cord to the unit and turn the unit on.
      If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
    Preventing paper jams
    The following information will help prevent paper jams from occurring:
    • When loading paper in to the paper tray, push it in
      until it meets first resistance. Do not continue pushing the paper in.
      If the paper is pushed too far in, more than one page is picked and
      paper jams result. This is the most common cause of paper jams with the
      HP Officejet 410 series.
    • Never use paper that is wrinkled or damaged in any way.
    • If you are having problems using paper that has already been printed on once, replace it with fresh paper.
    • Remove and then reinstall the rear access door.
      Verify that the access door is fully locked in place. The paper can
      skew if the rear access door isn't locked.
    • Every six months - one year, clean the paper
      feed rollers with a rag slightly dampened with clean water. Over time
      the paper feed rollers accumulate dust and do not function as well as
      they once did.
    • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
    Please do rate the solution as FixYa and revert for further assistance.
    This multi-function unit started out
    great until the rollers began to jam and the unit is now, after
    following all prompts in the user manual, ready for replacement just
    months after purchase. The wheels squeak and it jams for some strange
    reason. Paper is right weight and dimensions. So, give it a go, but
    make sure to buy an extended warranty. Normally I am a total Canon fan
    but this one is a real lemon.
    5 of 5 people found this review helpful.
    mohammed marika thambi Jul 06, 2009
    ur printer worked .........ok thanks
    Paper is jammed in the top or rear of the printer. Clear
    jam and press Continue or Online to resume printing. To prevent further
    jams, verify the rear door is closed securely. A false paper jam message
    will occur if the printer's back door is open. If message persists, the
    printer could have a defective paper jam sensor and service would be
    required.
Morning, Im working with a Canon All-In-One Inkjet MX300 printer. It is not allowing me to print as it keeps telling me I do not have paper loaded in the printer. I have turned it off, and back on. Even...
Hi....hard time with your Canon... It possible you have a paper jam inside you unit.. at the back you will see a endle in both side take off the tray and look for paper jam., also check where you feed the paper if you don't have anything like paper clip pencil jam it inside the feeder
Oct 16, 2010 | Canon MX300 Office All-In-One Printer
Paper jam
Check the inside of the machine, and try unplugging the power cord for ten minutes first.
Sep 11, 2008 | Canon MX300 Office All-In-One Printer
Canon Pixma MX300 printer had a paper jam. I took out the paper, and it was all there with no missing parts. It continues to say there is a paper jam - there appears to be no reason for the jam. I...
Try checking that a foreign object is in the paper feed rollers- do this by inserting a thin piece of plastic about 2 cm wide through the rollers from the paper exit side. Plastic like that from a shirt box (about 2cm wide by 20 cm long and 1 mm thick works well. I have solved this problem many times with my mx300 and it clears out objects which have droppped into the paper feed, such as Pens , yes pens. and paper clips etc which are otherwise hard to detect on this printer.
Sep 25, 2010 | Canon PIXMA MX300 All-in-One Printer
I have a printer paper jam error but there is not any jam. How do I bypass this error.
There are some "micro-sensors" that detect a jam.
You've got a tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor.
Turn the printer off, and disconnect the AC power-cable.
Try a can of compressed air, to give the printer a "blow-job".
If unsuccessful, it's time to take the printer to a qualified technician, for proper troubleshooting.
Apr 10, 2010 | Canon MX300 Office All-In-One Printer
Paper Jam
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Aug 30, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon Pixma mx300 printer has paper jam message.
Canon Pixma MX300
- new cartrige for Black ink
- can scan
- can photocopy documents
BUT can't print documents from my MacBook eventhough the paper feeds and goes out at the other side
Aug 10, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Canon MX300 printer shows jam and no paper in
I got hold of Canon support & he had me give him a # behind the white ribbon inside & after that he asked when purchased (7-28-08) Now I will be getting a new unit and have to send back old one at NO cost to me. Who knows???? Was happy with the outcome & surprised!
Nov 16, 2008 | Canon PIXMA MX300 All-in-One Printer
102 people viewed this question
k24674
jasbo
jasbo
